RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Need some help: adapter mcc 172 hat to Hansford HS100 M12 accelerometer
  • Blogs
  • RoadTests
  • Reviews
  • Locked Locked
  • Subscribers 2743 subscribers
  • Views 400 views
e14 Contributor over 2 years ago
Hello everyone,
I am having a very similar problem to this post:
Need Some Help: Adapting 2-pin Mil-C5015 to BNC plug
But unlike rscasny, I am planning to use Hansford HS1001005401 accelerometers, because I have a lot of these flying around
and I don't wanna spend another couple hundred bucks on vibration sensors if it is not really necessary.
The problem is the Hansford Sensors i have have a M12 connection and although I figured out you could get from 10-32 to 2 pin MIL,
I don't understand if it is easily possible to get from M12 to 10-32.
Is there a simple way to make a  cheap connection cable for this problem?
Your help is appreciated.
Robert
    I just realized the HAT has a screw Terminal, so I can connect the sensors without any adaptations.....problem solved. Thanks anyway!
    michaelkellett over 2 years ago
    You said cheap !
    Buy some of these:
    https://www.amazon.co.uk/FULARR%C2%AE-Professional-Connector-Terminal-Adapter/dp/B07RR2P5DK/ref=sr_1_3
    Cut the M12 connector off the Hansford cable and attach the screw terminal BNC which will mate with the cable from the HAT.
    Or buy an M12 lead with a connector and cut the BNC of the HAT cable and splice the two ends together.
