RoadTests & Reviews
RoadTests & Reviews
Review Blogs LEDRoadTestPlus - Post 1
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: amgalbu
  • Date Created: 17 Nov 2015 4:21 AM Date Created
  • Views 847 views
  • lighting
  • ledroadtestplus
  • würth
  • texas_instruments
  • wurth_electronic
amgalbu
amgalbu
17 Nov 2015
The project I want to build during this roadtest is a Visible Light Communication (VLC) system between a LED driven by the TPS92512 board and an Android smartphone
The idea behind VLC is very simple: light bulbs are pervasive, have ample access to power, and are often ideally positioned for sensing applications. So, why not transform lighting sources into landmark beacons that can be used, for example, for indoor localization? If each light bulb could uniquely identify itself to nearby mobile devices, it would be possible to localize the mobile devices in all the areas that are not reached by the GPS signal.
For this roadtest, I will build a VLC transmitter based on the TI LaunchPad and the TPS92512 evaluation board
The steps of the project will be as follow
  1. Introduction of the TPS92512 board
  2. Development of the application to drive LED
  3. Development of the Android app
By the way, since it’s tradition in roadtests to take pictures of the unwrapping the kit, here is some pictures of the unboxing ceremony
The content of the kit
The MSP430 Launchpad. The layout, the LCD display and the switch buttons make this board really flexible: I already have tons of projects where such a small, low-power board suits perfectly
Here is the TPS92512EVM board
And finally here are the BLE-enabled LEDs
    e14 Contributor over 11 years ago +1
    Thank your for the share.
  • amgalbu
    amgalbu over 11 years ago in reply to DAB
    For the moment, just to experiment and send a byte.... that would be a great result
    Cheers
    Ambrogio
    DAB over 11 years ago
    What are your objectives with the light communication implementation?
