RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Arduino Ventuno Q - my first experience with the Ventuno Q
  • Blogs
  • RoadTests
  • Reviews
  • Replies 7 replies
  • Subscribers 2742 subscribers
  • Views 441 views
  • RoadTest
  • Ventuno-Q
  • robotics
  • ai
  • Orbbec
geralds
geralds 22 days ago
Here's my first experience using the Ventuno-Q:
Today I received a 3D depth camera: Orbbec Astra Pro Plus.
This camera has a USB connector (USB-A, 3.0) and can therefore be easily connected to the Ventuno-Q
This is my working place:
left: my solder station, front: Uno-Q, Ventuno-Q, modulinos, behind: two MIPI/CSI cameras, USB docking stick, right: keyboard
Here in a 5-minute video I demonstrate how to open an example project using the App Lab:
The application is an example AI program that uses a 3D depth camera to display objects.
You can adjust the sensitivity settings to filter objects based on their size.
This example uses a pre-trained model to detect objects on a live video feed from a camera.
The workflow involves continuously getting the frames from a camera, processing it through an AI model using the video object detection Brick,
and displaying the bounding boxes around detections. The App is managed from an interactive web interface.
This example is based on the Arduino UNO Q, but also works on Arduino VENTUNO Q.
The projects and examples featured in the App Lab are typically write-protected; therefore, you must create a copy before you can make any modifications.
If you like more information's about App Lab, please follow Arduino's Git:
https://github.com/arduino/arduino-app-lab
Best regards
Gerald
  • geralds
    geralds 18 days ago in reply to vmate
    Fine. Since you’ve tested it, I’m looking forward to hearing about your experience. Thanks for that!
    I’m using an Arduino USB-hub (1xUSB2, 1xUSB3, 1USB-C, 1xUSB-C_Pwr, 1xUSB-C_uplink, 1xHDMI, 1xLAN; 2xSD-card-slots) for this, because the Ventuno-Q only has two ports.
    It works perfectly.
  • vmate
    vmate 18 days ago in reply to geralds
    I have a few kinects, I'll try to get it working on the Ventuno Q. However, it's very sensitive to what USB3 controller is used, some machines just refuse to work with it.
  • geralds
    geralds 18 days ago in reply to cstanton
    Hi Christopher  cstanton
    I found this camera here at the Hiwonder webshop.
    https://www.hiwonder.com/products/gemini?variant=40545466744919&_pos=1&_sid=5e0269dad&_ss=r
    Then I compared this type with others, the quality as well the prize.
    Here I purchased it then:
    https://www.mybotshop.de/Orbbec3D-Astra-Pro-Plus_1
    My impression is, yes, it is good in function, just plug and play, on Windows also on Linux, Android (I didn't test yet).
    A bit was wrong in my mention before: The camera has a USB-A 2.0  connection.
    !! The camera must be mounted using an M6 (metric) screw, not the 1/4-inch screw typically used for photographic equipment. This ist different to some other cameras.
    Technical data
    • Depth Images: 640 x 480PX @ 30FPS
    • RGB / Image Resolution: 1920 x 1080PX @ 30FPS
    • FOV: 73D 60H 49.5V
    • Dimensions: 165 x 30 x 40mm
    • measuring range: 0.6 - 5m
    • Two integrated microphones
    • Data & Power Supply: USB 2.0
    • Power consumption: < 2.5W
    • Measuring accuracy: 1m: 1-3mm | 2-3m: 12.7mm
    • Operating temperature: 10 - 40°C
    • OS: Android, Linux, Windows
    https://www.orbbec.com/products/structured-light-camera/astra-series/
    I only know of the Intel RealSense some years by name or from data sheets. The prize was every time an issue.
    As for Kinect, unfortunately I know next to nothing about it—though it’s certainly possible that I might have come across a mention of it on Microsoft’s websites at some point.
    Until now, I hadn’t looked into it any further, as I didn’t really have a need for it.
    But now, with the Arduino-Q, everything I had actually been wishing for and planning for many years has been reignited.
    The Orbbec Astra pro plus is good for my project. It comes in 3 variants, older types:
    Astra S, Astra Pro, Astra Pro Plus.
    A new one is the Astra 2:
    https://www.orbbec.com/products/structured-light-camera/astra-2/
    https://www.mybotshop.de/Orbbec-Astra-2
    But the prize about 353 USD / 564,95 Euro/ was a bit too much for my small project. May be in future....
    This was my first impression. Interesting, Orbbec offers a lot of fine things for industrial robots.
    Best Regards
    Gerald
    DAB 20 days ago
    Very cool device.
  • ralphjy
    ralphjy 20 days ago
    Nice demo geralds .  I'll be interested to see what you do with it.
    I'm planning to try an Oak-D-Lite-FF depth camera that I got on Kickstarter quite a few years ago.
    It has a Movidius Myriad-X VPU and requires some driver setup, so I won't try it on The Uno Q - I'll wait until I get my Ventuno Q.
    I actually had written a blog post about it 4 years ago.  I don't recall whether I posted any projects on E14.  I'll need to look for bread crumbs in the box where it is stored...
  • Qbit
    Qbit 20 days ago
    NIce write up geralds ! Thank you for adding the the demo video seems pretty cool!
  • cstanton
    cstanton 21 days ago
    Thanks for the git link - how's the camera? I've only messed with realsense and kinects myself.
