RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Exist any cheap option to be able to detect and recognize in a range of 10 Cm?
  • Blogs
  • RoadTests
  • Reviews
  • Replies 10 replies
  • Answers 7 answers
  • Subscribers 2747 subscribers
  • Views 1708 views
  • cat
  • dog
mauro_duque
mauro_duque over 8 years ago
Hi guys,
I want to detect my cats and recognize them so I test first with the RC522 RFID LF reader but the range is so small that I couldn´t detect my cats when the tag is not on the right position or when they eat in a different angle
I'm looking for a different option to replace this option but the prices rise a lot. I'm considering the possibility of using an antenna DIY (this test didn´t work, unfortunately), or buy one but is so expensive.
I'm considering different technologies as NFC (Near field Communication) and Proximity Beacons
Do you guys have any suggestion for me?
I'm looking for an option around 5Us.
Thank you so much for your help
  • mauro_duque
    0 mauro_duque over 8 years ago in reply to dougw
    Thank you so much Douglas
    0 dougw over 8 years ago in reply to mauro_duque
    You can make your own antenna from a coil of wire - something like RFIDCOIL-250A works up to 27 cm:
    You can make your own reader card using something like an EM4095 chip.
  • mauro_duque
    0 mauro_duque over 8 years ago in reply to yuritikhonov
    I'm using ESP8266 because I need a cheap option because I want to sell the product someday if the testing is successful.
  • mauro_duque
    Hi Frank,
    First of all sorry for delay answering,
    I want to detect different cats so I could give each one different portion of food.
    Yes, I want to use tags with an RFID reader + an antenna, my budget for it would be 20 USD because I want to be able to sell the product if the testing will be successful.
    I have a big advance in the mechanical part of the design but not so much in the electronic part yet.
    I would prefer that the range detection will be below of 40 Cm because it will be a little bit annoying if the feeder is continually open and close when the cat doesn't want to eat but for some reason id close to the feeder.
    Thank you so much for answering me Frank.
  • mauro_duque
    0 mauro_duque over 8 years ago in reply to jw0752
    Hi John, sorry for the delay answering.
    I want to detect each cat so I could give each one different portion of food (there is one "Coco" that is so Fat)
  • yuritikhonov
    0 yuritikhonov over 8 years ago
    What type of development board do you use in your project? If you use something like Raspberry Pi you can just connect a cheap webcam and write a simple program for object recognition.
    I've seen these available for about $50.
    • Vote Up +5 Vote Down
  • fmilburn
    0 fmilburn over 8 years ago
    Hi Mauro,
    it would help to know more details:
    • As John says, do you need to distinguish multiple cats?
    • Do you want to sense cats (or dogs) that don’t have tags
    • Is there a maximum range - e.g. exclude cats more than a meter away
    • What is your budget?
    • Etc.
    They are a bit expensive but this might be an interesting project for the Google AIY Vision kit.
    Edit:  Just noticed you placed this in RoadTests and Reviews - Are you reviewing something?
    0 jw0752 over 8 years ago
    Hi Mauro,
    Did I understand that you want to be able to not only detect the cats but also distinguish one cat from the other?
    0 DAB over 8 years ago
    Use capacitive sensing.
    I recommend the TI Capsense board.
