RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum What Would You Build If I Gave You an SBC, Sensors, Relays, Connectors, a Power Supply and an Enclosure?
  • Blogs
  • RoadTests
  • Reviews
  • Replies 25 replies
  • Subscribers 2747 subscribers
  • Views 4170 views
  • scasny
  • ind_tag
  • rpi
  • energy_power
  • rpi_projects
rscasny
rscasny over 7 years ago
Hi element14 Members.
I've been approached by several suppliers who are interested in having some of our members get creative and build something special out of a bunch of parts I would send you. Before I brainstorm on what could be built, let me roughly go through the parts that would be provided to each interested member. I don't have exact part numbers, so what follows is a general list that I would select specific parts based on the BOMs submitted to me. Here goes:
EBM Papst – Fan
Omron – Sensor / relays
Panasonic – Bluetooth module / relay
TracoPower – Power Supply
CamdenBoss – Bespoke enscloure
some SBC
Connectors  – Molex / Omron/ Panasonic (Dependent on which sensor & SBC we use)
Battery & Holder
Lots of parts! Here's what I think.
  • Fans-- this sounds like some kind of ventilation application, be it for the enclosure a standalone application.
  • Sensors-- first thought: what kind of sensors: more than likely, some kind of environmental sensors, which suggests a monitoring applications
  • Relays -- relay logic, load switching, auxiliary control, which suggest some kind of automation application
  • Power supply -- AC or DC?
  • Enclosures--portability? external environment? An application that's in the open environment?
  • SBC/RPI-- a controller with a wide range of possibilities. What do you want to control? How much load? How Fast? What kind of control loop do you need.
  • Connectors: interconnecting everything you are wiring up in the enclosure.
  • Battery and Holder-- if you aren't stationary, then you will probably need a battery and something to hold it.
At this point, what we need is a few system engineers to brainstorm with. I think I would focus on these themes:
  • Mobility
  • Remote Sensing
  • Cooling/Ventilation
  • Controlling something for a practical purpose (I'm trying to avoid saying industrial -- it means too many things)
  • Internet of Things--what data do you want to generate and why?
Here are my first brainstorming thoughts. What do you think? I'll check back to see what you come up with and respond.
Randall
  • a531016
    a531016 over 7 years ago
    I would be building a whole home heat recovery system. Not original I accept, but open source, more configurable and more affordable?
    Would need a plate heat exchanger (or make one?). Extract fan and supply fan (electronically commutated of course) with bypass dampers for summer heat rejection. SBC will monitor fan speed and performance (should be able to calculate flow rates from fan performance curves). Also, temperature sensors to monitor the performance of the fresh air, supply air, extract air and exhaust air, and calculate the most efficient course of action.
    I would use the SBC for close "DDC" control of the equipment, but high level MQTT (probably) control and set point adjustment. Of course something like tensor flow for machine learning would be a plus too!
  • jdlui
    jdlui over 7 years ago
    I'd build an auto irrigation system for my balcony garden or a climate control system for the condo, using temperature and light sensing to open can close the blinds in response to sun image
  • geralds
    geralds over 7 years ago
    My dream is to develop and build a hoverboard, a hover-car, a hover-train …
    https://en.wikipedia.org/wiki/TrickStyle
    Experimental: In 2010 I worked on a "Lifter" - Ionocraft.
    The model was an asymmetric capacitor that used a high voltage to build an ion field around itself, lifting it off the ground.
    https://en.wikipedia.org/wiki/Ion-propelled_aircraft
    Here you will find all what you need to build such "Lifter":
    The JLN Labs home page
    The Lifters Experiments home page by Jean-Louis Naudin
    At that time this website gave me a lot inspiration for many projects.
    But now in the real world, right now I'm helping people in their smart home with technology.
    If I have enough material, I will develop and build smart furniture, a fully electronics-supportive kitchen, living room, bathroom, bedroom, etc.
    Especially for people who have physical disabilities and with eg voice control, gesture control, or about body weight, or about body temperature or with similar sensors, I would build supporting machines.
    Well, I would like to do that in my home as well.
    Edit:
    Tip: In your list above I'm missing tools, eg hand tools for crimping, or similar.
    Gerald
  • geralds
    geralds over 7 years ago in reply to dougw
    Cool image a Rube Goldberg machine….
    Hm,,,, is that computer not such this machine? imageimageimage
    Gerald
  • geralds
    geralds over 7 years ago in reply to michaelkellett
    Yes, they are, like solar cells; calculated "PI-thumb finger".
    2010 I played with Peltier cells, that was very informative but at that time extremely expensive.
    I contacted once this manufacturer:
    https://tetech.com/peltier-thermoelectric-cooler-modules/
    Some information:
    https://tetech.com/downloads/
    Gerald
  • robogary
    robogary over 7 years ago in reply to michaelkellett
    Thank you.
    I did mean Peltier, had a Hall Effect brain fart that day.  :-)
    Appreciate the correction.
    Gary
    dubbie over 7 years ago in reply to mp2100
    Allen,
    If it is hot enough it can kill wasps. Some bees can kill attaching wasps by gathering all around it in a ball which creates a high temperature killing the wasp.
    If it isn't the heat then it must be something else up there killing them off. I don't think it is the preservative in the timbers as I think they bring in the resin from outside - I've seen them on my wooden panels scraping away. Perhaps it was the treated wooden panels that killed them off. Anyway, I don't mind as long as they are all dead.
    Dubbie
  • hlipka
    hlipka over 7 years ago
    Whenever I read 'sensors' I think 'weather station'. Building and mounting one on the rooftop poses the interesting question of getting it powered, and transferring data safely back to wherever you want to show it. For data we can use WiFi or Bluetooth (or LoRa), but energy is more tricky. Solar power is one way, but difficult to get right (need to be weather-proof, and withstand also heavy wind and snow, while still delivering power). When you want to power it via cable, you need to make sure that nothing bad happens when lightning should strike. A real isolated power supply helps here (together with good over-voltage protection) to keep it out of the house.
  • mp2100
    mp2100 over 7 years ago in reply to dubbie
    Hot enough to kill wasps.  That is something.  The heat is not a problem, it's a feature!  Wasps, yellow jackets build nests on the sunny side of my house, they really like the heat.  I wonder what is too hot for them?
  • BigG
    BigG over 7 years ago in reply to michaelkellett
    Thanks for that insight. Nice to learn something new today.
