Raspberry Pi
Raspberry Pi
Documents Video 1: Unboxing and Setting up the Peripherals
  • Author Author: joeman
  • Date Created: 19 Dec 2013 8:13 PM Date Created
  • Last Updated Last Updated: 10 May 2021 7:13 PM
  • Views 1914 views
This is the first video in our 2013 five-part series Get Started With Pi for Raspberry Pi 2.
Episodes in this Series:
image  Unboxing and Setting up the Peripherals
Video 2: Exploring the Raspberry Pi
Video 3: Getting your Pi Online
Video 4: Your First Pi Project
Video 5: Exploring Accessories and Projects
What you will need:
  • Model B Raspberry Pi
  • Power Supply
  • 8GB NOOBS Software pre-programed SD Card
  • Protective ABS plastic case
  • A monitor (television or computer monitor will both work, provided they have the right inputs)
  • A Keyboard and Mouse
  • connectors specific to your set-up
Running Raspberry Pi Configuration
To get to the configuration tool after your initial install of the operating system, open LXTerminal and type: sudo raspi-config
Set the locale
The format is a two-letter abbreviation for language followed by an underscore “_” followed by a two-letter abbreviation for the country.  Always select the UTF-8 option, if one is available. Link to table of location/language values:  http://docs.moodle.org/dev/Table_of_locales
IMPORTANT NOTE:  The en_GB.UTF-I UTF-8 option will be pre-selected by default (the Pi comes from the UK after all).  Be sure to unselect this option (unless you’re in the UK) when you’re selecting your appropriate locale.
Time Zone Selection
Your Pi will not show the current time until you connect it to the internet, even after you select the time zone from the NOOBS configuration menu.  The Pi doesn’t have a real-time clock.  It will automatically get the time using the Network Time Protocol.
If you don't have an Internet connection then you can use the date command to set the date / time appropriately.
sudo date -s "Jul 5 08:10"
  • peripherals
  • raspberry
  • series
  • pi
  • video
  • parts
  • setting
  • started
  • unboxing
  • raspberry_pi_getting_started
    where is the starter for pi 2?
    Great production values.
