Raspberry Pi
Raspberry Pi
Documents Stack Up & Add More Features to Your Raspberry Pi Model A, Model B, Model B+, Pi 2, Pi 3
  • Author Author: joeman
  • Date Created: 20 Oct 2014 2:45 PM Date Created
  • Last Updated Last Updated: 10 May 2021 8:51 PM
  • Views 1140 views
Start with the Microstack Adapter Board for Raspberry Piimage
Buy NowBuy Now
The Microstack adapter board for Raspberry Pi provides an interface between Microstack Accessory boards & the Raspberry Pi.
image  Connect two MICROSTACK modules to Raspberry Pi
image  Mounting headers for the various Microstack accessories
image  Connects to the RPI via the GPIO connector
Tech Specs image
imageIndicates product is Raspberry Pi 3, Pi 2, Model B+ & A+ compatible.
Now Available!  Add on Microstack Boards
Microstack GPS
Buy NowBuy NowMore Info image
Microstack Accelerometer
Microstack PROTO
Microstack boards are plug-and-play modules designed to add extra functionality to existing development kits.  These small, function-specific add-on boards/modules all have a common interface to the Microstack adapter board.
Multiple Microstack boards can also be used simultaneously to enable many features to be implemented at the same time.  These Microstack boards offer a wide variety of creative build capabilities.
Buy NowBuy Now
Microstack GPS
image  Low power, quick position-fix and in built data logging
image  Embedded high sensitivity internal patch antenna with optional external antenna connection
image  Power saving mode for automatic sleep in inactivity
image  Can be used directly in breadboards, prototyping and custom designs
image  Easy plug and play development
image  Automatic antenna switching function
image  Support short circuit protection and antenna detection
image  Built-in LNA for better sensitivity
image  EASYimage, advanced AGPS technology without external memory
image  AlwaysLocateimage, an intelligent controller of periodic mode
image  LOCUS, innate logger solution with no need of host and external flash
image  High sensitivity 165dBm @ Tracking, -148dBm @ Acquisition
image  66 acquisition channels, 22 tracking channels
image  Support DGPS,SBAS(WAAS/EGNOS/MSAS/GAGAN)
image  Anti-Jamming, Multi-tone Active Interference Canceller
image  MICROSTACK Framework compatible
image  Can be combined with other MICROSTACK add-ons
image  Radio links to support remote telemetry
Tech Specs image
Buy NowBuy Now
image  Extreme low power, 400 nA per Hz
image  Ultra-fast data output time, ~700 μs
image  1.95V to 3.6V VDD supply range
image  3 mm x 3 mm, 0.65 mm pitch with visual solder joint inspection
image  ±8g full-scale range
image  14-bit digital output, 1 mg/LSB sensitivity
image  Output Data Rate (ODR), implementation based from < 1 Hz to 800 Hz
image  I2C digital interface
image  3-axis, 45° tilt outputs
Tech Specs image
Buy NowBuy Now
Microstack PROTO
image  Generous Prototyping area
image  Common MICROSTACK interface
image  One design works on multiple platforms
Tech Specs image
  • pi 3
  • raspberry
  • b+
  • to
  • your
  • pi
  • up
  • more
  • stack
  • tagged
  • b
  • plus
  • raspberry_pi
  • content
  • with
  • model
  • add
  • a
  • pi 2
  • features
