RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Which would you get Rasberry PI 2 or Gizmo 2 and why?
  • Blogs
  • RoadTests
  • Reviews
  • Replies 15 replies
  • Subscribers 2745 subscribers
  • Views 2393 views
libernullmal
libernullmal over 11 years ago
Just curious between the two and I wanted to know what the pros and cons between the two?
    shabaz over 11 years ago in reply to fvan
    Oh. I'd forgotten about that!
  • fvan
    fvan over 11 years ago in reply to shabaz
    Even mSATA might require some soldering, if the device is "non-compliant" image
    http://www.element14.com/community/community/designcenter/single-board-computers/gizmo2/blog/2015/01/30/gizmo2-installing-ssd-and-ubuntu
    shabaz over 11 years ago in reply to clem57
    Hi Greg,
    Gizmo does have SATA capability with a bit of soldering, however since it has mSATA capability built-in, mSATA can be used for local storage
    (i.e. no need to use SATA connector unless you really need it).
  • clem57
    clem57 over 11 years ago in reply to e14 Contributor
    For sata support try pcDuino 3.
    Clem
    e14 Contributor over 11 years ago in reply to clem57
    best question I have is can you interface it with a computer that is stata and uses ddr 2 ram?
  • clem57
    clem57 over 11 years ago in reply to libernullmal
    As I understand, the Gizmo supports Windows CE which is not a full Windows.
  • libernullmal
    I'm not really worried about the low powered consumption. the thing that really interest me is the Linux and Window on the Gizmo. However I've so far liked the Rasberry Pi and have yet to try out the Gizmo.
  • clem57
    clem57 over 11 years ago in reply to najath
    Ok! I will play for a few days and let you know.
  • najath
    najath over 11 years ago in reply to clem57
    I tried Chromium on another ARM board - SABRE Lite which I had obtained thanks to element14. The ARM board is good enough for most use cases. But unfortunately pepper-flash was not available packaged for ARM devices. I used one that I got after an online search, and which was extracted from a chromebook. It worked reasonably well too. But for each update, I had to search the web for finding the latest version.
    Later I got an Intel NUC with Atom processor. So now I'm experimenting with it and have set it up as my home cloud and entertainment platform.
    If you find a simple and secure way of getting flash work on ARM devices, do let me know. I can then make some use of the SABRE Lite board
  • clem57
    Google Chrome cannot be installed on Raspberry Pi, because Google does not have support for Linux/ARM.
    But Chromium, the open-source version of Google Chrome can be installed on a Raspberry Pi box, for both Arch Linux and Debian:
    I got this quote from a good source najath. So you are kinda of right, unless you consider Chromium. I plan on trying soon and will let you know how flash works.
    Clem
