Enrollment closes in
Days 0 Hours 0 Mins 0 Secs 0
We need two Electronic Engineers to create a short video on how to use an arbitrary waveform generator in return we'll let you keep the test equipment for FREE.![]()
About the Mulitcomp Pro RoadTest Fundamentals Series
This RoadTest is a part of our Fundamentals series where we are ask roadtesters to provide video demos of the featured product.
This time we’re looking for 2 electronic engineers to create a video on the fundamentals of using an arbitrary waveform generator, specifically the MP750511 US Waveform Generator.
Your RoadTest Application should include:
· The Key Benefits of Waveform Generator
· What you have used a waveform generator for
· Tips & Tricks of Using a Waveform Generator in a short video
Your Video should:
· Be around 10 minutes in length
· Start with an introduction – introduce yourself and the product
· Talk about the types of tests you will be running
· Introduce the Device Under Test you will be using and show one to two examples of how to use the MP750511 to conduct those tests
· Wrap it up with recap – how does a Waveform Generator make tasks easier/possible? Explain how a Waveform Generator aids the design and troubleshooting process.
You do not need to do a standard RoadTest Review for this product.
Extra Credit:
Once you get the package delivered, please consider doing a 2-3 minute unboxing showing the product and “what’s in the box.”
Here are two examples of an unboxing:
Path to Programmable - MiniZed board overview and kit contents
LattePanda 3 Delta // Tech Highlight
Example Videos
Note: the product variant the roadtester receives will be based on their geographic location.
Multicomp Products
Click here to view other Multicomp Products.
Product Overview
Signal Generator Type: Arbitrary
No. of Channels: 2 Channel
Product Range: Multicomp Pro Waveform Generators
Bandwidth: 60MHz
Signal Generator Modulation: 3FSK, 4FSK, AM, ASK, BPSK, DSB-AM, FM, FSK, OSK, PM, PSK, PWM, QPSK, SUM
Manufacturer Warranty: 1 Year
Plug Type: US
Important Dates
| Begin enrollment: | January 10th, 2023 |
| End enrollment: | February 17th, 2023 |
| Select RoadTesters: | February 17th, 2023 |
| Ship unit: | Mar 2, 2023 |
| Begin Recording: | Mar 8 2023 |
| Element14 follow up: | Apr 8 2023 |
| Post Videos by: | May 6 2023 |
Terms and Conditions
