Raspberry Pi
Raspberry Pi
Documents Raspberry Pi 7” Touchscreen Display
  • Author Author: joeman
  • Date Created: 11 Aug 2015 6:55 PM Date Created
  • Last Updated Last Updated: 16 May 2022 10:17 AM
  • Views 116541 views
  • Likes 20 likes
  • Comments 478 comments
Buy Here  Display Installation Guide
Install Virtual Keyboard* Other Pi Accessories  image
The 7” Touchscreen Monitor for Raspberry Pi gives users the ability to create all-in-one, integrated projects such as tablets, infotainment systems and embedded projects. The 800 x 480 display connects via an adapter board which handles power and signal conversion. Only two connections to the Pi are required; power from the Pi’s GPIO port and a ribbon cable that connects to the DSI port present on all Raspberry Pi’s.  Touchscreen drivers with support for 10-finger touch and an on-screen keyboard will be integrated into the latest Raspbian OS for full functionality without the need for a physical keyboard or mouse.
*Note: Your NEW Rasp Pi 7.0 needs you to Add a Virtual Keyboard….
Raspberry Pi Sense HAT
Learn More  image
Technical Specification:
image  7” Touchscreen Display
image  Screen Dimensions: 194mm x 110mm x 20mm (including standoffs)
image  Viewable screen size: 155mm x 86mm
image  Screen Resolution 800 x 480 pixels
image  10 finger capacitive touch
image  Connects to the Raspberry Pi board using a ribbon cable connected to the DSI port
image  Adapter board is used to power the display and convert the parallel signals from the display to the serial (DSI) port on the Raspberry Pi
image  Will require the latest version of Raspbian OS to operate correctly
Features and Benefits
image  Turn your Raspberry Pi into a touch screen tablet, infotainment system, or standalone device.
image  Truly Interactive - the latest software drivers will support a virtual ‘on screen’ keyboard, so there is no need to plug in a keyboard and mouse.
image  Make your own ‘Internet of Things’ (IoT) devices including a visual display. Simply connect your Raspberry Pi, develop a Python script to interact with the display, and you’re ready to create your own home automation devices with touch screen capability.
image  A range of educational software and programs available on the Raspberry Pi will be touch enabled, making learning and programming easier on the Raspberry Pi.
Kit Contents
image  Adapter Board
image  DSI Ribbon cable
image  4 x stand-offs and screws (used to mount the adapter board and Raspberry Pi board to the back of the display
image  4 x jumper wires (used to connect the power from the Adapter Board and the GPIO pins on the Pi so the 2Amp power is shared across both units)
NOTE: THE RASPBERRY PI AND POWER SUPPLY ARE NOT INCLUDED IN THIS KIT AND ARE SOLD SEPARATELY.
Compatible With:
Raspberry Pi 3 Model B
Raspberry Pi 2 Model B
Raspberry Pi Model B+
Raspberry Pi Model A+
The display will technically work with the Model A and Model B boards (connecting it to the DSI port on the Pi board), however the mounting holes on the back of the display will only line up with the newer board design (A+, B+, Pi 2 and Pi 3).
How to Install the Matchbox-Keyboard for your Pi
1. Connect a physical keyboard to the Raspberry Pi (or SSH into it if that’s your thing.)
2. Connect to the internet via WiFi or Ethernet.
3. Open the terminal.
4. Type sudo apt-get install matchbox-keyboard
5. Let the program download & install (takes 30s-1min depending on your connection.)
6. Exit the terminal & reboot your Pi.
7. The keyboard can be found by clicking the Menu -> Accessories -> Keyboard.
Operating System Support
In order to be sure you’re running the latest version of Raspbian, connect your Raspberry Pi to the Internet and then open LX Terminal.  Type ‘sudo apt-get update’ to download the latest version of the OS.  Once that’s complete, type ‘sudo apt-get upgrade’ to apply the download to your Raspberry Pi.  That way you’ll have all of the latest drivers and software needed to support the touch screen display.
