RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum In Search of RoadTesters to Take On The All Programmable SoC (AVNET MiniZed RoadTest)
  • Blogs
  • RoadTests
  • Reviews
  • Replies 37 replies
  • Subscribers 2749 subscribers
  • Views 4573 views
  • scasny
rscasny
rscasny over 8 years ago
I'm in search of a few more roadtesters who would like to experiment with the Avnet MiniZed board.
What do you need?
1. Got to be Clever.
2. Inventiveness Helps
3. A Thirst for Learning
4. A love for Electronics
5. A Wish to Say "Hello World"
6. Beauty is not a requirement
7. A knack for tinkering is preferred
8. The ability to enter into the world of FPGA SoCs are pure magic.
9. A Messy Benchtop
10. A devotion to new technology. That's music to our ears.
(Here's something you should know about the MiniZed: "The board aims to showcase the power of Zynq, where the Cortex A9 processor core integrates seamlessly with the programmable fabric to provide signal
processing and control solutions."
Sign Up for the RoadTest Here: AVNET MiniZed
  • rscasny
    rscasny over 8 years ago in reply to jomoenginer
    Jon,
    Please do apply.thanks.
    Randall
  • Workshopshed
    Workshopshed over 8 years ago
    Spotted fpga4fun.com - where FPGAs are fun  today. Some simple experiments and projects to try there.
  • jomoenginer
    jomoenginer over 8 years ago
    If you are still looking for more folks to RoadTest the Avnet MiniZed, I would like to toss my hat into the mix. This board is on my To-Do list, so I am already looking at working with this and a RoadTest might be a good place to get this going.  I'll see about putting together a proposal and get it posted.
  • hlipka
    hlipka over 8 years ago in reply to jadew
    I can recommend the FPGA boards from Numato Lab. I do own some of their Spartan 6 boards, they are quite nice. And they break out nearly all the pins, without any fuzz.
  • hlipka
    hlipka over 8 years ago in reply to Workshopshed
    One idea I had for a while is to run a multi-channel digital filter for Delta-Sigma-ADC on a FPGA. TI has some nice isolated Delta-Sigma modulators, which you can use as isolated ADC. But you need a filter for it, which must run with 20MHz. This is too fast for most CPUs (since there is non-trivial computation involved).
    This would be ideal for e.g. a lab power supply, to monitor current and voltage for multiple, isolated channels.
    But since I already have a Zybo board at home, and did not find the time to exercise it properly, I too will skip on this road test (my list of non-finished projects is just too long).
  • Workshopshed
    Workshopshed over 8 years ago in reply to jadew
    Indeed, lots of small parallel tasks would be another thing that FPGA would be good with but without the I/O that a whole bunch of usecases eliminated
    michaelkellett over 8 years ago in reply to jadew
    Agreed, I've had the same problem with the Avnet Arty board (for Artix) FPGA, when we moved to a much pricier board it was still a bit limited for easy to get at IO but did have Xilinx mezzanine board connectors which allow access to a lot more IO with some difficulty (we used a Cypress adapter board which was sold for something quite different but had the right connectors broken out to pins.
  • jadew
    jadew over 8 years ago
    I don't know about others, but I can tell you why I won't apply to this, even tho I have both the motivation and background to test it.
    It may be a good product for some people who want a bunch of functionality out of the box, but it hardly qualifies as a dev board (which is what I usually need). At best, it can be considered a demo board or even a finished product, that makers can use.
    As a dev board is of little value, because it only exposes a couple of the IOs, so you can't connect your own circuitry to it. You can only use it as a whole, which is rarely something you want to do (or is even possible) during product development.
    To me, given the contradiction between the Arduino header, the complexity of the IC and the lack of IOs, is not even clear who this board is aimed at. Perhaps the target audience should be established first and then explain what this board can do for them.
    Razvan
    mcb1 over 8 years ago in reply to rscasny
    rscasny
    "cost of entry from a knowledge based perspective"
    I'm wondering if that (or some variation) shouldn't be part of the RT scoring.
    Obviously some devices are much easier than others, and the supporting documents and programming software can vary the score.
  • kas.lewis
    kas.lewis over 8 years ago in reply to Workshopshed
    Maybe someone that did the other FPGA roadtest (the one that was great for beginners) could do this as a comparison ? That would be one approach I would take but I didn't do the previous roadtest so this in an avenue not available to me.
    Kas
