RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum What can I do with my element 14?
  • Blogs
  • RoadTests
  • Reviews
  • Replies 10 replies
  • Views 1679 views
I have just been given an element 14 for my birthday. I am reasonably computer savvy but I have no idea what I can do with my pressie.
Anyone tell mer?
Jack
    Jack,
    Yes, this is a small, inexpensive computer intended to get students excited
    about learning programming, especially those who can't afford a typical PC.
    Since you already have a PC, you would almost certainly find your PC to be
    faster and more suitable for tasks like web browsing and learning programming.
    The RPi would likely be more suitable for tasks where its size, quietness, and
    low power are important.  Many people use the RPi together with a PC, by
    using SSH to connect them, with X Windows forwarded to the PC's display,
    rather than hooking up a keyboard and TV or display directly to the RPi.
    That avoids some of the slowness of X Windows on the RPi.
    I am reminded of a recipe for cooking shad fish:
    "Find a board from a birch tree and soak it in water for about eight hours. Gut the shad and nail it to the board. Build a fire of apple and cherry wood. Suspend the board over the flames, adding wet wood chips to produce smoke. Remove the board and let cool. Throw away the shad and eat the board."
    http://articles.mcall.com/2009-05-06/news/4368443_1_shad-board-wood
  • awneil
    awneil over 14 years ago
    Yes, it is indeed a Raspberry Pi!
    So http://www.raspberrypi.org/quick-start-guide is the place to start. Be sure to also explore the rest of that site.
    Theses are pretty hot at the moment - so putting "Raspberry Pi" into google will show you loads of stuff going on with them...
    Also check out @Raspberry_Pi and #raspberrypi and #raspberry_pi and #rpi on Twitter...
    Nico, Dave, thanks to both your advices and reading the links pages, I'm slowly learning a little.
    I've have to go to town to buy SD card so cannot do much more at this time.
    Thanks again
    Lads
    jack
    e14 Contributor over 14 years ago in reply to ntewinkel
    Nico, thanks so much for your advice, obviously you are a man who knows what hes talking about and to be listened to.
    My friend, as you have  said, has since told me its a rasberry Pi
    I'll look up the links you have sugested.
    Cheers again
    Jack
    e14 Contributor over 14 years ago in reply to DaveLTX
    Sorry Dave yes I meant a USB slot not a PSI.
    As you are now aware I'm not that computer Savvy but I'm learning every time someone replies to my quiries.
    Jack
  • ntewinkel
    ntewinkel over 14 years ago in reply to e14 Contributor
    Oh sweet! You have a Raspberry Pi - those things are still quite hard to get!
    It is indeed a small stand-alone computer that hooks up to your TV.
    Your first step should be to just run it as a basic computer, by hooking up a mouse and keyboard and a TV, and running the operating system on an SD card. Don't hook it up to your computer.
    Here is a quick start guide: http://www.raspberrypi.org/quick-start-guide
    If you have trouble figuring out how to get the SD card set up with the operating system, I'm pretty sure you can buy a prebuilt one on element14.
    Once you have it running as a little computer, you can look into learning how to program it using Python. And from there the possibilities are quite endless actually.
    Check out the Raspberry Pi group - they will have a lot more information for you than I can give: http://www.element14.com/community/groups/raspberry-pi
    Cheers,
    -Nico
  • DaveLTX
    DaveLTX over 14 years ago
    What the heck?
    What's a PSI slot? If you mean a USB it's all wrong ... it's a USB host port not a USB device.
    What's a PSI slot again? You mean your GPU HDMI slot? WRONG! This is a standalone mini computer with it's own graphic card to plug into your TV/Monitor!
    I hope you didn't blow the raspberry's GPU up though ...
    You have to boot it up too.
    Someone told me the PI is a mini computer and for its size is very powerful and can be used to learn programming. It can be connected to a tv or monitor.
    i have connected it up to my computer by PSI slot but the computer does not show it as connected.
    i have connected it to the TV but again it does not show.
    Jack
    Nico thanks for your reply enclosed below is a photo
    Since unwraping it I have powered it up using an old Blackberry charger.
    Cheers for your interest
        .Jack
  • ntewinkel
    As far as I know, element14 refers only to this website and the related company (please correct me if I'm wrong).
    Maybe you have a product that was created by element14, like an XL_Star development board?
    Could you post a picture of what you have?
    Cheers,
    -Nico
