RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum How Would You Connect a BLDC Motor to This Evaluation Board?
  • Blogs
  • RoadTests
  • Reviews
  • Replies 7 replies
  • Subscribers 2739 subscribers
  • Views 1872 views
  • roadtster survey
rscasny
rscasny over 2 years ago
How would you connect a Brushless DC Motor to this evaluation board?
Infineon XMC7200 evaluation kit
User Guide
Quick Start Guide
Roadtester Poll
  • rsc
    rsc over 2 years ago
    The data sheet says it has a PMOD interface, so just use a PMOD BLDC motor driver plugin
  • manojroy123
    manojroy123 over 2 years ago
    Does this board has firmware for micropython.
  • manojroy123
    There is no motor interface, that is mention on the datasheet. I would rather go for motor specific boards that has more motor control features in it. The datasheet gives a circuit for separate motor control drive. Please provide us with that same drive to test this board for motor control. And a 3 phase motor as well.
  • obones
    obones over 2 years ago
    Using a motor driver shield feels way safer from the hobbyist point of view.
    Much less risk of frying the MCU if there's some sort of "buffer" in between
  • battlecoder
    battlecoder over 2 years ago
    That board reminds me a bit of the Edison boards.
    Depending on the availability and the goal (just for fun? a design for a client? etc), an ESC, a custom driver, or a driver shield would all be options, in my opinion.
  • Gough Lui
    Gough Lui over 2 years ago
    Depends, if the motor had its own controller, you could use canbus and hook the control lines to the header on the board (e.g. in automotive/elevator applications). A raw motor would need its own driver, in which case, maybe via a shield. But not too much experience with this myself.
    dougw over 2 years ago
    If I had the time, I would design an e-bike motor controller to test this beast.
