RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Help me to setup the software to use the trimak motor
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 91 replies
  • Subscribers 2654 subscribers
  • Views 3424 views
  • RoadTest
  • problem
  • motor control
  • trimak
  • motor
manojroy123
manojroy123 6 months ago
I am trying to install TMCL-IDE for windows. I am getting this error. Please help me in solving it.
  • cstanton
    cstanton 5 months ago in reply to manneveru +3
    manneveru said: This is not right forum for this post This post is relating to a RoadTest and its consequent review, it's the correct place for it to be situated. You can turn off replies to the thread…
    Jan Cumps 5 months ago in reply to manojroy123 +2
    Manoj, it may help if you: use the correct name in the subject. Shows respect to the manufacturer that sponsored the board explain what step you are trying to complete in the user guide/documentation…
  • beacon_dave
    beacon_dave 6 months ago in reply to manojroy123 +1
    https://www.analog.com/media/en/technical-documentation/user-guides/how-to-start-linux-tmcl-ide.pdf
  • obones
    obones 6 months ago
    This won't work with Windows 8 because the SystemParametersInfoForDpi functions is only available starting with Windows 10 as can be see here:
    learn.microsoft.com/.../nf-winuser-systemparametersinfofordpi
  • manojroy123
    Which linux OS can it run and what is the hardware requirement for it.
  • manojroy123
    manojroy123 6 months ago in reply to obones
    My hardware cannot support windows 10 or higher. I am looking for linux os in which it is compatible and the hardware requiemnt for it.
    Jan Cumps 6 months ago in reply to cstanton
    I saw Windows 7 or higher on one post of their website. That's clearly outdated info, because the required API didn't exist in that version
    update: found it back. Page 8 of this document: https://www.analog.com/media/en/dsp-documentation/software-manuals/TMCM-1230-TMCL_firmware_manual_fw1.16_rev1.01.pdf
  • colporteur
    colporteur 6 months ago in reply to manojroy123
    https://www.analog.com/en/resources/evaluation-hardware-and-software/embedded-development-software/software-download.html?swpart=SD_2CTQCCI
    following the links  Jan Cumps provided.
  • manojroy123
    manojroy123 6 months ago in reply to colporteur
    But which linux OS does it supports
  • manojroy123
    In which linux os do I need to install it.
    It may help to ask the question in the main Road Test post: https://community.element14.com/products/roadtest/rt/roadtests/690/seeking_an_engineer_to_review_a_trinamic_motor_drive_kit_from_analog_devices#pifragment-18971=4&pifragment-18972=7&pifragment-19828=11
    That 'll give the Analog marketing team a chance to spot that there is a question related to their road test (if they are following up)
  • beacon_dave
  • manojroy123
    manojroy123 6 months ago in reply to beacon_dave
    Thanks.
