Raspberry Pi
Raspberry Pi
Documents Can the Raspberry Pi 2 Replace your Desktop Computer?
  • Author Author: biglesp
  • Date Created: 12 Feb 2015 4:06 PM Date Created
  • Last Updated Last Updated: 10 May 2021 7:05 PM
  • Views 13009 views
  • Likes 20 likes
  • Comments 102 comments
With the recent release of the Raspberry Pi 2 we have seen a flurry of new benchmarks and statistics that represent how powerful the new Raspberry Pi 2 is when compared to the older Raspberry Pi models. From a CPU point of view the new Raspberry Pi is around 6 times more powerful than its predecessors but how can we show this in a more meaningful way?
A more meaningful method to show the power of the Raspberry Pi 2 is to use it as a desktop computer. What can we do with Raspberry Pi 2 that we could not realistically do with Raspberry Pi 1?
In this blog post we will install a range of common applications and use them to gauge how feasible it would be to use the Raspberry Pi 2 as a desktop computer. We won't focus times or other metrics rather we will use a real live person..Me to judge if something takes too long to load or is too slow to use.
So without further ado let's get started.
Test 1 - Create Documents with LibreOffice
LibreOffice is a free office suite that provides the same functionality as Microsoft Office. A standard install of LibreOffice provides you with applications such as
  • Writer - Word Processor
  • Calc - Spreadsheets
  • Base - Database
  • Impress - Presentation
  • Draw - Illustration
  • Math - Equations
To install libreOffice you will need to be connected to your home broadband via WIFI or Ethernet. Open LXTerminal and enter the following commands, remember to press enter at the end of each line.
sudo apt-get update
sudo apt-get install libreoffice
The first line updates our list of available software with a central list this ensures that we are installing the latest software.
The second line installs LibreOffice using the APT package management tool which is common to all Debian based operating systems of which Raspbian is one.
Once installed you will be able to access the Applications via the menu at the top left of your screen, in there will be a new section called Office. Let’s start exploring the LibreOffice suite by launching the Writer application.
Writer
Writer is a word processor application that packs all of the same features as Microsoft Word but is an Open Source application, by which the code that makes the LibreOffice is available to all who wish to see it. It is also a free application so no charges are made to use it.
With LibreOffice Writer you can
  • Create a resume / CV
  • Write a novel
  • Produce reports, including graphs and data from LibreOffice Calc.
  • Create web pages using HTML
  • Export work to PDF
  • Save work as Microsoft compatible files for office and school use
Plus lots more use cases. Anything that can be done with Microsoft Office can be done with LibreOffice.
Calc
LibreOffice Calc is a spreadsheet application that offers the same functionality as Microsoft Excel. You can easily perform tasks such as
  • Home accounts
  • Statistical analysis
  • Graphs and tabular data
Test Results
LibreOffice works extremely well taking only 9 seconds to boot with the Raspberry Pi 2. Using Writer and Calc was a slick and pleasurable experience with very little to no lag when navigating the menus. The Raspberry Pi 2 is clearly powerful enough to be used for your next class report or novel.
Test 2 - Edit graphics with GIMP
GIMP, the GNU Image Manipulation Programme is a fully featured bitmap editor with a similar set of functionality to the very expensive Adobe Photoshop. With GIMP you can
  • Edit photographs
  • Color correct images
  • Airbrush
  • Convert images from various formats
  • Create animated GIFs
To install open LXTerminal and type
sudo apt-get install gimp
Once installed GIMP resides in the Graphics menu and can be launched by clicking on it’s entry.
Once GIMP has launched you will be presented with a blank page, you can open an image saved on your Raspberry Pi and edit it to meet your needs. In our test we edited a high res image of the Raspberry Pi 2. Applying colour correction and a blur filter using the built in functions was fairly straight forward, if a little slow.
Test Results
The Raspberry Pi 2 handled GIMP rather well. It was able to keep up with our demands and rarely slowed down. When applying filters there was some slow down but this is also true on machines of a high specification, so pay no heed to that as an indicator.
GIMP on the Raspberry Pi 2 is a pleasant and usable experience and provides a great working environment for budding illustrators
Test 3 - Create Vector Illustrations With Inkscape
Inkscape is a particular favourite of mine, it is an Open Source alternative to Adobe Illustrator and packs a serious amount of functionality into a small application. It is a vector image editor, where illustrations are created using mathematical vectors rather than individual picture elements (pixels) which is how GIMP edits images.
