RoadTests & Reviews
RoadTests & Reviews
Review Blogs Need Some Help: Adapting 2-pin Mil-C5015 to BNC plug
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: rscasny
  • Date Created: 11 Dec 2021 9:43 PM Date Created
  • Views 3942 views
rscasny
rscasny
11 Dec 2021
Hi All,
I was wondering if someone could provide me some help.
I will be launching a roadtest in January on an IEPE Measurement DAQ HAT for Raspberry Pi®.
The roadtest kit comes with a board and two cables (10-32 plug to BNC jack)
image image
I will be using this sensor, which has a 2-pin (Mil-C-5015) 5/8-24 UNEF-2A connector
Here's the product information: description and drawing.
I'm trying to find the easiest way to connect the sensor to the cable.
I found a Mil 5015 to BNC jack adapter:
But I need a BNC plug.
Can anyone provide me suggestions on the best way to do this?
Thanks.
Randall
  • Gough Lui
    Gough Lui over 4 years ago +1
    You could just use the same adapter that you had found and throw in a regular BNC-BNC cable. That would be very straightforward and inexpensive.
  • jc2048
    jc2048 over 4 years ago in reply to Gough Lui +1
    Or, instead of the cable, a BNC-plug to BNC-plug adaptor like this https://uk.farnell.com/amphenol-rf/031-218-rfx/rf-adapter-bnc-plug-plug-50-ohm/dp/3757652
  • rscasny
    rscasny over 4 years ago
    Thanks 4everybody. Looks like I have two options.
    Randall
  • jc2048
  • Gough Lui
  • geralds
    geralds over 4 years ago
    Hi Randall,
    What I found are this original adapter cables on the German website (I'm sure you can find it as well in your country):
     Datenblatt - PCB Synotech GmbH
    2 pol connector straight, shielded cable, 3m long, to a BNC plug:
    https://www.synotech.de/produkte/datenblatt/?untergruppe=zub_kabel_ind&h=PCB&m=052BR010AC
    2 pol connector right angle, shielded cable, 3m, with open end:
    https://www.synotech.de/produkte/datenblatt/?untergruppe=zub_kabel_ind&h=PCB&m=052BQ010BZ
    2 pol connector straight, shielded cable, 3m, with open end:
    https://www.synotech.de/produkte/datenblatt/?untergruppe=zub_kabel_ind&h=PCB&m=052BR010BZ
    With this you can easily make your adapter cable.
    Best Regards
    Gerald