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
  • pi_guide
  • raspberry
  • pi
  • pi_display
  • raspberry_pi
  • matchbox_keyboard
  • display
  • touchscreen
  • 7”
  • guide
  • installation
  • 7_inches
    shabaz over 9 years ago in reply to idometeor +3
    Jason Does Meteor wrote: As mentioned, I tried that. Actually you didn't, you stated: I have tried everything and I cannot get the display to rotate in Raspbian. I have written many X configuration files…
  • softweyr
    softweyr over 11 years ago in reply to ejohnfel +2
    Yeah, this is not a bad price for a 7" display, plus you get the touchscreen, integrated keyboard, etc. And tomorrow is my birthday!
  • bwelsby
    bwelsby over 11 years ago in reply to phantomski +2
    The reduced screen size is because Overscan settings are enabled. you can either comment out the settings in /boot/config.txt or just run raspi-config and select the advanced options then Overscan , Disable…
  • gadget.iom
    gadget.iom over 11 years ago in reply to jack.chaney56
    https://www.youtube.com/watch?v=c3y0CD2CoCs
  • jack.chaney56
    jack.chaney56 over 11 years ago in reply to amk182
    Hi, sorry for me being a bit OCD here. Use of the word "do" should be "due" like "payment is due", not "do I look good in this?" Mind, spell checkers are my salvation, because I am a bit dyslexic, but correct grammar and word usage is essential for proper communication. (as is syntax for programming).  Please don't take offense, and ignore if necessary.
    Cheers, Jack.
    shabaz over 11 years ago in reply to josepvg@gmail.com
    Hi Jósep,
    That section you have illustrated is definitely not replaceable I'm afraid. It is integral to the LCD, and the whole LCD would need replacing.
    The LCD on its own is not available, so you'd need to obtain an entire new LCD and control board.
  • claudegel
    claudegel over 11 years ago
    Very nice touch screen. Is there a back cover to include all the wire so it can be handled easy. I want to add a cellphone battery pack to be able to walk out with my Pi
  • amk182
    amk182 over 11 years ago in reply to josepvg@gmail.com
    do to my search I have to say no but the company which you purchased the screen from may replace it
  • josepvg@gmail.com
    josepvg@gmail.com over 11 years ago
    Hi, I love the display but unfortunately I managed to ruin the flat cable between the control board and the display. Is it possible to purchase it seperately? It would be sad to have to purchase a whole new unit.
  • amk182
    amk182 over 11 years ago in reply to dhunjoshi
    if I may suggest, if you have a multi-meter use it to check the power and voltage output to the screen because it may not working properly do to under-voltage or over-load
    list to check
    amp input
    volt input
    amp output
    volt output
    because I've found some screen's have a bad voltage and amp handling. Some time the board to the display just is bad even on new display.
  • dhunjoshi
    dhunjoshi over 11 years ago
    Hello
    I got blank screen on 7" display when power up raspberry pi2.
    i have upgrade the raspberry pi
    kindly help
    balearicdynamics over 11 years ago in reply to lynguthre@aol.com
    Just a question, Lynn, did you checked the very first two connectors that should be plugged in the board before wiring it on the back of the LCD ?
    Sorry if I bore you but it is just to avoid any possible issue.
    Enrico
  • lynguthre@aol.com
    lynguthre@aol.com over 11 years ago
    I am still having trouble.  I have followed the procedures above and have swapped and rotated the cables linking the adapter to the RPi.  Everything seems fine except the display is dead.  I measured the voltage going into the RPi with input to the adapter and it measures 5.1 volts.  the lights on the RPi seem normal.  I tried a second memory loaded with NOOBS (which I checked out with the RPi, independent of the adapter/display) and got same results.  The other flat cables connecting the adapter to the display seem normal, no apparent damage.  At this point I don't feel pictures would do much good, especially with all of the good documentations that you have provided.  I still want and need the display, so I would appreciate any suggestions that you might have.
    Lynnng
