E36313A Triple Output DC P.S. - Review
View table of contents ...
RoadTest: E36313A Triple Output DC P.S.
Author: rachaelp
Evaluation Type: Power Supplies
What other parts do you consider comparable to this product?: There are numerous power supplies available from all the main test equipment manufacturers. The most direct comparison product I have available is a TTi QL335T or alternatively I have a TTi PL303QMD + TTi CPX400S combo, both of these solutions would give comparable triple PSU outputs.
What were the biggest problems encountered?: The unit being shipped with the wrong configuration but this isn't really a problem as it's easy to solve. I have found that there is an audible mains hum from my unit regardless of whether the supply is turned on or off, for as long as the AC inlet is powered. From searching online I found that whilst most people report the unit to be extremely quiet, there are some people who have units which make a mains hum the same as my unit. I reported the issue to Randall and he contacted Keysight who have sent me an email this morning confirming that this is not normal for these units and they are going to send me a replacement unit and arrange for my current one to be collected so they can investigate the issue. This is excellent service from Element14/Keysight.
1. Introduction
1.1. Overview
I received my shiny new Keysight E36313A Power Supply from Element14 this week. Thank you so much to both Element14 and Keysight for picking me for this Road Test. It's an excellent product and I am very happy indeed to have one sitting in my lab. I have a pretty good setup already but my current PSU's are missing a few really useful features which the Keysight unit happily provides.
This Power Supply is the top of the range model from the Keysight E36300 range. There are three models currently available, the entry level E36311A which is limited to 80W total power output and has a limited feature set, and the fully featured E36312A and E36313A models which have all the features enabled but with 80W and 160W total output power respectively. These models can also optionally have a GPIB interface which is supplied in my review unit. Unfortunately I do not have any way to utilize GPIB currently, but as the unit also has USB and Ethernet this is no problem at all. The main differentiations between the available features for the three models is shown in the image* below:
* Taken from the Keysight E36313A Bench Power Supply Data Sheet
1.1.1. External Links
Keysight E36300 Triple Output Bench Power Supply Data Sheet: http://literature.cdn.keysight.com/litweb/pdf/5992-2124EN.pdf
1.2. What's in the Box?
The unit came very well packed in a sturdy box and held firmly in place within the box with custom packaging. Inside the box was the E36313A itself and a small box containing the following additional items:
  • US Power cable - This was a mistake as I was shipped a unit intended and configured for the US market. More about this below.
  • A bag containing 1 x 4-way 3.81mm terminal plug, 1 x 4-way 5.08mm terminal block plug, and 1 x 8-way 5.08mm terminal plug. These are to connect to the rear panel I/O connectors. More about this below.
  • A bag containing 1 x Keysight Instrument Control DVD. This contains the IO Libraries 2017 Update 1, Command Expert 2017 Update 1, and the BenchVue 2017 suite.
  • An envelope containing the Certificate of Calibration for the unit.
  • Various additional pieces of documentation, e.g. Packing List, Quick Start, Safety Information, etc
1.3. The Main Specifications
The main specifications for the three versions available of the Keysight E36300 Bench Power Supplies shown in the image* below:
1.4. Comparable Solutions
For this road test I am going to be evaluating the Keysight E36313A and comparing it to two other solutions I have available to me:
  1. TTi QL355T - Like the Keysight, this is a triple output unit.
  2. TTi PL303QMD + TTi CPX400S combo - In order to have the same three outputs I could combine two other power supplies. In this case my dual output TTi PL303QMD and my single output TTi CPX400S units.
