RoadTests & Reviews
RoadTests & Reviews
Review Blogs Raspberry Pi CM5 roadtest - flashing the operating system
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: gpolder
  • Date Created: 5 Sep 2026 8:29 AM Date Created
  • Views 834 views
  • Comments 6 comments
gpolder
gpolder
5 Sep 2026
Flashing an operating-system image to the Compute Module 5 is slightly different from what you may be used to with a traditional Raspberry Pi. With a regular Raspberry Pi, the usual procedure is to write Raspberry Pi OS to a microSD card using Raspberry Pi Imager, insert the card into the Pi, and boot. The CM5, however, does not have a microSD card slot. The operating system is installed on the module's onboard eMMC storage instead.
To do this, the CM5 is connected to a computer through the USB interface on the IO board and placed into USB boot mode. The host computer can then detect the CM5 storage, allowing Raspberry Pi Imager to write the selected operating-system image directly to it. This extra step makes the first installation a little less straightforward than with a conventional Raspberry Pi, but once the CM5 is set up, the boot process is essentially the same as you would expect from a Raspberry Pi.
Installing the tools on the host computer
For the host computer, I decided to use my Raspberry Pi 400. The tool required to flash the CM5 over USB is rpiboot. According to the official documentation, rpiboot can be installed using apt:
me@raspberrypi:~ $ sudo apt install rpiboot
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following NEW packages will be installed:
  rpiboot
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 76.7 MB of archives.
After this operation, 108 MB of additional disk space will be used.
Get:1 http://archive.raspberrypi.org/debian bullseye/main armhf rpiboot armhf 20221215~105525 [76.7 MB]
Fetched 76.7 MB in 26s (2,934 kB/s)
Selecting previously unselected package rpiboot.
(Reading database ... 174846 files and directories currently installed.)
Preparing to unpack .../rpiboot_20221215~105525_armhf.deb ...
Unpacking rpiboot (20221215~105525) ...
Setting up rpiboot (20221215~105525) ...
me@raspberrypi:~ $
Flashing
Next, a jumper needs to be placed on J2 on the IO board. This disables eMMC boot mode and allows the eMMC to be accessed and written to over USB. No jumper was included with the kit, but luckily I have a well-stocked junk box, so finding a suitable one was no problem.
Finaly connect the IO board to the host computer over USB.
Now on the host computer mount the eMMC with the rpiboot command.
me@raspberrypi:~ $ rpiboot
RPIBOOT: build-date Dec 15 2022 version 20221215~105525 7aa7e758
Waiting for BCM2835/6/7/2711...
Unfortunately nothing happend. Also it shows that his rpiboot version is already quite old, from 2022. After some reading at the usbboot troubleshooting guide I decided to try a newer version, by downloading and compiling it from github.
me@raspberrypi:~ $ wget https://github.com/raspberrypi/usbboot/archive/refs/heads/master.zip
--2026-09-02 20:33:31--  https://github.com/raspberrypi/usbboot/archive/refs/heads/master.zip
Resolving github.com (github.com)... 140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://codeload.github.com/raspberrypi/usbboot/zip/refs/heads/master [following]
--2026-09-02 20:33:32--  https://codeload.github.com/raspberrypi/usbboot/zip/refs/heads/master
Resolving codeload.github.com (codeload.github.com)... 140.82.121.10
Connecting to codeload.github.com (codeload.github.com)|140.82.121.10|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 126933862 (121M) [application/zip]
Saving to: ‘master.zip’
master.zip                100%[==================================>] 121.05M  8.46MB/s    in 14s
2026-09-02 20:33:53 (8.87 MB/s) - ‘master.zip’ saved [126933862/126933862]
me@raspberrypi:~ $ unzip master.zip
Archive:  master.zip
3090a13e58b7f55c4941c56134501e1934744137
   creating: usbboot-master/
   creating: usbboot-master/.github/
   creating: usbboot-master/.github/ISSUE_TEMPLATE/
  inflating: usbboot-master/.github/ISSUE_TEMPLATE/bug_report.yml
  inflating: usbboot-master/.github/ISSUE_TEMPLATE/config.yml
  inflating: usbboot-master/.github/ISSUE_TEMPLATE/feature_request.md
...........long list of files .....................
  usbboot-master/tools/rpi-otp-private-key -> ../rpi-eeprom/tools/rpi-otp-private-key
  usbboot-master/tools/rpi-sign-bootcode -> ../rpi-eeprom/tools/rpi-sign-bootcode
me@raspberrypi:~ $
me@raspberrypi:~ $ cd usbboot-master/
me@raspberrypi:~/usbboot-master $ ls
bin2c.c        docs          main.c                     msd         rpi-imager-embedded    test
bootfiles.c    eeprom-erase  Makefile                   Readme.md   secure-boot-example    tools
bootfiles.h    firmware      mass-storage-gadget        recovery    secure-boot-msd        win32
decode_duid.c  fmemopen.c    mass-storage-gadget64      recovery5   secure-boot-recovery
decode_duid.h  LICENSE       mass-storage-gadget64-cm3  rpi-eeprom  secure-boot-recovery5
Install nescesary libraries:
me@raspberrypi:~ $
me@raspberrypi:~/usbboot-master $ sudo apt install git libusb-1.0-0-dev pkg-config build-essential
build-essential is already the newest version (12.9).
git is already the newest version (1:2.30.2-1+deb11u5).
pkg-config is already the newest version (0.29.2-1).
