RoadTests & Reviews
RoadTests & Reviews
Review Blogs RASPBEERYPI2 ---- BARE METAL WITHOUT(OS) ---HDMI OUTPUT --- RGB 565 FORMAT
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: neerajrd82
  • Date Created: 26 Nov 2022 5:43 AM Date Created
  • Views 1054 views
neerajrd82
neerajrd82
26 Nov 2022
This is video HDMI output at 1920x1080 (full HD) @ 60 fps from RASPBERRY PI2 programmed just like any good & high speed ARM based microcontroller without any OS. This means there is no OS inside board.This demonstration also shows all 4 cores of SoC switched "ON" using Embedded C/assembly language;types of clutter in percentage:LAND,SEA,AIR etc;range & bearing of target being hooked up for Track while scan; Gyroscope heading in degrees. There is dummy RADAR PPI display without any target(s). For showing target(s) cost commitment is required. Please! see the video below:
https://www.youtube.com/watch?v=mg9AgnSQ9NE
This Raspberry Pi 2 was purchased by me in 2015 to do Roadtest on bare metal programming. It was found that DSP inside BroadCom SoC BCM2836 was very accurate in computing Maclaurin Expansion of sin(x) & cos(x) series due to this i was able to rotate the beam & also compute polar co-ordinates. This was done to demonstrate the capability of developing multi-functional displays for mission critical applications.
I used in work in Pipavav defense & offshore engineering company in 2015 when it was largest defense manufacturing company & shipyard in India.
I m promoter of "MADE IN INDIA" instead of "MAKE IN INDIA". Reason: "MADE IN INDIA" means "DESIGN & MANUFACTURED IN INDIA" otherwise "MAKE IN INDIA" means "DESIGN SOMEWHERE ELSE BUT MANUFACTURED IN INDIA".
Good comments & suggestions are always welcome.
    dougw over 4 years ago
    Neat demo.
