Raspberry Pi
Raspberry Pi
Documents Quake 3 on the Raspberry Pi 2
  • Author Author: cstanton
  • Date Created: 26 Feb 2015 2:12 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 8:21 AM
  • Views 4240 views
  • Comments 11 comments
I've been a Quake 3: Arena gamer since it was released into open beta. Many, many point releases ago. When I learned that it had been ported to ARM for the Raspberry Pi it piqued my curiosity, and I am more of a purist when it comes to frame-rate.image
In the earlier days of gaming, frame rate truly mattered. These days the game tends to be locked to 30 or 60 frames per second. Quake 3: Arena, though, if you managed to hit the sweet spot of 125fps you had the gaming edge. People made jump height calculators to help. The new incarnation, Quake Live, kinda limits your frame rate as well and it is why Doom 3 limited their frame rate to 60fps (John Carmack's reasoning was probably 'why do you need more? this solves problems') but it made it less fun.
I ran Quake 3: Arena on the Raspberry Pi with the config attached to this post (as in, it's a Quake 3 config, so you put it in your baseq3 folder). So you can run it yourself with your build. I own a legitimate copy of the game, so I was able to use the original PK3 files. The time-demos were run on Class 10 Hama brand SD cards with clean installations of Raspbian from 31st of January.
The demo was loaded at the same time, and easily the Raspberry Pi 2 destroys the B+ in speed of loading and frame-rate. You can recreate the demo by opening the console and typing:
timedemo 1
With seeing the current framerate by:
cg_drawfps 1
And then just choose the demo you want to play from the Demo menu. So long as you have the relevant pk3/map files.
The B+ managed 39.6fps
The Pi2 managed 163.7fps
Oh and here's some bonus footage for those who're familiar with the jump for the megahealth on Q3DM13 (if you're not sure what I'm doing, searching for it or try it on your B+ image ):
q3config.cfg.zip
  • raspberry_pi_b+
  • raspi
  • quake_3
  • raspberry_pi_2
  • raspberry_pi_space
  • raspberrypi
  • quake_3_arena
    e14 Contributor over 11 years ago +2
    such a good game and a great little showcase nice one
  • cstanton
    cstanton over 11 years ago in reply to screamingtiger
    Yes, though some only have bots in them.
  • screamingtiger
    screamingtiger over 11 years ago
    Are there still multip player servers available to play online?
    This is awesome. One of my favourite game when it was first released. For sure I will try this out once I receive my order.. image
  • marcelodantas
    marcelodantas over 11 years ago
    Very nice ... can't wait to get my hands onto a Pi 2.
    Simply amazing just how much faster it runs image
  • cygnusx1
    cygnusx1 over 11 years ago
    I love Quake! I can't wait to try it out on the PI 2! Just for grins.
    e14 Contributor over 11 years ago in reply to cstanton
    Holy hell that's impressive. Maybe I should take one to my next LAN meet!
  • cstanton
    cstanton over 11 years ago in reply to e14 Contributor
    On the Pi 2 it was 125fps, if I changed com_maxfps to 999 then it ranged from 125 to 250 most times, to higher.
    On the B+ it was about 30fps+
    What was your lowest FPS?  image
    Eu adoro Quake III! Vai ser muito divertido joga-lo na TV da sala!
    I love Quake III! I will have some fun playing on my LED TV!
    Congrats!
