RoadTests & Reviews
RoadTests & Reviews
Review Blogs LED Road Test - Making a ring light - Blog 8 - Jan 16
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: gpolder
  • Date Created: 16 Jan 2016 9:39 PM Date Created
  • Views 793 views
  • heatsink
  • led_ring
  • ledroadtestplus
  • ring_light
  • dremel
gpolder
gpolder
16 Jan 2016
Previous Posts:
TI and Würth Elektronik LED RoadTest+ application and un-boxing - Blog 1 - Nov 10
LED Road Test - Software issues - Blog 2 - Nov 26
LED Road Test - LED PCB issues - Blog 3 - Dec 5
LED Road Test - Some words on timing - Blog 4 - Dec 15
LED Road Test - Launchpad user interface - Blog 5 - Dec 19
LED Road Test - Solder the LEDs - Blog 6 - Dec 28
LED Road Test - Deadline approaching - Blog 7 - Jan 15
Related links:
search for a PCB for Würth power leds
LED_RoadTest_Unboxing
LED_RoadTest_Soldering
LED testing
flashcontroller screen-recording
Making a ring light
Today I made a aluminium ring serving as heatsink for the ring light.
As I had to do it by hand, using only a hacksaw, dril and Dremel, I'v choosen to quick and dirty make a octagon shaped plate.
To be honest in the end it was more dirty than quick image.
First I calculated:
and drew the shape on a piece of 2mm thick aluminium plate:
Then using hacksaw and Dremel, I cut it out:
Finally I drilled the  holes for mounting the LED's and mounted them:
Thats it for now, next step, soldering and testing with the TPS9251 hopefully on Monday.
stay tuned.
    DAB over 10 years ago +1
    The plate should make a good heat sink. DAB
