RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Introducing OFF THE BENCH RoadTests - What Products Do You Prefer to Test?
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 49 replies
  • Subscribers 2558 subscribers
  • Views 4933 views
rscasny
rscasny over 1 year ago
About a month ago, I introduced an idea I call "Off The Bench" Roadtests.
Basically, I would reserve a few roadtest slots per year for products that aren't primarily used on your electronics workbench. It's a fairly simple idea.
In this discussion/poll, I wanted to drill down to more specific products, based on the feedback I had previously received from you.
I have a series of polls below, grouped by product types, more or less. I offer two products and the option to suggest an entirely different product in the comments section.
I will take your voting back to our product management, and I could start lining up "off the bench" products in the coming year.
So, if you have the time, vote as little or as much as you have time for.
Thank you in Advance.
Randall Scasny
RoadTest Program Manager
Hand Tool Kits
Tool Kit, Field Maintenance
More Info
PK 1700NA electronic kit
More Info
Shop Cleaning Devices
Vacuum Cleaner
More Info
imageDuster
More Info
Heat Gun and Heat Shrink
imageHeat Gun
More Info
imageHeat Shrink Kit
More Info
Tapes and Adhesives
imageAdhesive
More Info
imageTape
More Info
Printer Accessories
imageResin
More Info
imageFilament
More Info
The product choices above are not confirmed. So, there is an opportunity to suggest other products. Please do so if you are so included in the comments section.
  • misaz
    misaz over 1 year ago +10
    I would like to add some storage containers like the units which you use when shipping Experimenting with ... components. Farnell/newark have plenty of these storage boxes but documentation is very brief…
  • baldengineer
    baldengineer over 1 year ago +6
    Regarding the vacuum / duster. I know it is more expensive, but I have a Datavac Pro. It's both. I think it would be a better option for a test since it is dual-function. (I'm biased on this one since…
    dougw over 1 year ago +5
    In the heat gun category, I would really like to see a hot plate road test. Newark sells a number of them. They have several uses but few people actually have one because they can be pretty expensive.…
  • kmikemoo
    kmikemoo over 1 year ago in reply to cstanton
    I'll admit it.  I still use my teeth sometimes.  I do it less than when I was younger.  Back in the PSTN days, I got bit a few times "stripping wire" when a call came in.  THAT tingles quite a bit.  AND it caused me to buy a real set of wire strippers.
  • Andrew J
    Andrew J over 1 year ago in reply to dougw
    Timely comment: I was just looking for a decent set.  One's I've used in the past just chewed batteries and never worked when I needed them.  Mitutoyo seemed to be the best quality but the price is extraordinary!  I have a scaled set now but my eyes are just not good enough and I think a digital version would help.
  • baldengineer
    baldengineer over 1 year ago in reply to Andrew J
    FWIW, After years of (ab)use, I am very glad I invested in a Mitutoyo.
    dougw over 1 year ago in reply to hifromkatie
    I am fortunate to have a Mitutoyo as well. Its battery goes for years, even with daily use. Other calipers I've tried just feel like they are clogged with sandpaper by comparison.
  • Andrew J
    Andrew J over 1 year ago in reply to baldengineer
    Mulling it over.  I may ask Santa for one although I’m not sure I’ll get it.  I heard he electrified his sledge and can only make deliveries within 180miles of the North Pole.
  • beacon_dave
    beacon_dave over 1 year ago in reply to Andrew J
    Small lightweight item so it may qualify for delivery by long range drone ?
  • colporteur
    colporteur over 1 year ago in reply to Fred27
    I remove the batteries in mine also. It took me a while to discover turning them off didn't assure the battery was OK the next time. Mine are a Craftsman Canadian (Crappy) Tire purchase.
  • anniel747
    anniel747 over 1 year ago in reply to shabaz
    Depending on quantity: Ideal T stripper, Paladin Mini-Stripax Plus, Eraser C100S or one of the Schleuniger models.
  • JWx
    JWx over 1 year ago
    maybe a multitool? Sometimes carrying all the required equipment is not possible, and something more universal but good enough for the job will be sufficient...
