RoadTests & Reviews
RoadTests & Reviews
Review Blogs PYNQ-Z2 Dev Kit - Xilinx/PYNQ_Workshop Introduction
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: ralphjy
  • Date Created: 26 Jun 2019 4:53 AM Date Created
  • Views 2198 views
  • RoadTest
  • pynq-z2
ralphjy
ralphjy
26 Jun 2019
My end objective for this roadtest is to implement a binary neural network (BNN) for image classification on the PYNQ-Z2.  I'll need to learn the board hardware and the development framework first.  There are a lot of tutorial videos on YouTube, but I found a Xilinx 1-day, hands-on workshop on GitHub that seems to be just what I need.  It uses some Pmod and Grove peripherals that I don't have, but they will be well worth the cost if I can get them quickly.  I'll blog about my experience as I go through the roadtest.
Here is the workshop link: https://github.com/Xilinx/PYNQ_Workshop
I am also a newbie relative to Jupyter notebooks and I found a very useful overview that explained the basics: https://realpython.com/jupyter-notebook-introduction/#getting-up-and-running-with-jupyter-notebook
PYNQ Tutorial Workshop
Goals
Introduction to the PYNQ project
  • Pynq framework
  • PYNQ-Z2 board
  • Jupyter Notebook Interface
  • Overlays and Hardware designs
  • Designing overlays
Hands on experience with Jupyter Notebook and the board
Agenda
  • Introduction to PYNQ
Session 1
  • First steps with PYNQ (presentation)
Configure board, SD card
Connect to the board
Labs:
  • Getting started with Jupyter Notebooks (notebook)
  • Getting started with IPython (notebook)
  • Exploring the board (notebook)
  • Programming on board peripherals (notebook)
Session 2
  • Introduction to overlays (presentation)
Lab
  • Grove temperature sensor example (notebook)
  • Pmod OLED example (notebook)
  • Grove LED bar example (notebook)
  • Grove light sensor example (notebook)
Session 3
  • Pynq IOPs (presentation)
  • logictools overlay (presentation)
Labs:
  • Wavedrom tutorial (notebook)
  • Logictools Boolean generator (notebook)
  • Logictools Boolean generator demo (notebook)
  • Logictools pattern generator (notebook)
  • Logictools FSM generator (notebook)
  • MicroBlaze programming (notebook)
Session 4
  • Overlay design methodology (presentation)
Labs:
  • PYNQ tutorial on PS GPIO (notebook)
  • PYNQ tutorial on AXI GPIO (notebook)
  • PYNQ tutorial on MMIO (notebook)
  • PYNQ tutorial on XInk (notebook)
  • PYNQ tutorial on XInk with PL master (notebook)
  • PYNQ tutorial on DMA example (notebook)
  • Putting it all together: Resize example (notebook)
Additional hardware required for Labs in Session 2:
The ZYNQ-Z2 has two Pmod connectors to add external peripherals.  One will be used for an OLED display and the second will be used with a Grove adapter to interface to the Grove peripherals.
  1. Grove I2C ADC, use with tempemperature sensor and light sensor
  2. Grove temperature sensor v1.2 (thermistor)
  3. Grove light sensor v1.1 (LDR)
  4. Grove LEDbar v2.0 10 LEDs (7 Green, 1 Light Green, 1 Yellow, 1 Red), uses MY9221 controller
  5. Pmod OLED 128 x 32 pixels monochrome, uses SSD1306 controller
  6. Pmod Grove adapter with 4 Grove sockets
  • ralphjy
    ralphjy over 7 years ago in reply to genebren +2
    Thanks Gene. The interesting thing about the PYNQ-Z2 is that it has connectors for Raspberry Pi, Arduino Uno, and Pmod IO. The FPGA can be programmed to emulate all those interfaces. It will be fun trying…
    genebren over 7 years ago +1
    Best of luck with your workshop and eventual project/roadtest review. It is nice when you can find a useful learning source for a new project/environment. I hope that this one turns out to be worth your…
    genebren over 7 years ago in reply to ralphjy
    Ralph,
    That is pretty cool that you can interface this to RPi and Aduino Uno so easily.  And the Pmod IO is nice too (I have some older Xlinx eval boards that also use the Pmod IO).
    Enjoy all of the possibilities!
    Gene
  • ralphjy
    Thanks Gene.
    The interesting thing about the PYNQ-Z2 is that it has connectors for Raspberry Pi, Arduino Uno, and Pmod IO.  The FPGA can be programmed to emulate all those interfaces.  It will be fun trying all that out.  Grove modules can plug in using a Digilent Pmod adapter board and I have a RPi microBUS Hat that I can use for Click modules.
    Ralph
    Best of luck with your workshop and eventual project/roadtest review.  It is nice when you can find a useful learning source for a new project/environment.  I hope that this one turns out to be worth your time and effort.
    Gene
