RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum need help please
  • Blogs
  • RoadTests
  • Reviews
  • Replies 8 replies
  • Subscribers 2745 subscribers
  • Views 1282 views
need help please
hi
looking for an equivalent to the G2356HEX this is a transistor from international rectifier used in an automotive ècu
thanks for you'r help
  • cksd
    0 cksd over 16 years ago
    Hi Manou,
    here is a link with an alternative from Intersil.
    http://www.seekdatasheet.com/Datasheet-340954-G2356HEX.html
    Your G2345HEX is an older IGBT MosFet which is now very seldom to get. But the HGTG20N120C3D is an alternative with
    nearly identical parameters...
    Have fun!
    Chris
    0 e14 Contributor over 16 years ago in reply to e14 Contributor
    yes th package seems right
    but i didn't found any components with similar name
    and this package....
    http://search.datasheetcatalog.net/key/2356
    but if HEX mean hexagonal sure it's an hex mosfet used for high power
    application
    https://ec.irf.com/v6/en/US/adirect/ir?cmd=eneNavigation&N=0+4294841672+4294850936
    this is the photo ,it's not so clear
    If you can, please post a transistor and PCB photos. Maybe it's IGBT from ignition system.
    Best way to solve the problem is making drawings from PCB and trying discover role of this element, and type NPN, PNP, IGBT, MOSFET.
    hi
    in shape ,it looks more like TO247AC,could you confirm this choice please,does the characteristics fits ? need cofirmationimageimageimage
    thank's
    hi good equivalent for your transitor should be
    NPN  2SD2356
    http://www.datasheetcatalog.org/datasheets2/24/243016_2.pdf
    or this one
    BUX 37 ... BU 931, MJ 10012, BUX80 ...
    hi
    i really don't now this is part of an mg rover écu , it could be an earth amplifier signal
    thank's
    Hi, can you specify type of application (power or other), and type of package (TO-247, TO-220 ... etc)?
    G2356 without suffix HEX, can be replaced by 2SA114 but this is small transistor for RF/AMP
    2SA114   <=>  G2356 TR PNP18 GE,RF/IF AMP,OSC,MIX(DIGI
