RoadTests & Reviews
RoadTests & Reviews
Review Blogs Special Project with Cypress PSoC6 BLE kit +  Honeywell Pressure Sensor
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: dougw
  • Date Created: 1 Dec 2018 4:08 PM Date Created
  • Views 2868 views
  • Comments 6 comments
  • doug wong
  • honeywell pressure sensor shield
  • cypress psoc6 ble kit
  • paint ball gun
dougw
dougw
1 Dec 2018
This project is about building an interesting medical application project around Honeywell pressure sensors and a Cypress PSoC6 BLE Kit.
I am partnered with glennvanderveer on this project. He will be doing most of the heavy lifting now that he has recieved a PSoC6 BLE Kit from jomoenginer . Thanks jomoenginer.
Our project aims to use a Honeywell pressure sensor to measure shock waves that could damage ears. The project will also experiment with different types of ear protection to see how effective they are in attenuating the over pressure associated with shockwaves.
To create a realistic test platform, I 3D printed a headform with cavities around the ear locations. These cavities can hold very realistic biofidelic ears. These ears will allow ear plugs to fit properly.
The pressure sensor can be mounted inside where the ear drum would be.
The pressure sensor measures gage pressure so the ambient port will need a tube to a location unaffected by the shockwave. Probably some heat-shrink tubing will be adequate.image
The pressure sensor will be read by the PSoC6, which will also display data on its e-ink display.
The shockwaves will be generated by a paintball gun shooting compressed air.
This preliminary video shows the apparatus and how it all works:
Here is a chart that puts sound levels and their damage potential in perspective:
I will add links to glennvanderveer blog when he has some progress to report on measuring pressure.
Relevant Links:
Need Someone for a Project: Cypress PSoc6 BLE kit +  Honeywell Pressure Sensor Shield
https://www.element14.com/community/roadTests/1862/l/cypress-psoc-6-ble-pioneer-kit-cy8ckit-062-ble#comment-117223
Solve Your IoT problems with the New Cypress PSoC 6 MCU: Purpose-Built for the IoT
http://www.cypress.com/documentation/development-kitsboards/psoc-6-ble-pioneer-kit
https://uk.farnell.com/honeywell/sek002/eval-kit-board-mount-pressure/dp/2849208?st=honeywell%20abp
https://sensing.honeywell.com/sensors/humidity-sensors/HIH8000-series
https://sensing.honeywell.com/hih8000-datasheet-009075-7-en.pdf
https://sensing.honeywell.com/ABPDRRT005PG2A5-amplified-board-mount-pressure-sensors
https://sensing.honeywell.com/honeywell-sensing-basic-board-mount-pressure-abp-series-datasheet-2305128-e-en.pdf
https://sensing.honeywell.com/honeywell-sensing-basic-board-mount-pressure-abp-series-installation-instructions-32305127…
Convert Sound Level to Pressure
Convert Pascals to PSI
    dougw over 7 years ago in reply to genebren +3
    Good point Gene. Chronic prolonged exposure to loud sound will definitely damage hearing even though when measured as a pressure loud sounds seem to be very low pressure. For example a .357 magnum gunshot…
    genebren over 7 years ago +2
    What a great medical application. Human safety, including hearing protection is a important field, which an area that should benefit from the development of sensors. Given the wide range of environmental…
  • kas.lewis
    kas.lewis over 7 years ago +2
    Hello dougw , I'm just curious, did you need or get any help for Honeywell at all on this. Do you need any technical support. I'm asking because At the San Jose Sensor Expo Honeywell had mentioned that…
    What a great medical application.  Human safety, including hearing protection is a important field, which an area that should benefit from the development of sensors.  Given the wide range of environmental conditions that can damage hearing, I would have thought that a wider frequency range, like from a microphone, would have been a better choice of a sensor for these experiments.  I do look forward to following your progress through this blog series.
    Best of luck!
    Gene