SpecificationKeysight E36313A
TTi QL355T
TTi QL355TP
TTi PL303QMD
TTi PL303QMD-P
TTi CPX400S
TTi CPX400SP
Price*
* As on Farnell UK 18/12/2017
£1317.00 + VAT
£760.00 + VAT
£947.00 + VAT
£529.00 + VAT
£707.00 + VAT
£558.00 + VAT
£717.00 + VAT
DC Output Ratings
Channel 1: 0 to 6V @ 0 to 10A
Channel 2: 0 to 25V @ 0 to 2A
Channel 3: 0 to 25V @ 0 to 2A
Channel 2||3: 0 to 25V @ 0 to 4A
Channel 2+3: 0 to 50V @ 0 to 2A
Channel 1: 0 to 15V @ 0 to 5A / 0 to 35V @ 0 to 3A / 0 to 35V @ 500mA
Channel 2: 0 to 15V @ 0 to 5A / 0 to 35V @ 0 to 3A / 0 to 35V @ 500mA
Channel 3: 2.7V @ 0 to 1A / 3.3V @ 0 to 1A / 5V @ 0 to 1A
Channel 1: 0 to 30V @ 0 to 3A
Channel 2: 0 to 30V @ 0 to 3A
Channel 1||2: 0 to 30V @ 0 to 6A
0 to 60V @ 0 to 20A (Max 420W TPD)
Max Total Power160W110W180W420W
Operating Modes
Independent, Tracking, Series*, Parallel*
* Fully automatic connection and control
Independant, Linked*, Tracking
* Enables linked controls with manually configured series / parallel modes
Independant, Tracking, Series*, Parallel*
*Series with manual connection in Tracking mode,
Parallel is configured internally with a switch on the front panel.
Independant
Load Regulation - Voltage< 0.01% + 4 mV
Channel 1: < 0.01% + 2 mV
Channel 2: < 0.01% + 2 mV
Channel 3: < 1.0% for a 90% load change
Channel 1:
Channel 2:
< 0.01%
Load Regulation - Current< 0.01% + 500 uA
Channel 1: < 0.01% + 250uA (5A/3A range), < 0.01% + 50uA (500mA range)
Channel 2: < 0.01% + 250uA (5A/3A range), < 0.01% + 50uA (500mA range)
Channel 1:
Channel 2:
< 0.05%
Line Regulation - Voltage< 0.01% + 1 mV
Channel 1: < 0.01% + 2mV for a 10% line change
Channel 2: < 0.01% + 2mV for a 10% line change
Channel 3: < 0.1% for a 10% line change
Channel 1:
Channel 2:
< 0.01% for a 10% line change
Line Regulation - Current< 0.01% + 500 uA
Channel 1:
Channel 2:
Output Ripple
Channel 1: < 350 uVrms / 2 mVpp
Channel 2: < 1 mVrms / 5 mVpp
Channel 3: < 1 mVrms / 5 mVpp
Channel 2: < 350 uVrms / 2 mVpp
Channel 3: < 1 mVrms typical
Channel 1:  < 400 uVrms / 2 mVpp
Channel 2: < 400 uVrms / 2 mVpp
< 3 mVrms / 15 mVpp
EthernetYesNoYes (P version)Yes (P version)
USBYesYes (P version)Yes (P version)Yes (P version)
GPIBYesYes (P version)Yes (P version)Yes (P version)
RS-232NoYes (P version)Yes (P version)Yes (P version)
So we can see from the above whilst the solutions are comparable in some respects, there are differences which may make one solution or another a better fit for certain applications. For example, the combination of the TTi PL303QMD-P and the TTI CPX400SP give a massive total power capability of 600W between the two which for some higher power applications may be an advantage.
However, it should be noted that it's not all about the fine detail of the specs, a huge factor for a general purpose lab power supply is the ease of use and its ability to be well integrated into an overall test solution. We can see from the above that making various configurations for the output power rails is much simpler with the Keysight as all the connections as well as the combining of controls is all handled internally to the power supply with no additional wiring necessary.
3. First Look at the Unit
3.1. Front Panel Overview
Looking at the image to the left we can see the unit has a fairly simple layout. There is a large screen to the left with size buttons immediately below it in a row.
To the right there is a section with two rotary knobs, one to control the voltage and one to control the current. Above these are three colour coded buttons to select which of the three output channels is selected for control. Immediately below these are some navigation and control buttons plus a numeric keypad.
Across the bottom of the unit you can see the binding posts for all three outputs. These are also colour coded and you can see they match the colour coding of the buttons at the top and their individual output enable buttons. It should be noted that, although you can't see here, the coloured buttons illuminate when the unit is powered on.
To the left of the screen there is a USB port to enable a flash drive to be connected.
Last but not least at the bottom left hand side of the front panel we find the soft touch power button and it's associated power on LED.
3.2. Rear Panel Overview
From the image to the left we can see that the rear panel of the unit is quite well utilized, there certainly isn't much room to add anything else! A large area in the middle is taken up by a vent for a cooling fan. I've heard this fan spin up a little during startup but not much at other times. Maybe once I get into testing this unit under higher load the fan will kick in and become more noticeable but generally the fan itself is very quiet. I'll touch on the noise levels from the unit a little bit more below.
