Raspberry Pi
Raspberry Pi
Documents Is the Raspberry Pi Vulnerable to the Spectre or Meltdown exploit?
  • Author Author: e14phil
  • Date Created: 5 Jan 2018 3:00 PM Date Created
  • Last Updated Last Updated: 9 Jan 2018 11:05 AM
  • Views 1717 views
  • Likes 12 likes
On January 3rd 2018 a loose group of Jann Horn, Paul Kocher, Daniel Genkin, Mike Hamburg, Moritz Lipp and Yuval Yarom came together to make
the public aware of, what seems to be, one of the most serious computer security vulnerability to date.  These vulnerabilities, named "Spectre" and "Meltdown",  allow programs access to any data in any location on the device, even areas which the operating environment specifically would block programs from accessing.
The reason this vulnerability is seen as so serious is because it is at processor level, which makes it hard to patch.
This vulnerability effects all Apple iPhones, iPad, or Macbooks, most Intel processors and by extension some Arm Cortex processors.
As some Arm processors are used in, ALL Raspberry Pi, are the Arm Processors in the Raspberry Pi Vulnerable to the Spectre or Meltdown exploit?
I will save you the Click Bait...
Short answer is NO,
None of the Variants of the Raspberry Pi. (as of 5th January 2018) are vulnerable to Spectre or Meltdown exploit.
According to Arm directly:
https://developer.arm.com/support/security-update
The processor used by the Raspberry Pi are:
Raspberry Pi 1 and Zero (W): ARM11
Raspberry Pi 2 V1: ARM Cortex-A7
Raspberry Pi 2 V1.2 ARM Cortex-A53
Raspberry Pi 3:    ARM Cortex-A53
The good news for Raspberry Pi users is that these are NOT on Arm's Definitive list of vulnerable processors:
Vulnerable Processors:
Processor
Variant 1
Variant 2
Variant 3
Variant 3a
Cortex-R7
Yes*
Yes*
No
No
Cortex-R8
Yes*
Yes*
No
No
Cortex-A8
Yes (under review)
Yes
No
No
Cortex-A9
Yes
Yes
No
No
Cortex-A15
Yes (under review)
Yes
No
Yes
Cortex-A17
Yes
Yes
No
No
Cortex-A57
Yes
Yes
No
Yes
Cortex-A72
Yes
Yes
No
Yes
Cortex-A73
Yes
Yes
No
No
Cortex-A75
Yes
Yes
Yes
No
* Note for Cortex-R cores: The common usage model for Cortex-R is in non-open environments where applications or processes are strictly controlled and hence not exploitable.
*Source https://developer.arm.com/support/security-update
I hope this slice of good news helps one of you concerns......   Unlike all Apple iPhones, iPad, or Macbooks,  which are all vulnerable.
Please make sure you do not put off security updates!
More info: https://support.apple.com/en-us/HT208394
-e14Phil
  • meltdown
  • spectre
  • raspberry pi
  • cyber security
  • arm
    beacon_dave over 8 years ago +3
    There is some related reading material published here on the Raspberry Pi blog which may be of some interest: https://www.raspberrypi.org/blog/why-raspberry-pi-isnt-vulnerable-to-spectre-or-meltdown/
    mcb1 over 8 years ago +2
    e14phil I'm surprised at the number of chips that have a vunerability. The news item I watched suggested Intel chips, and I was thankful I tended to use AMD processors. However it appears that isn't the…
    mcb1 over 8 years ago in reply to shabaz +1
    shabaz Maybe harder for Apple who have very few models of phones released each year. Naah they'll be fine since it's older hardware Apple's apple will make it run slower, so the exploit will be slowed…
    e14phil
    However it appears that isn't the whole story.
    Variants of this issue are known to affect many modern processors, including certain processors by Intel, AMD and ARM.
    SO it looks like some digging is required for some patches.
    Thanks for sharing this
    From the ARM link Phil provided :-
    https://developer.arm.com/support/security-update/download-the-whitepaper
    https://googleprojectzero.blogspot.co.nz/
    https://spectreattack.com/spectre.pdf
    https://meltdownattack.com/meltdown.pdf
    shabaz
    Naah they'll be fine since it's older hardware Apple's apple will make it run slower, so the exploit will be slowed right down image
    It just shows that despite updating the OS, it all comes down to stuff inside a chip that provides the venerability.
    shabaz over 8 years ago
    Hi Phil,
    Thanks for this table - nice summary!! I suspect some manufacturers will now diversify and start using different architectures across their ranges, just to reduce risk exposure for future vulnerabilities/bugs/flaws.
