Raspberry Pi
Raspberry Pi
Documents Raspberry Pi 7” Touchscreen Display
  • Author Author: joeman
  • Date Created: 11 Aug 2015 6:55 PM Date Created
  • Last Updated Last Updated: 16 May 2022 10:17 AM
  • Views 116465 views
  • Likes 20 likes
  • Comments 478 comments
Buy Here  Display Installation Guide
Install Virtual Keyboard* Other Pi Accessories  image
The 7” Touchscreen Monitor for Raspberry Pi gives users the ability to create all-in-one, integrated projects such as tablets, infotainment systems and embedded projects. The 800 x 480 display connects via an adapter board which handles power and signal conversion. Only two connections to the Pi are required; power from the Pi’s GPIO port and a ribbon cable that connects to the DSI port present on all Raspberry Pi’s.  Touchscreen drivers with support for 10-finger touch and an on-screen keyboard will be integrated into the latest Raspbian OS for full functionality without the need for a physical keyboard or mouse.
*Note: Your NEW Rasp Pi 7.0 needs you to Add a Virtual Keyboard….
Raspberry Pi Sense HAT
Learn More  image
Technical Specification:
image  7” Touchscreen Display
image  Screen Dimensions: 194mm x 110mm x 20mm (including standoffs)
image  Viewable screen size: 155mm x 86mm
image  Screen Resolution 800 x 480 pixels
image  10 finger capacitive touch
image  Connects to the Raspberry Pi board using a ribbon cable connected to the DSI port
image  Adapter board is used to power the display and convert the parallel signals from the display to the serial (DSI) port on the Raspberry Pi
image  Will require the latest version of Raspbian OS to operate correctly
Features and Benefits
image  Turn your Raspberry Pi into a touch screen tablet, infotainment system, or standalone device.
image  Truly Interactive - the latest software drivers will support a virtual ‘on screen’ keyboard, so there is no need to plug in a keyboard and mouse.
image  Make your own ‘Internet of Things’ (IoT) devices including a visual display. Simply connect your Raspberry Pi, develop a Python script to interact with the display, and you’re ready to create your own home automation devices with touch screen capability.
image  A range of educational software and programs available on the Raspberry Pi will be touch enabled, making learning and programming easier on the Raspberry Pi.
Kit Contents
image  Adapter Board
image  DSI Ribbon cable
image  4 x stand-offs and screws (used to mount the adapter board and Raspberry Pi board to the back of the display
image  4 x jumper wires (used to connect the power from the Adapter Board and the GPIO pins on the Pi so the 2Amp power is shared across both units)
NOTE: THE RASPBERRY PI AND POWER SUPPLY ARE NOT INCLUDED IN THIS KIT AND ARE SOLD SEPARATELY.
Compatible With:
Raspberry Pi 3 Model B
Raspberry Pi 2 Model B
Raspberry Pi Model B+
Raspberry Pi Model A+
The display will technically work with the Model A and Model B boards (connecting it to the DSI port on the Pi board), however the mounting holes on the back of the display will only line up with the newer board design (A+, B+, Pi 2 and Pi 3).
How to Install the Matchbox-Keyboard for your Pi
1. Connect a physical keyboard to the Raspberry Pi (or SSH into it if that’s your thing.)
2. Connect to the internet via WiFi or Ethernet.
3. Open the terminal.
4. Type sudo apt-get install matchbox-keyboard
5. Let the program download & install (takes 30s-1min depending on your connection.)
6. Exit the terminal & reboot your Pi.
7. The keyboard can be found by clicking the Menu -> Accessories -> Keyboard.
Operating System Support
In order to be sure you’re running the latest version of Raspbian, connect your Raspberry Pi to the Internet and then open LX Terminal.  Type ‘sudo apt-get update’ to download the latest version of the OS.  Once that’s complete, type ‘sudo apt-get upgrade’ to apply the download to your Raspberry Pi.  That way you’ll have all of the latest drivers and software needed to support the touch screen display.
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
  • pi_guide
  • raspberry
  • pi
  • pi_display
  • raspberry_pi
  • matchbox_keyboard
  • display
  • touchscreen
  • 7”
  • guide
  • installation
  • 7_inches
    shabaz over 9 years ago in reply to idometeor +3
    Jason Does Meteor wrote: As mentioned, I tried that. Actually you didn't, you stated: I have tried everything and I cannot get the display to rotate in Raspbian. I have written many X configuration files…
  • softweyr
    softweyr over 11 years ago in reply to ejohnfel +2
    Yeah, this is not a bad price for a 7" display, plus you get the touchscreen, integrated keyboard, etc. And tomorrow is my birthday!
  • bwelsby
    bwelsby over 11 years ago in reply to phantomski +2
    The reduced screen size is because Overscan settings are enabled. you can either comment out the settings in /boot/config.txt or just run raspi-config and select the advanced options then Overscan , Disable…
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago in reply to e14 Contributor
    Not yet, technically it may be but not yet supported
    balearicdynamics over 10 years ago in reply to gabaryza
    Not necessarily, Gregoy, the signals - I bet including obviously the logic ground are in the flat connector - The fact that the LCD can be powered through the PI is an option but you can also power it independently through the same two wires or through the USB power connector on the LCD controller board. So, IMHO you can disconnect both the black and red cables and leave the pi and the lcd connected logically through the flat connector. If things are different, I guess it is an error, but frankly I exclude.
    A fact is that in the worst case you get nothing but sure you don't risk to broke anything.
    Enrico
  • gabaryza
    gabaryza over 10 years ago
    I'm a long-time software but newbie hardware guy.  If I decide to power the RPi and the screen separately as the instructions say, I believe I should disconnect the red wire carrying power from the Pi to the screen but keep the black (ground) wire.  Is this correct?
    I really need help regarding the resolution of my official Rasp pi display. It is connected to DSI ports. I have installed raspbian but in that the setting is only available for HDMI peripheral. Even the touchscreen calibration is messed. Please suggest that how can i change the resolution on my touchscreen connected to DSI ports
    Awesome. Bought my first raspberry pi last week. Bought one of these displays and had it setup and working in minutes. Awesome display.
    So, how do I get this screen to work on other OSes that Raspian?
    Do I need to install additional software or drivers?
    Is it possible to change the orientation of the screen ?
  • clem57
    clem57 over 10 years ago in reply to e14 Contributor
    Please open a "new" question sir. Thank You.
    Has anyone been able to setup right click by touch-and-hold with this display on rPi3 running Jessy?
  • Matt
    Matt over 10 years ago
    It was good to see this screen featured on Know How epsisode 194... they show you how to put it all together.
    https://www.youtube.com/watch?v=dkSMgwKjcM0&feature=youtu.be&t=44m23s