At the top left there is an 8-way 5.08mm terminal block connector for connecting to Output Channel 2 and Output Channel 3 of the power supply. Note that this provides four pins per supply output.
Working our way down, we find an earth stud and then down at the bottom another 4-Way 5.08mm terminal block connector, this time for connecting to Output Channel 1 of the power supply. Again, note that this provides 4 pins for the supply output.
At the top right we have the LAN connector and the USB connector. This USB port would be used to connect to a computer to allow the instrument to be controlled over USB. In my case I will be using Ethernet for my control interface so this will not be required. It should be noted that there was NOT a USB or Ethernet cable supplied with the unit and I think for a unit in this price bracket these should definitely be supplied. Fortunately after a short rummage in a drawer I managed to dig out a spare Ethernet cable so my review did not come to a screeching halt at that point.
At the bottom right you will see the power inlet. At this point I should mention that I am based in the UK. The eagle eyed amongst you may notice there is something amiss noted on the back of this unit. You can see that the 115V configuration marking is shown. This unit was actually shipped to me configured for the US market and as such was set up for 115V rather than the 230V we use in this country. Fortunately I saw this before plugging in and powering up the unit otherwise I expect I would be requiring a replacement.
The unit is easily configurable to support different voltages. As you can see there is a table on the back showing the switch positions for 100V, 115V, and 230V. In my case I simply needed to slide the right hand switch over from the left to the right to change it to the correct setting. Below is a close up on this section of the rear panel to give a clearer view of the configuration switches. So, a small disaster has been averted and I can get on with reviewing my unit!
4. Getting More Familiar with the Unit
4.1. Teardown!
In the words of Dave Jones from the EEVBlog (like you didn't know who he was?!), don't turn it on, take it apart!
Okay so I'm not Dave Jones, or any of those that get given lots of free kit with the explicit expectation they'll tear it down. I'm not going to totally strip the unit down into as many pieces as I can get it into now because I don't want to risk accidentally damaging the unit and I really like this unit and want to be able to use it as my main lab power supply so I am not going to do anything to risk breaking it. If Keysight would like to send me a faulty unit they have lying around, I would be more than happy to do a more detailed tear down of that at a later date, but for now I'm just going to pop the lid and take a few pics of the insides. It's quite easy to get the lid off if you have a Torx driver set as it is held in place by two Torx bolts on each side and two on the top at the back. Once these are removed the lid simply slides out backwards.
4.1.1 The Main Board
Unfortunately I am being very cautious so this is the best view I can get of the main board without taking the unit apart further and looking at what, if anything is located on the other side. I can see some residue on the board so it's not been quite as well cleaned in production than I would have liked but it's probably no-clean flux so not going to be causing any issues.
You an see a few features of this board, for example there are two separate diode bridge's taking the secondary AC and then converting to various DC levels. There appear to be regulators for +12V and -12V, +3V3, +2V5, some current monitoring and towards the bottom I can see circuitry relating to the constant current and constant voltage references.
4.1.2. Front Panel Controller Board
You can see inside here, it's a typical embedded processor board. The main processor which controls the unit is shown and we can see it's all running on an STM32. You can make out a few other pieces of circuitry, some local power supplies, clocks, the FPC ribbons which go to the LCD and a coin cell battery presumably for an RTC or for a hold-up on some memory being used to store settings. I'd go for it being for an RTC as these days there are lots of options for non-volatile storage for small data sets like settings which are really cost effective and don't require an external hold up supply.
4.1.3. A Deep Dark View into the Back!
There is not a lot else to say about this one, I tried to shine some light in to the back to try and illuminate what was there, but unfortunately there is just too much in the way. You can just about make out that there is another board at the bottom of the unit, running across the back.
4.2. A Run Down of the User Interface
We can see from the image on the left that the unit has a very clear full colour LCD. The firmware uses appropriate colour coding for each of the channels which ties in with the colour coding for the buttons and the terminal post surrounds. This all ties the various displays and the physical controls together nicely and makes it very easy to quickly see for which channel you are viewing or editing the settings.
Along the bottom of the LCD there is an area reserved for button labels. This area is fixed and there is one segment for each of the physical buttons which reside immediately below the LCD. The labels help guide you through the various options and update to be specific for each page you are viewing.
