I am trying to install TMCL-IDE for windows. I am getting this error. Please help me in solving it.
Hi manojroy123 ,
Please keep your conversation about this software to this thread, that way those who want to be notified about it and help you can remain subscribed to it.
The error you're receiving about "permission denied" is exactly that, the user you're running the software as does not have the permission to access the serial device. A search online can also grant you the answer to this, your user either needs to be added to the 'dialout' group (because it's a serial device, as in a dial up modem), or you can run as a user that is 'root' or run the software using 'sudo' to run it with elevated permissions.
Can you share me steps for it.
I can validate what you've found so far, what have you discovered when searching for the answer online?
Can you share me what should I search.
It say's I need to add user to dialout group. But I am running ubuntu as guest. How to add it into the dialout group.
ttyACM0 error: permission denied. Even after adding user to dialout group.
user name is ubuntu
Once you've added a user to a new group, you need to log out and back in for the change to apply, or you can restart the operating system.
You can also edit your messages, so you do not need to press reply each time, this reduces the number of notifications people receive
know it is showing.
