RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum What To Do When You Have No Idea (Or Draw a Mental Blank) on How To RoadTest a Product?
  • Blogs
  • RoadTests
  • Reviews
  • Views 1100 views
  • scasny
rscasny
rscasny over 6 years ago
I read that the question in my title was posed by a reader in my discussion on: Do You Know Enough or Are You Good Enough To Be a RoadTester?  I think this question has been answered  various times in the past by experienced roadtesters themselves. But the question came up again, and I think it somewhat relates to Road Test Fears and influences whether someone applies or doesn't apply, or completes or doesn't complete their review. So, I'm going to take a shot at answering it from my point of view as the RoadTest Program Manager.
Prior to my assuming the role of RoadTest Program Manager, I noticed that the roadtest application was kind of sparse. It just asked, why do you want to roadtest this product? I think that can work for some products, like the Raspberry Pi, which as an extensive following on element14 and people see the roadtest as a de facto project giveaway. But there are a lot of new products being launched where the knowledge level varies. My concern was the very question I am posing in the title: you get a product for a roadtest that you know nothing about: what do you do? The way I resolved this issue was to ask a series of pointed questions in the application that I believe help a roadtester clarify his or her thoughts so they never enter panic mode. This is where the question about the testing procedure came from. If you provide a testing procedure you have a starting point or a roadmap for the review.
So, if you draw a mental blank once you get the roadtest product, go back to your application. Re-read your testing procedure. If something isn't right, modify the procedure. Ask yourself, what about your testing procedure is not working for you? Think about ways you can break up the testing procedure into mini-tests. Then, methodically try to complete these mini tests one by one.  (If it isn't obvious on how much I rely on your testing procedure in selecting you, then this paragraph demonstrates it. An application with a weak testing procedure has less value than a detailed one. I do it to help the actual roadtesters so they don't draw a blank.)
Ask somebody for help. It could be a colleague, a professor, another element14 member. Hashing out a problem with someone else usually helps people clear up your thoughts (and doubts) and gives you the fortitude to progress, no matter what the endeavor. Part 2 of this question is somewhat of a risk on my part, but I will say it anyway and let the members respond: if you see someone who is an experienced roadtester, try to message or contact them. Introduce yourself. Tell them you have seen their reviews and you were impressed and tell them the reason you are writing is you need some advice about a roadtest. Explain your concern. Be honest, sincere and professional. I think there is a good chance that an experienced roadtester will respond to your request for advice.
Ask me. That's part of my job. Message at rscasny
Get back to the basics. You are conducting a technical review of the product. So, every roadtest whether explicitly or implicitly answers three questions: Does it work? Is the product easy to use? And is the documentation correct? Those three questions tell a lot. A sponsor obviously want to see Yes to all these questions. But if there is a No, and you can support a No in your roadtest, they would your review to be useful and valuable, as well.
The last thing I would say is to ask yourself, is my roadtest complex or simple. I think complex roadtests are probably hard to pull off unless you are an experienced professional and experienced roadtester. If it is too complex, simplify it.
Randall Scasny
  • n5kzw
    n5kzw over 6 years ago in reply to BigG
    IMHO it would behoove manufacturers to hire calibrated innocents and provide them with computers that have been wiped completely clean with a fresh OS to test out their documentation.  That would be a good task for an intern if they have just been "hired".  I have encountered too many times where the documentation, if it was checked at all, was checked by someone who was familiar with the product and working on a computer that had been used with the tested device before it was used to check the documentation. - Ed
  • hugohu
    hugohu over 6 years ago in reply to BigG
    Lack of understanding from both sides.
    Manufacturers need to know we don't understand their logic reasoning and how they designed everything, but end users can't expect an Evaluation board to be as easy to use as a flagship iPhone.
  • BigG
    BigG over 6 years ago in reply to hugohu
    Yes you are correct. The cause of most early stage problems is due to assumption on the manufacturers part, especially when it comes to documentation - they assume all users know the answer, which is seldom the case. On the other hand many new users somehow expect everything to be perfectly presented, which is also seldom the case. The real world is never a class room or a lab.
  • hugohu
    If you’re conducting a test of a new product, or rather- a totally different thing:
    rhese are the challenges.
    Little to no documentation and support.
    no one knows how to use this. You have to figure it out.
    if the roadtest is very new then it is probably a very good brain stretcher for advanced people.
    newbies, good luck in the wild.
  • BigG
    I would say that more often than not you are conducting a technical review of a NEW or NEWISH product, and anyone who undertakes a review of a new/newish (unproven) product will be confronted by two curves, namely the "learning curve" and the ""bathtub curve".
    Thus the first question "Does it work?" is not as simple as it sounds and could be rephrased as asking "what does it take to get the product to work". Naturally those with oodles of experience with similar products will find the learning part much easier than others (and vice versa) but would still be confronted by early unknown problems.
    Seldom does a new product not surprise when it is unboxed, so spill the beans. It is the writing up of these issues (i.e. learning & unknown problems) objectively which IMHO are more valuable than spending time creating another marketing pitch about the product.
