RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum What is the format to add to an Element14 Blog
  • Blogs
  • RoadTests
  • Reviews
  • Subscribers 2745 subscribers
  • Views 849 views
colporteur
colporteur over 6 years ago
What is the process to update a Blog? Are Blog posts individual CREATES or Add to Comments?
I'm a novice at using a Blog. I have started the following Blog on Element14 The Road to Raspberry Pi4B/ PoE Hat RoadTest Review (Introduction) and would like to post an update. Do just use the Add A Comment button at the bottom of the post or do I CREATE a new Blog enter using the same title and then add the material there?
I can see pluses and minus for both approaches but would like to follow the norms for blogging. Can anyone provide a recommendation?
  • colporteur
    0 colporteur over 6 years ago in reply to genebren
    Thanks GB genebren . I'm trying to determine what constitutes a small or large change and then applying the criteria.
    If you just keep editing a Blog post, what prevents it from becoming a running toilet?
    I guess the decision points you choose to break posts. Hummm, I have to do some thinking about this.I'm trying to prevent the reader from endless scrolling. The Blog is on Pi4/PoE but I have a post on test criteria, another on cable specification, another on power requirements.
    0 genebren over 6 years ago
    Sean,
    It is possible to edit an existing blog.  On the righthand side of the screen is an actions list and in it is an 'Edit' button/link.  This allows you modify the blog.
    I have used this feature to add updates to an existing blog (as have others).  Depending on the amount of new material, I either append to the initial blog (small additions) create a new blog (large additions).