Editing the settings for a particular channel is a simple matter of pressing a button to get to the control page for the currently selected channel. From there you can use the navigation buttons to move to each of the various options, you can type values in on the numeric keypad, or you can use the voltage and current knobs to make fine adjustments quickly. For setting a specific voltage or current it is almost always easier just to dial it in on the keypad than to try to use the knobs.
Across the bottom there are four buttons, three of these are colour coded channel output enable buttons as previously described and the fourth is a button dedicated to turning all the channels on or off at the same time.
4.2. Delving into the Usability
So the big question is, how well does this interface work for every day usage scenarios. Well, I've only had it a couple of days so haven't used it extensively at all yet but it seems very intuitive to use. The combination of a simplified single set of controls to operate all three channels, the colour coding and the very large and clear colour LCD give a good foundation for a easy to operate unit. Lets now take a short tour around a few of the menus to see how we'd go about setting up the unit to perform a few basic tasks. We'll do this by way of some examples which we will work through to show the various steps required.
So before we get into the actual setups, I wanted to show you a image of the main screen and show a little glitch I found when using the web interface (we'll look at this later) to grab images from the screen.
Looking at the two images above, these are both of the main LCD screen when it just has the default configuration of 0V and maximum current set up on all it's outputs.
If you look carefully you will see that on the first image there is a glitch in the current reading for both channel 1 and channel 2. These are reading exceedingly small values, in the order of <10uA and there is naturally some noise on these readings. However, you'd expect the capture to grab a stable image. It would appear rather than the capture grabbing the currently stable display buffer it is grabbing a buffer that is the subject of the next display update. I don't know if the rendering to the display itself is double buffered or not, although I haven't seen any tearing on the display which is the usual sign of updates happening on the live display, but this issue with the screen capture is something to watch out for if you are grabbing images for a report. It means rather than working through quickly and grabbing all the images you need as you go, you have to switch to another window and check the grabbed image and recapture if necessary. I hope Keysight fix this issue soon!
In the screen captures you can see the information about each channel which is displayed, i.e. The set voltage and current, the actual measured voltage and current, whether a 2-Wire or 4-Wire connection is used, and whether the channel is turned on or off. If I now press the Channel 1 select button again the display will change to give more detailed information for Channel 1 as shown below.
We can see that the Channel 1 area has now expanded to take up 2/3 of the display area with the Channel 2 and Channel 3 displays being condensed to show only their measured voltage and current and stacked on top of each other.
With this configuration the display shows a lot more information about the channel setup including over-current and over-voltage protection settings (OCP and OVP) as well as any delay settings relating to the OCP and also for turning the output On/Off.
Finally we see it now also displays the measured power in W too which is a really nice feature which should speed up things like generating efficiency curves for DC-DC converters (especially if I had a Keysight Bench DMM with a similar feature!) or checking the power consumption of a circuit quickly in various operating states.
Above I made a brief comment about showing whether 2-Wire or 4-Wire output modes are being used. In case you are not familiar with this terminology, I will explain further now.
  • 2-Wire simply means that only the + and - outputs of the PSU go directly to the load which means that depending on the load and the cables used there may be a significant voltage drop in the cables and the voltage measured at the supply output may not be what is presented to the load.
  • 4-Wire connections use an additional pair of wires as a "sense" connection. These carry no significant current so they measure the exact voltage at the load. This measurement is then used to adjust the powers supply output to compensate for the voltage drop in the cables to ensure the load sees the intended voltage. Please note: If you set 4-Wire and your sense wires aren't connected with some supplies it is possible to significantly over-voltage the load. I'll take a look at how this supply deals with this scenario in due course.
Those with eagle eyes (or generally anybody who has got this far and been paying attention!) will notice that the front panel doesn't have the capability available for 4-Wire connections. If you wish to use this mode of operation then you will need to make some cables up with the supplied terminal plugs and use the rear panel connectors.
4.2.1. Set Channel 1 to 5V with a 2.5A current limit.
We're starting from a clean slate with this so currently all the channels are set up with the default configuration so we can see that Channel 1 is the selected channel and is currently set to 0 Volts @ 10 Amps. In order to configure the voltage and current for this channel we simply press the button below the 'Source Settings' label to get to the source configuration screen for Channel 1.
Once in the 'Output 1 - Source Settings' screen we can see that there are a number of things that can be configured beyond just the basic voltage and current.