The following additional packages will be installed:
  libusb-1.0-doc
  libusb-1.0-0-dev libusb-1.0-doc
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 263 kB of archives.
After this operation, 1,861 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://mirror.truenetwork.ru/raspbian/raspbian bullseye/main armhf libusb-1.0-0-dev armhf 2:1.0.24-3 [70.8 kB]
Get:2 http://ftp.tsukuba.wide.ad.jp/Linux/raspbian/raspbian bullseye/main armhf libusb-1.0-doc all 2:1.0.24-3 [192 kB]
Fetched 263 kB in 9s (30.5 kB/s)
Selecting previously unselected package libusb-1.0-0-dev:armhf.
(Reading database ... 174898 files and directories currently installed.)
Preparing to unpack .../libusb-1.0-0-dev_2%3a1.0.24-3_armhf.deb ...
Unpacking libusb-1.0-0-dev:armhf (2:1.0.24-3) ...
Selecting previously unselected package libusb-1.0-doc.
Preparing to unpack .../libusb-1.0-doc_2%3a1.0.24-3_all.deb ...
Unpacking libusb-1.0-doc (2:1.0.24-3) ...
Setting up libusb-1.0-doc (2:1.0.24-3) ...
Setting up libusb-1.0-0-dev:armhf (2:1.0.24-3) ...
And build the program:
me@raspberrypi:~/usbboot-master $ make
cc -Wall -Wextra -g   -o rpiboot main.c bootfiles.c decode_duid.c `pkg-config --cflags --libs libusb-1.0` -DGIT_VER="\"\"" -DPKG_VER="\"local\"" -DBUILD_DATE="\"2026/09/02\"" -DDEFAULT_MSG_DIR=\"/usr/share/rpiboot/mass-storage-gadget64/\"
Try again, and success!
me@raspberrypi:~/usbboot-master $ sudo ./rpiboot -d mass-storage-gadget64
RPIBOOT: build-date 2026/09/02 pkg-version local
Please fit the EMMC_DISABLE / nRPIBOOT jumper before connecting the power and USB cables to the target device.
If the device fails to connect then please see https://rpltd.co/rpiboot for debugging tips.
Loading: mass-storage-gadget64/bootfiles.bin
Using mass-storage-gadget64/bootfiles.bin
Waiting for BCM2835/6/7/2711/2712...
Sending bootcode.bin
Successful read 4 bytes
Second stage boot server
File read: mcb.bin
File read: memsys00.bin
File read: memsys01.bin
File read: rp1c0fw1.bin
File read: memsys02.bin
File read: rp1c0fw2.bin
File read: memsys03.bin
File read: bootmain
Loading: mass-storage-gadget64/config.txt
File read: config.txt
Loading: mass-storage-gadget64/boot.img
File read: boot.img
Second stage boot server done
This can also be checked with lsblk, which nicely shows the eMMC drive (sda).
me@raspberrypi:~ $ lsblk
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
sda           8:0    1 29.1G  0 disk
mmcblk0     179:0    0 14.8G  0 disk
├─mmcblk0p1 179:1    0  256M  0 part /boot
└─mmcblk0p2 179:2    0 14.6G  0 part /
Now with the use of the Raspberry Pi Imager I was able to flash the CM5.
Bottom line
Flashing the CM5 is not difficult once you know the correct procedure, but there is one important pitfall. The version of rpiboot available through apt on my Raspberry Pi 400 was too old to work with the CM5. Installing the latest version from the Raspberry Pi usbboot GitHub repository solved the problem, and the CM5 eMMC was then successfully detected as a USB mass-storage device and could be flashed with Raspberry Pi Imager.
In short: fit the jumper on J2, connect the CM5 to the host via USB, use the latest rpiboot, and then flash the eMMC with Raspberry Pi Imager.
  • Qbit
    Qbit 2 months ago +1
    Excellent blog post! It's super helpful that you documented the dependency installation.
  • gpolder
    gpolder 2 months ago in reply to Fred27
    Indeed, I did not use the HDMI cables yet.
  • Fred27
    Fred27 2 months ago
    It's odd that the jumper isn't included. It's such a minor component but essential for one of the main uses of the IO board. I know most of us would have one lying around, but it seems more a part of a development kit than the 2 HDMI cables.
  • Qbit
    Qbit 2 months ago
    DAB 2 months ago
    Nice update.
  • gpolder
    gpolder 2 months ago in reply to embeddedguy
    good question, after flashing, booting the system went fluently, I will talk more about that in the next blog.
