Raspberry Pi
Raspberry Pi
Documents Raspberry Pi Sense HAT
  • Author Author: joeman
  • Date Created: 11 Aug 2015 6:53 PM Date Created
  • Last Updated Last Updated: 10 May 2021 8:51 PM
  • Views 6125 views
  • Likes 13 likes
  • Comments 7 comments
Official Sense HAT from the Raspberry Pi Foundation.
Buy NowBuy NowSee other Pi Accessories  image
Technical Specification:
image  Official Sense HAT from the Raspberry Pi Foundation
image  8x8 LED matrix display
image  Accelerometer, gyroscope and magnetometer
image  Air pressure sensor
image  Temperature and humidity sensor
image  Small joystick
Compatible With:
Raspberry Pi 3 Model B
Raspberry Pi 2 Model B
Raspberry Pi Model B+
Raspberry Pi Model A+
*To mount the Sense HAT securely it is advisable to use a set of standoffs and mounting screws
Projects/Applications:
image Pi IoT Global Design Challenge
See the Sense HAT projects in action as part of this 2016 Global Design Challenge. Find out more here >
image  ASTRO PI
The Raspberry Pi Sense HAT was used in conjunction with the Raspberry Pi Foundation during the 186-day Principia mission by Major Timothy Nigel "Tim" Peake CMG, a British Army Air Corps officer, European Space Agency astronaut and a former International Space Station crew member to perform science experiments aboard the International Space Station (ISS), 2016.
http://astro-pi.org/
https://www.raspberrypi.org/competitions/astro-pi/
  • raspberry
  • sense
  • the
  • from
  • pi
  • official
  • raspberry_pi
  • hat
  • foundation
    shabaz over 6 years ago in reply to keiichicom
    Hi Andrew,
    I've not tried it on a Pi 4, but I believe it does work (at least, I see no reason why it wouldn't work).
  • keiichicom
    keiichicom over 6 years ago
    Hi,
    If the proper connections are made can it be used with the RPI4?
  • hackiderspecht
    hackiderspecht over 9 years ago in reply to marksteele
    The Name is the Game!
  • scitechindian
    scitechindian over 10 years ago
    wow awesome
  • davidmoss1701@gmail.com
    davidmoss1701@gmail.com over 10 years ago
    Just tried to go to the raspberrypi site, and got a 404 error message!  Is this being worked on?
    Thanks
  • clem57
    clem57 over 10 years ago in reply to marksteele
    marksteele
    Do you need help? Post code and tell more about the messages you get.
    Clem
  • marksteele
    marksteele over 10 years ago
    Coding for the sensehat is a pain in the ass for sure!  Miss on little thing in Python and you're done. Project caput!
    But... I guess that's the name of the game huh?
    I'm just pissed 'cause I'm having trouble with a certain project.  Whatever.... I'll get it!
    Mark "Tattoo" Steele