We can configure the various protection thresholds for over voltage (OVP) and over current (OVP) and we can configure delays for the over current protection. You'll notice that for the over current there are two possible delays, 'OCP Delay Start' and 'OCP Delay'. The reason for a separate start delay is so that during power up, where there is likely to be a significant inrush current we can increase the delay before the OCP trips to allow the system to power up correctly, but then once it's up and running we can introduce a faster OCP trip if desired. For our example we aren't looking at OVP and OCP so we'll leave these settings at their default values.
We can also choose between 2-Wire and 4-Wire connections in this screen. We'll be using the front panel connectors so we're going to leave the default 2-Wire setting.
Using the Up/Down/Enter buttons and the numeric pad we can now go ahead and enter the values for the desired output voltage and current limit.
Once everything has been set up the resulting screen should be as shown to the left.
Once we return to the main screen we can see that our new settings for Channel 1 are shown in the 'Set' boxes at the bottom of the Channel 1 display area.
You might have noticed that Channel 2 is now selected. This is because I selected this channel to move onto the next set of tests before I remembered to save the screenshot. It's not some random mode change or anything odd like that, it's just me almost forgetting to grab what I needed for this report.
4.2.2. Set Channel 2 and 3 to provide +9V and -9V rails which are tied together and tracking each other with a 1A current limit.
The same procedure as we used for Channel 1 above will be used for setting the desired voltage and current for channel 2. It's all very quick and intuitive to get set up and it would be very difficulte to get it wrong. If you try and set a voltage or current which is out of range it will tell you and there is visual feedback at every step at to what changes have been made.
Here I have configured Channel 2 to be 9V with a current limit of 1A.
Returning to the main screen we can see Channel 2 has the correct settings, but at the moment Channel 3 is not set up.
At this point we need to press the button below the 'Output Settings' label to take us to the configuration screen which will allow us to configure the modes available.
On this screen we can configure various options, On/Off delays, On/Off coupling, Inhibits and also the mode of operation.
For these examples we will ignore the delays, coupling, and inhibits and we'll come back to these later. For now we will look purely at the 'Operation Mode' option which allows us to select between four different modes as described in the next section.
If we press the button below the 'Operation Mode' label we will move to the screen below.
Here we can see several pieces of information:
  1. Down the right hand side is a summary of the current output settings.
  2. A large picture and description is shown in the main section which gives a picture of what is available at the various outputs along with information about exactly what is available from the various connections shown.
Along the bottom the button labels have changed to show the various possible modes:
  • Independent - The outputs are completely independent and can be set to any valid value for each output.
  • Series - The outputs are internally connected in series with the output voltage being across the positive pin of Channel 2 and the negative pin of  Channel 3.
  • Parallel - The outputs are internally connected in parallel with the output voltage being available on the Channel 2 output pins.
  • Tracking - Channel 3 is set to track the settings of Channel 2 so anything that happens to that channel will be reflected on Channel 3.
We want the outputs to track each other because we want a +/-9V set of power rails. In this case we've pressed the button below the 'Mode Tracking' label.
The picture and description below show us what is now available from the Channel 2 and Channel 3 outputs.
Pressing the 'Back' button we return to the main screen and can see that Channel 3 has now changed to show 9V as it is tracking Channel 2.
One thing to be wary of is that only the voltage setting is reflected when choosing tracking. I think it would be useful to be able to set the current limit based on the tracked channel too, this could avoid some annoying mistakes. It's always good to check these things before applying power, fortunately the way this information is presented with this unit makes it really easy and quick to spot these kinds of things.
We can correct the output current limit for Channel 3 by setting it in the same way we did for Channel 1 and Channel 2.
To the left we can see the result of setting the current on the 'Source Setting' screen for Channel 3.
Finally on the main page we can see that out outputs have now been correctly configured.
In order to achieve the +/-9V which we desire on the output we shall externally connect the positive of Channel 3 to the negative of Channel 2 and use this also as the 0V reference for our circuit. Channel 2 will now be our +9V supply and Channel 3 will now be our -9V supply.
4.2.3. Set Channel 2 and 3 to produce a single 48V rail with a 0.5A current limit.
In this setup we are going to be configuring the power supply to put Channel 2 and Channel 3 is series mode. This allows double the maximum output voltage of any one of these two channels. Of course we could do this with most decent bench power supplies with floating output channels simply by tying the positive of one channel to the negative of the other.
