RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Which would you get Rasberry PI 2 or Gizmo 2 and why?
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 15 replies
  • Subscribers 2668 subscribers
  • Views 1936 views
libernullmal
libernullmal over 11 years ago
Just curious between the two and I wanted to know what the pros and cons between the two?
  • fvan
    fvan over 11 years ago in reply to shabaz +2
    Even mSATA might require some soldering, if the device is "non-compliant" http://www.element14.com/community/community/designcenter/single-board-computers/gizmo2/blog/2015/01/30/gizmo2-installing-ssd-and…
  • dtsartsanis
    dtsartsanis over 11 years ago +1
    Gizmo 2 is using a x86 processor which means that u can install windows.So if u are not familliar with Linux software and u can spend $199 go for it. Raspberry Pi 2 now is a complete pc in a compact size…
  • najath
    najath over 11 years ago in reply to clem57 +1
    I tried Chromium on another ARM board - SABRE Lite which I had obtained thanks to element14 . The ARM board is good enough for most use cases. But unfortunately pepper-flash was not available packaged…
    Former Member over 11 years ago in reply to clem57
    best question I have is can you interface it with a computer that is stata and uses ddr 2 ram?
  • clem57
    clem57 over 11 years ago in reply to Former Member
    For sata support try pcDuino 3.
    Clem
    shabaz over 11 years ago in reply to clem57
    Hi Greg,
    Gizmo does have SATA capability with a bit of soldering, however since it has mSATA capability built-in, mSATA can be used for local storage
    (i.e. no need to use SATA connector unless you really need it).
  • fvan
    Even mSATA might require some soldering, if the device is "non-compliant" image
    http://www.element14.com/community/community/designcenter/single-board-computers/gizmo2/blog/2015/01/30/gizmo2-installing-ssd-and-ubuntu
    shabaz over 11 years ago in reply to fvan
    Oh. I'd forgotten about that!
