Raspberry Pi
Raspberry Pi
Documents Raspberry Pi 2 Model B 1GB Technical Specifications
  • Author Author: pchan
  • Date Created: 23 Jan 2015 4:01 PM Date Created
  • Last Updated Last Updated: 10 May 2021 7:09 PM
  • Views 40265 views
  • Comments 62 comments
The Raspberry Pi 2 Model B 1GB
6X Faster
Learn More
Buy NowBuy Now
Benefits  image
Technical Specifications  image
Features  image
Benefits:
Get personal with your Pi. Welcome to the Raspberry Piimage 2, the single board computer that thinks it’s a home PC.
Enhanced Quad Core Processor and 1GB RAM now provides you with the opportunity to:
  • Build your own workstation – create and manage your documents and spreadsheets with ease using LibreOfficeimage
  • Faster and more enjoyable gaming – experience less lag and more seamless gaming in all your favourites. Can’t wait to demolish buildings in Minecraftimage, trigger your TNT now and be amazed by the results!
  • No more buffer face – boots up Raspbian in less than half the time as the Model B+
  • More power for your favourite projects – create Space Progammes, Time Lapse Videos, GPS tracking, HD audio and lots more with a full ecosystem of supporting accessories.
  • All your previous Raspberry Pi projects are 100% backward compatible with the new Raspberry Pi 2 Model B 1GB
Technical Specifications:
  • Broadcom BCM2837 Arm7 Quad Core Processor powered Single Board Computer running at 900MHz
  • 1GB RAM
  • 40pin extended GPIO
  • 4 x USB 2 ports
  • 4 pole Stereo output and Composite video port
  • Full size HDMI
  • CSI camera port for connecting the Raspberry Pi camera
  • DSI display port for connecting the Raspberry Pi touch screen display
  • Micro SD port for loading your operating system and storing data
  • Micro USB power source
Raspberry Pi 2 Model B Features:
  • Broadcom BCM2837Arm7 Quad Core Processor powered Single Board Computer running at 900MHz
  • 1GB RAM so you can now run bigger and more powerful applications
  • Identical board layout and footprint as the Model B+, so all cases and 3rd party add-on boards designed for the Model B+ will be fully compatible.
  • Fully HAT compatible
  • 40pin extended GPIO to enhance your “real world” projects. GPIO is 100% compatible with the Model B+ and A+ boards. First 26 pins are identical to the Model A and Model B boards to provide full backward compatibility across all boards.
  • Connect a Raspberry Pi camera and touch screen display (each sold separately)
  • Stream and watch Hi-definition video output at 1080P
  • Micro SD slot for storing information and loading your operating systems.
  • Advanced power management:
  • You can now provide up to 1.2 AMP to the USB port – enabling you to connect more power hungry USB devices directly to the Raspberry PI. (This feature requires a 2Amp micro USB Power Supply)
  • 10/100 Ethernet Port to quickly connect the Raspberry Pi to the Internet
  • Combined 4-pole jack for connecting your stereo audio out and composite video out
  • raspberry
  • broadcom bcm2837
  • the
  • pi
  • 2
  • new
  • b
  • raspberry_pi_space
  • technical
  • 1gb
  • model
  • specifications
  • alnico
    alnico over 11 years ago in reply to e14 Contributor +1
    I moved over 1000 miles from it, unfortunately. Fortunately, I have a buddy that is close and can buy and ship to me cheaper than the element 14 'personal' partner does.
    shabaz over 11 years ago in reply to e14 Contributor +1
    No full schematic is publicly available (it is not open source). But yes, you can directly connect 5V DC to the 40-way connector if you wish to.
  • Dhananjayan
    Dhananjayan over 4 years ago
    Nice
  • clem57
    clem57 over 10 years ago in reply to e14 Contributor
    No. If you need, consider a Mcu like MCU target board based on STM32F107VC
    Does this chip contain an on chip adc??
    e14 Contributor over 11 years ago in reply to balearicdynamics
    Thanks. I have this document. But it does not contain required details. image
    balearicdynamics over 11 years ago in reply to e14 Contributor
    You reach this link from top of this pos! image http://www.farnell.com/datasheets/1878224.pdf
    Can you share a link to one of these datasheets with me? Did not find anything like this in the package with the device.
    Hello Alexander,
    the environment for stockage and operating conditions of the PI (almost for any device) are mentioned in the paper you find inside the box or reported to the bottom of the same pdf version that you can find in one of the datasheets of the product on element14.
    Hi,
    Where can we find environment conditions to run Raspberry Pi 2 Model B? Temperatures, vibrations, humidity and so on.
    Where are Schematics for Raspberry Pi 2 available?
    Can i connect 5V DC directly to 5V GPIO header(from battery) Pin 2 to power the board?
