Raspberry Pi
Raspberry Pi
Documents Raspberry Pi Camera Board
  • Author Author: Yiying
  • Date Created: 8 May 2013 9:28 AM Date Created
  • Last Updated Last Updated: 10 May 2021 3:00 PM
  • Views 8188 views
  • Comments 8 comments
BUY NOWBUY NOWTechnical DocumentsVideoFeaturesKit Contents
Overview
The Raspberry Pi Camera Module is a custom designed add-on for Raspberry Pi. It attaches to Raspberry Pi by way of one of the two small sockets on the board upper surface. This interface uses the dedicated CSI interface, which was designed especially for interfacing to cameras. The CSI bus is capable of extremely high data rates, and it exclusively carries pixel data.
The board itself is tiny, at around 25mm x 20mm x 9mm. It also weighs just over 3g, making it perfect for mobile or other applications where size and weight are important. It connects to Raspberry Pi by way of a short ribbon cable. The camera is connected to the BCM2835 processor on the Pi via the CSI bus, a higher bandwidth link which carries pixel data from the camera back to the processor. This bus travels along the ribbon cable that attaches the camera board to the Pi.
The sensor itself has a native resolution of 5 megapixel, and has a fixed focus lens onboard. In terms of still images, the camera is capable of 2592 x 1944 pixel static images, and also supports 1080p30, 720p60 and 640x480p60/90 video.
The camera is supported in the latest version of Raspbian, Raspberry Pi's preferred operating system.
More Resources
imageRaspberry Pi Group
imageMore Raspberry Pi Accessories
Technical Documents
Learning Center
TypeDescription
Quick User GuideGetting Started with the Raspberry Pi Camera Module
Design Elements
TypeDescription
SoftwareComing soon!
Back to top
Video
Back to top
Features
  • Small board size: 25mm x 20mm x 9mm
  • A 5MP (2592×1944 pixels) Omnivision 5647 sensor in a fixed focus module
  • Support 1080p30, 720p60 and 640x480p60/90 video record
Back to top
Kit Contents
  • 1 Camera module
  • 1 ribbon cable
Back to to
  • raspi
  • video
  • 5mp
  • raspi_accessories
  • raspberry_pi
  • camera_module
  • raspberrypi
  • rpi
  • camera
  • raspeberry_pi_accessories
  • cudmore
    cudmore over 13 years ago +1
    Any chance you will carry this camera without the IR filter? It was on the UK website but is currently out of stock. Providing this camera without the IR filter opens up the possibilities for the cameras…
  • lotharyx
    lotharyx over 11 years ago in reply to e14 Contributor
    Generally speaking the number after the p (or i) does mean framerate.
    hi
    What is the FOV of this module?
    any spec on the lens?
    thanks
  • lotharyx
    What is the focal length and aperture of the lens?
  • dkelley810
    dkelley810 over 11 years ago
    Is the Camera board open source? can I get the eagle files somewhere?
    e14 Contributor over 12 years ago in reply to e14 Contributor
    Hi, there is non NOIR module on element, but globally it is sold.
    Here is proof
    http://www.adafruit.com/products/1567
    29 USD
    there is also more advanced IR camera Infragram (Kickstarted) for PI which cost 55 USD
    http://www.adafruit.com/products/1722
    1080p30   does the 30 represent fps?
    Another vote for a Non IR filter version.  My current project needs to compare an IR illuminated image to a normal light image to identify differences.
  • cudmore
    Any chance you will carry this camera without the IR filter? It was on the UK website but is currently out of stock. Providing this camera without the IR filter opens up the possibilities for the cameras usefullness. In my case I want to monitor the activity of mice in the dark (with IR lights).
    Please say you will stock the Rapsberry Pi NOIR camera!!!