The beauty of the Keysight E36313A though is that connecting the outputs in series or parallel mode is all done internally so it gets configured correctly and doesn't rely on any external wiring which could be a point of failure (or mistake) in a test set up. Also in these modes, the main controls of channel 2 directly control the output voltage so no need to mess about setting multiple voltages and current limits. Simply set it how you want it as if it's a single power supply channel with those specs.
So when I did these setups, my head was in the usual mindset for setting up series outputs manually. In this case I set Channel 2 to be 24V at 0.5A first, intending to have to go and do this with Channel 3 also but once I had done this and selected 'Mode Series' below, I soon realised this wasn't necessary!
In the output setting window we can how choose 'Mode Series'. It will update the page to show how to connect to the supply in this instance and the limits of the combined channels. In this case we effectively have a single output channel which can supply up to 50V at a current of 2A which equates to 100W maximum.
Going back to the main page it clearly shows that the two outputs are connected together and shows the combined voltage and current setting for these channels as a whole. Very nice!
4.2.4. Set Channel 2 and 3 to produce a single 24V rail with a 4A current limit.
Much like we did above for connecting the two output channels in series, we can select parallel mode. In this mode the single resulting output channel is able to provide a maximum of 25V with a current of up to 4A which again equates to 100W maximum.
If I press the button to choose 'Mode Parallel' you can see the display has updated to show how we now connect to the supply. In this case we connect across the Channel 2 outputs and leave the Channel 3 outputs unconnected as these supplies are connected together in parallel internally.
Going back to the main screen we can see it has updated to show we are now in parallel mode.
We can see that we have the 24V @ 0.5A originally set on Channel 2 but paralleled up with the same setting on Channel 3 to give us a total of 1A on the combines Channel 2 output.
If we now go into the usual screen we can see that we can now set the current to 4A which is the combined maximum current of the two channels in parallel.
Finally back to the main screen and we can see the resulting setting with the Channel 2 and Channel 3 outputs combined into a single output and a clear indication it is in parallel mode.
4.3. The Web Interface
The image to the left shows the main view of the web interface on the unit once you have browsed to the unit on the network and logged in. As you can see it is an almost exact clone of the main layout of the front panel of the physical unit. The buttons on the unit correspond exactly to clickable buttons on the web interface so the way you operate the web interface and the way you operate the physical unit are almost identical. The only slight difference is there are buttons labelled with arrows for turning the control knobs up and down rather than having a gesturing method to allow the knobs to be operated more naturally. This would be a benefit if using the web interface on a tablet as it would enable a more natural feel when using a touchscreen. But this is a minor niggle really in an otherwise very clear user interface.
I would also like the option to be able to make the unit view full screen rather than it being only a part of a larger page. Again, if trying to use this interface from a tablet this would be a big advantage as currently it'll be a little more fiddly to use on the smaller screen with so much real estate taken up by non-critical information.
At the bottom of the screen below the unit to the left is a screen capture button. The purpose of this is to grab and save a BMP image of the current screen of the unit, i.e. it's a grab of the contents of the LCD screen area only, not an image of the whole front of the unit. I really like this idea and will help with documenting tests much more easily. Unfortunately there is a small niggle with this which is that the screen capture doesn't appear to use any double buffering so it will quite happily grab a screen capture mid update so if you have a reading which is not stable you can get a capture with a mix of numbers before/after update which is quite frustrating. This should have been spotted and fixed early on, preferable before the unit was released as it's quite an obvious bug. None the less, it's still an excellent feature which I will use a lot, even if I do have to grab a couple of extra shots each time to get one that's not got any refresh related image errors.
The other thing I would like to be able to do from this interface is specify a directory to download the captured screenshots as currently it just puts them into the browsers default download location. As well as this I would like to see them employing an image numbering system. With the current set up when I press the screen capture button the first time I get a file called screenshot.bmp. If I take another capture it creates a file called screenshot (1).bmp, then screenshot (2).bmp and so on. Maybe a better way would be to make the capture filename a combination of the unit's serial number and the current data/time such that even with multiple units available there would never be a conflict in the file names generated.
