RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Would You Be Interested in Roadtesting a Multiple Motor & Valve-Control Reference Design Board?
  • Blogs
  • RoadTests
  • Reviews
  • Replies 14 replies
  • Subscribers 2737 subscribers
  • Views 3230 views
  • roadtester survey
  • MCTPTX1AK324
  • motor control
  • automotive
  • nxp
rscasny
rscasny over 3 years ago
imageRecently, we have been speaking with NXP to find some good candidates for a series of roadtests they would like to sponsor. The first product we've talked about is a reference design board (RDK) that's capable of controlling three sensorless-based PMSMs (Permanent Magnet Synchronous Motors), one direct current (DC) motor, and four valves under low CPU loading. I think there's a lot to do on a roadtest of this product and wanted to get your opinions.
I'll add some basic facts about the RDK below.
If you have the time, I'd appreciate you voting in my polls, too. Thanks.
Randall Scasny
Roadtest Program Manager
Here are some basic facts about the board:
The MCTPTX1AK324 is a reference design board engineered for out-of-the-box automotive multi permanent magnet synchronous motor (PMSM), targeting electric pumps, electric powertrain, eTurbo or thermal management system controller applications. Based on the 32-bit Arm® Cortex®-M7 S32K3 microcontroller and the GD3000 pre-driver, it controls three sensorless-based PMSMs, one direct current (DC) motor and four valves under low CPU loading.
Here are some features of the board:
  • Supports up to three PMS motors sensorless field-oriented control (FOC)
  • Up to 100W power for each PMSM
  • Up to 20W power for DC motors
  • Up to 5A peak current for high-side switch
  • One-way CAN and one-way LIN
  • Dual-core operation mode to reduce CPU load
  • ISO 26262 support
Here's the block diagram:
Here's some documentation:
  • Getting Started:
  • App Note 1:
  • App Note 2:
  • Schematics:
  • Software User Guide:
  • Hardware User Guide:
Roadtester Polls
  • weiwei2
    weiwei2 over 3 years ago
    i am thinking where it can be used on. and i do have electric golf cart that runs off 2 PMSM. perhaps use the dc motor for steering. one extra PMSM not used Slight smile
  • beacon_dave
    beacon_dave over 3 years ago in reply to scottiebabe
    Perhaps stick some wheels on it, add in a few of your vape batteries and you've got yourself personal transport along with a good chance at the upcycling challenge. Slight smile
    DAB over 3 years ago
    This board has a lot of interesting capability for non-automotive projects.
    I can envision a lot of interesting projects for testing the board and show off some of its capabilities.
  • scottiebabe
    scottiebabe over 3 years ago in reply to scottiebabe
    Jokes aside, looks like they have done a nice job.
  • scottiebabe
    Looks perfect.
    • Vote Up +5 Vote Down
  • saadtiwana_int
    saadtiwana_int over 3 years ago in reply to javagoza
    Yes, I guess that's the side effect of controlling too many motors from one controller...you run out of pins for encoders! Slight smile
  • rsc
    rsc over 3 years ago
    Looks like you'll need a hefty power supply to run this with all the motors and valves ~ 12V 400W.  It could probably control a small wheel chair or scooter
    scott
  • javagoza
    javagoza over 3 years ago in reply to saadtiwana_int
    From the figure it supports one encoder only
  • saadtiwana_int
    At first it looked like an interesting kit for controlling the gimbal motors on my recent Path-to-programmable project I worked on recently. I had issues with tuning the drive those motors came with, and have been thinking of replacing the original with better drives (while reusing the motors). However, the "sensorless" part of this kit is what will prevent me from applying, since I need to get feedback from the encoders for position control.
    michaelkellett over 3 years ago
    This is another of those boards where it fits a project and is great - or it doesn't. In my case it doesn't fit with anything I'm planning so I voted not to the road test.
    I feel that if you need a motor then you don't actually have a project that is suitable for such a multi functional board - so offering a motor isn't likely to increase the range of good Road tes applicants.