With Inkscape you can
  • Design website layouts
  • Edit SVG images, SVG can be inserted into web pages
  • Design graphics for print, web and broadcast use
To install inkscape you will need to open LXTerminal and enter the following.
sudo apt-get install inkscape
Inkscape is available via the Graphics menu, launch it when ready.
Inkscape does take some time to load and this is true even on my Core i5 laptop with 8GB or RAM. Once loaded it can stutter a little when handling large images but for the most part it is stable and responsive. To really push the Raspberry Pi 2 we loaded one of the intensive examples, a highly detailed yellow car, and inkscape took a short while, around 10 seconds to fully display the image.
Test Results
Inkscape is rather slow on the Raspberry Pi 2 but it is usable, just. We wouldn't recommend editing large documents or illustrations but for day to day tinkering and making it will do a good job of small to medium sized projects.
Test 4 - Editing Audio With Audacity
Audacity is an Open Source audio editor that is favoured among podcasters around the world. It provides a massive amount of power via a series of intricate menus and configuration options. Splicing, manipulating and editing audio is possible thanks to Audacity.
To install Audacity open LXTerminal and type the following, remember to press Enter at the end of the line.
sudo apt-get install audacity
Audacity can be found in the menu under Audio and Video.
On first launch Audacity will present a top tips dialog box, this is a really handy gesture and I tend to keep it turned on for future reference.
Editing audio in Audacity can be as simple or complex as you wish. In our tests we opened a short wave file and applied an echo filter to it. Applying filters to audio can be a slow process, depending on the size of the file used. Audacity on the Raspberry Pi 2 is not really meant for handling large files, editing short audio clips is possible but much larger files will easily overpower the Raspberry Pi 2.
Test Results
Audacity is an application that can really test a computer, editing audio on a Core i5 is still a resource hog and so it is quite remarkable that the Raspberry Pi 2 can run Audacity as well as it did. We wouldn'tsuggest editing a podcast but sound effects for projects could be easily edited on your Raspberry Pi 2.
Test 5 - Drawing Circuits With Fritzing
Whenever you see a layout diagram or breadboard schematic on Element 14 they will most likely have started life as an illustration in Fritzing. Fritzing is a vector illustration editor that specialises in producing high quality illustrations of maker projects. It comes with a massive parts bin, parts being the common components used in projects, such as LEDs, capacitors, switches etc.
To install Fritzing open LXTerminal and type the following, remember to press Enter at the end of the line.
sudo apt-get install fritzing
Once installed, Fritzing can be found in the Programming section of the menu.
We launched Fritzing and immediately came across an issue with not all of the parts, that’s components to be used in illustrations, being available for use. This can be fixed by importing your own components into the parts bin, but this is out of scope for this blog post.
We created a simple illustration of an Arduino Uno, connected to an LED via a resistor on a breadboard. Fritzing was quick to respond and never slowed down in testing.
Test Results
Fritzing is a great application and it is awesome to see it work on the Raspberry Pi 2. You really could use the Raspberry Pi 2 as a maker computer that meets the project illustration role admirably.
Final Thoughts
It is still early days for the Raspberry Pi 2 but after the initial fanfare has faded we are still left with a solid desktop computer for $35. The sheer power on offer for such a low price is incredible and really outshines other boards on the market.
Yes the Raspberry Pi 2 is not a top spec computer, but it is a sheer powerhouse for it’s size and price. We have proven in this blog post that the raspberry Pi 2 can be used as a second PC in the home either for a child to tinker with or as a serious alternative purchasing a laptop for basic home accounts and office admin duties.
But there aren’t that many home PCs that can travel into space or become robots and investigate the world around them. Only the Raspberry Pi 2 can be all things to everyone.
  • raspberry-pi
  • raspberry_pi_space
  • johnbeetem
    johnbeetem over 11 years ago +5
    Nice 'blog. How well does RasPi 2 surf the Internet? I found that to be intolerably slow on RasPi Model B w/ 256MB DRAM, but the quad Cortex-A7 w/ 1GB DRAM is probably up to the task. I wrote a poll on…
  • dbrems
    dbrems over 11 years ago +4
    Good Blog Entry, It's just missing the development part. Is it now possible to compile C and C++ program (really less than 10 hours for the complete Kernel compilation) on it and not rely only on cross…
    e14 Contributor over 11 years ago +3
    Excellent article. I too have adopted a Pi 2 as my home desktop, running the Xfce desktop environment on top of Raspbian. In general, it does an excellent job of a traditional desktop, just somewhat slower…
    e14 Contributor over 11 years ago in reply to clem57
    On the Pi? Bog standard Raspbian.
