Raspberry Pi
Raspberry Pi
Documents Pi 2 versus B+ - Which boots Raspbian faster?
  • Author Author: cstanton
  • Date Created: 12 Feb 2015 3:27 PM Date Created
  • Last Updated Last Updated: 10 May 2021 7:06 PM
  • Views 2240 views
  • Comments 9 comments
Side by Side comparison
I was pretty fortunate to get my hands on an Raspberry Pi 2 Model BRaspberry Pi 2 Model B early, even when you work within element14 being able to get hold of the products is akin to panning for gold!
In this video I have a Raspberry Pi BRaspberry Pi B+ and a Raspberry Pi 2 Model B. They are both using class 6, Hama brand microSD cards with a stock installation of Raspbian which has been booted at least once to go through the setup process. They're using the same 5v, 2amp power supply5v, 2amp power supply and they do not have any peripherals connected. They are turned on at the same time by flicking a power switch on the 4-way socket extension that they're both plugged into and both boards are at stock speeds.
The Pi 2 manages to get to the desktop environment some 18 seconds faster than the B+ , though I noticed that the B+ appears to pause in one or two points in particular on boot and I wonder how much difference it would make if those services were prevented from starting?
  • raspberry_pi_b+
  • raspberry pi 2
  • raspberry pi boot comparison
  • boot comparison
  • raspberry_pi_2
  • raspberry_pi_space
  • raspberry pi b+
  • boot
  • comparison
  • speed
  • raspbian
  • amgalbu
    amgalbu over 11 years ago +2
    Sad to see that both boots faster than my Windows system
  • cstanton
    cstanton over 11 years ago in reply to saurocksall +2
    I doubt there will be a standard desktop build of Windows for the Pi 2.
  • saurocksall
    saurocksall over 11 years ago +1
    I wonder how fast will Windows 10 will take to boot up on this....
    e14 Contributor over 11 years ago in reply to e14 Contributor
    Sorry I'm on WinEnterprise restraints here, i might check out the link later. image
    I'm gonna still use Rasbian though....
    e14 Contributor over 11 years ago in reply to cstanton
    Yes...
    I know, but it'll expand into something!
    That has GUI!
  • cstanton
    cstanton over 11 years ago in reply to e14 Contributor
    It's currently a command line only build where by you push compiled binaries to it from Visual Studio, if you look at how the Intel Galileo runs Windows:
    http://connect.microsoft.com/directory/?keywords=windows+embedded
    But check out www.windowsondevices.com!
    Microsoft is already building for the pi!
    Good fast boot for the new unit. should have had a brighter monitor on the new unit.
  • cstanton
  • saurocksall
  • amgalbu
    Sad to see that both boots faster than my Windows system image
