RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Have any helpful maker tips? Send them my way!
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 58 replies
  • Subscribers 2567 subscribers
  • Views 5055 views
  • scasny
danzima
danzima over 7 years ago
Hello RoadTest!
I'm working with our community team on a second volume of our Essential Tips for Makers eBook series (you can see the original here). Our fearless RoadTest leader rscasny suggested that I reach out to our wonderful group here and see if anyone might have some useful tips they've picked up that they'd be willing to contribute.
We'll be printing this eBook for distribution at Electronica 2018, and of course it'll live on in perpetuity on the community as well. If you have any ideas you'd like to share, please leave them in this thread! Also feel free to reach out to me directly if you have any questions.
Thanks everyone!
  • fmilburn
    fmilburn over 7 years ago +11
    A bit of extra care with the enclosure and user interface can give a finished and professional look to a project. In the example below a PCB was designed and used as a faceplate.
  • luislabmo
    luislabmo over 7 years ago +10
    Most of the my tips are for easy bread-boarding/prototyping, I will update with pictures later on: Solder current limiting resistors to LEDs to save some space and time.... and use a big resistor (lets…
  • jc2048
    jc2048 over 7 years ago in reply to shabaz +10
    One thing to watch with old books is that sometimes the circuits were redrawn by graphic designers from scrappy, hand-drawn originals. A classic mistake was adding additional dots where there shouldn't…
    shabaz over 7 years ago in reply to dougw
    That's great for SMD IC alignment too, I do it a lot : ) It really helps with positioning them! Since you can rotate them by fractions of a degree, due to the leverability of the long tape if you see what I mean..
  • gpolder
    gpolder over 7 years ago in reply to mcb1
    I never destroyed my tips, but thanks for the tip, I will try the dish scrubber from our kitchen.
    (two type of tips in the sentence above, as a non native speaker english language is still difficult to me)
    • Vote Up +5 Vote Down
  • luislabmo
    luislabmo over 7 years ago in reply to gpolder
    Tecnically a wet sponge doesn't destroy tips, but makes their lifespan shorter due to oxidation also, sudden changes on the Tip's temperature (from very hot to cold when using the sponge) will cause cracks to the tip's coating in the long term, a good explanation here. I agree with others, the brass sponge is good enough and does an excellent job.
    Luis
    shabaz over 7 years ago in reply to gpolder
    A great benefit is it never seems to need cleaning/emptying. Since I've had the wire springy stuffy, I've never emptied it in a few years.. I don't know where the waste flux/solder/dirt off the iron falls.. probably falls through to the bottom of the pot eventually, but if I don't look there, the problem doesn't exist : )
    Jan Cumps over 7 years ago in reply to jc2048
    jc2048  wrote:
    One thing to watch with old books is that sometimes the circuits were redrawn by graphic designers from scrappy, hand-drawn originals. A classic mistake was adding additional dots where there shouldn't be joints. There's a nice example of that in the particular schematic you reproduce.
    When I learned circuit drawing at school, we were never allowed to make a cross a join. we always had to draw three   leg straight angle joins. No dots needed and no confusion. Even not after multiple photocopies from previous copies.
    shabaz over 7 years ago in reply to Jan Cumps
    Not like this then : )
    https://xkcd.com/730/
    • Vote Up +6 Vote Down
  • luislabmo
    luislabmo over 7 years ago in reply to shabaz
    I saw that diagram couple of years ago (when I was starting with electronics), the part that made me laugh the most was "Arduino, just for blog credits" image
    Jan Cumps over 7 years ago in reply to Jan Cumps
    If you print and scan the following drawing two times (or photocopy them with an early 80s copier image ), you'll have issues knowing what's connected and what not.
    The cross-hairs will all seem to have a dot after a few copies
    source: https://electronics.stackexchange.com/questions/26610/dual-polarity-vs-dual-rail-power-supply?noredirect=1&lq=1
    I double checked my own schematic here on element14 to see if I am consequent myself.
    Pfew, yes:
    Maker tip:
    Switch to SMD components. Just don't use the smaller footprints. 1206 for passives and SOIC for ICs is doable by hand.
    Your stock becomes smaller. Components fit in an envelope in a binder. PCBs are smaller, hence cheaper.