    Ragnar
  • clem57
    clem57 over 11 years ago in reply to e14 Contributor
    What distro is that?
    e14 Contributor over 11 years ago in reply to dbrems
    My complete kernel builds take between 65 and 75 minutes on a RPi2.
    It is actually slightly faster than my old kernel-building environment; crosscompiling on a VirtualBox'ed Lubuntu 14.04 on a 2.6GHz dual-core Windows host.
    Ragnar
  • clem57
    clem57 over 11 years ago in reply to bartonwood
    @bartonwood
    Sorry cannot say but see http://www.geekazine.com/guests/linux-hardinfo-hardware-information-utility/
  • bartonwood
    bartonwood over 11 years ago in reply to clem57
    Hi Clem,
    the Raytracing program you mention for benchmark testing: is it a true optical ray tracing program or one that is used for shading and highlights in image creation?
    If the former, is there a link to information about it?
    Regards and thanks in anticipation,
    John Barton Wood    (bartonwood)
  • clem57
    After apt-get install hardinfo:
    Benchmarks
    CPU Blowfish
    -CPU Blowfish-
    <big><b>This Machine</b></big> Unknown MHz 61.780
    Intel(R) Celeron(R) M processor         1.50GHz (null) 26.1876862
    PowerPC 740/750 (280.00MHz) (null) 172.816713
    CPU CryptoHash
    -CPU CryptoHash-
    <big><b>This Machine</b></big> Unknown MHz 15.434
    CPU Fibonacci
    -CPU Fibonacci-
    <big><b>This Machine</b></big> Unknown MHz 16.101
    Intel(R) Celeron(R) M processor         1.50GHz (null) 8.1375674
    PowerPC 740/750 (280.00MHz) (null) 58.07682
    CPU N-Queens
    -CPU N-Queens-
    <big><b>This Machine</b></big> Unknown MHz 51.896
    FPU FFT
    -FPU FFT-
    <big><b>This Machine</b></big> Unknown MHz 79.122
    FPU Raytracing
    -FPU Raytracing-
    <big><b>This Machine</b></big> Unknown MHz 75.121
    Intel(R) Celeron(R) M processor         1.50GHz (null) 40.8816714
    PowerPC 740/750 (280.00MHz) (null) 161.31264
         We can see the benchmark of Raspberry Pi 2 is between Intel Celeron M and PowerPC 740/750. I think this is very respectable. BTW, this benchmark runs on single core only!
    Cheers,
    Clem
    Fantastic gadget and nice article! Thank you!
  • johnbeetem
    johnbeetem over 11 years ago in reply to mikerman50
    Michael Robinson wrote:
    My appologies, I did not mean to hijack I was brought to this page by searching for keyword odroid
    Heavens, nobody cares about thread "hijacking" at element14!  Here the discussion goes whereëver it wants to, and the digressions are often the best part image
    It's at the ODROID Forum where they care so much about "thread purity".  It's probably just one admin who cares, but he cares a lot image
  • mikerman50
    mikerman50 over 11 years ago in reply to johnbeetem
  • johnbeetem
    I'm looking into getting the Odroid Xu3 Lite, seems to have the spec for alot of projects. The only thing that lacks is a larger community base.
    ODROID does indeed have a smaller community base, but my experience at the ODROID Forum is that they tend to be more knowledgeable than RasPi.  In its present form, ODROID is targeted more at serious developers than consumers who just want a cheap media box.  It helps if you use GNU/Linux on your main computer, since most of the advice posted uses GNU/Linux commands rather than Windows or Macs.
    I've found the ODROID forum to be quite helpful, and I've tried to contribute back my own experience when I think it might help others.  Moderators seem genuinely eager to help fix problems and make ODROID easier to use.  The main scolding I've seen is asking users to create their own issue threads rather than "hijacking" an existing thread.  This makes it easier to track issues.
    I've found that you have to be careful how you say things at the Raspberry Pi forum -- it's pretty easy to get banned there.
    JMO/YMMV
