RoadTests & Reviews
RoadTests & Reviews
Review Blogs PYNQ-Z2 Dev Kit - CIFAR-10 Webcam revisited....
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: ralphjy
  • Date Created: 15 Aug 2019 10:41 PM Date Created
  • Views 765 views
  • RoadTest
  • pynqworkshpch
  • pynq-z2
  • cifar10
  • machine learning
ralphjy
ralphjy
15 Aug 2019
After my previous blog post it was pointed out to me that the amount of whitespace (or other non-object pixels, i.e. background) that I had in my captured image was affecting the accuracy of the classification.  I did a quick inverse test that was suggested by beacon_dave and added whitespace around the CIFAR-10 test image and it then classified as an airplane!  I guess this makes sense as there are a lot of extraneous pixels to confuse the classifier.  In general purpose use of a camera or other image source, the object to be classified would be normally identified and enclosed in a tight bounding box and only the pixels in the box would be used to classify the object.  For this example notebook that step was left out.  I think the assumption was that you could create that bounding box by zooming in on the object (which I not sure how to do with my webcam).  So, I tried the next best thing and repeated the test using cropped images from the webcam.  And that produced more satisfactory results.  Using neural networks and training them correctly is indeed a challenging task.
CIFAR-10 Sportscar test image with added whitespace
Webcam Firetruck cropped image
Webcam Sportscar cropped image