4.4. BenchVue
I had intended to take a look at how this supply integrates into KeySights BenchVue instrument control and automation suite. However, upon launching my Windows 10 virtual machine where I had previously installed an used the software I found it had disappeared which is totally weird. I then downloaded the installer for the latest BenchVue 2017 and tried to reinstall it and finally after about 4 hours it appeared to complete the installation, however upon looking for anything relating to BenchVue being installed I found almost nothing except for the BenchVue FieldFox app, none of the other apps and not the main application. Again, this was totally weird and disappointing. Fortunately I was able to resurrect a Windows 7 virtual machine from elsewhere and I found on this that BenchVue 2017 installed quite happily and comparatively quickly. Happy days!
Unfortunately the happy feeling only lasted a short while. After loading the latest version of BenchVue I found that the majority of the modules for it are now only available at cost with the addition of Pro licenses. This is not a change I particularly like as the earlier version of BenchVue I had gave access to feature limited versions of the various modules so you could at least get a feel for its operation. I have this power supply, my oscilloscope and my multimeter, all of which are separate modules so the cost to buy these is significant. There is a trial version available for each of these but as I don't know how I might wish to use this yet I don't want to start the trial until such time as I am ready to invest some serious time into investigating and setting up BenchVue.
4.4.1. External Links
BenchVue Software 2017 Technical Overview: http://literature.cdn.keysight.com/litweb/pdf/5991-3850EN.pdf
BenchVue Software 2017 Platform Website: https://www.keysight.com/main/software.jspx?ckey=2417463
5. Lets Do Some Experiments!
5.1. Powering-up the unit, how fast does it start?
The first thing I noticed when I powered up the unit was that even though it's a smart power supply with a processor running a network stack and providing a web interface and various programmable options, as well as supporting a modern user interface with a large LCD, it powers up and is ready to use within just a few seconds. Below is a video showing the overall boot up speed of the unit.
So as you can see, from me starting the camera recording, pressing the button to switch on the power supply to me stopping the recording, it's only 10 seconds in total, the power supply booting up is only a few of those seconds which is very nice. Nice one Keysight!
5.2. Testing the Voltage and Current Capabilities
5.2.1. Test Overview
For this test I am going to use my DC electronic load which is a TTi LD300. This can support up to 80V input and up to 80A within a total power dissipation of 300W. For testing the outputs of the Keysight E36313A I will use the 80A constant current range to enable me to load Channel 1 of the power supply to 10A and I will use the 8A constant current range to load Channel 2 and Channel 3 of the power supply in their various independent, series, and parallel modes.
The following tests are going to be performed on the Keysight E36313A only as we can assume that the TTi units perform to their load specs. I have used these for a number of years and I know they work as advertised in this respect.
5.2.2. Set Channel 1 to 6V and Load with an Increasing Current up to 10A
Keysight E36313A ConfigurationKeysight E36313A Results
The voltage of the channel was set to 6V and the current limit was set to 10A. Initially the output was unloaded and the voltage was measured using my Keysight U1272A Digital Multi Meter. The following table shows the results obtained from varying the load from 0A up to 10A.
Condition
Result
6V, No LoadPass - Measured 6.003V on DMM
6V, 1A LoadPass
6V, 2A LoadPass
6V, 5A LoadPass
6V, 10A LoadPass - Measured 5.895V on DMM
6V, Over LoadPass - Measured 1V on the DMM
5.2.3. Set Channel 2 and Channel 3 to 25V and Load Each with an Increasing Current up to 2A
The voltage of the channel was set to 25V and the current limit was set to 2A. Initially the output was unloaded and the voltage was measured using my Keysight U1272A Digital Multi Meter. The following table shows the results obtained from varying the load from 0A up to 2A.
Condition
Result
25V, No LoadPass - Measured 25.013V on DMM
25V, 200mA LoadPass
25V, 500mA LoadPass
25V, 1A LoadPass
25V, 2A LoadPass - Measured 24.994V on DMM
25V, Over LoadPass - Measured 0.175V on the DMM
Condition
Result
25V, No LoadPass - Measured 25.012V on DMM
25V, 200mA LoadPass
25V, 500mA LoadPass
25V, 1A LoadPass
25V, Over LoadPass - Measured 0.174V on the DMM
5.2.4. Set Channels 2 and 3 into Serial Mode and to 50V and Load with an Increasing Load up to 2A
Channels 2 and 3 were put into serial mode and the voltage of the combined channel was set to 50V and the current limit was set to 2A. Initially the output was unloaded and the voltage was measured using my Keysight U1272A Digital Multi Meter. The following table shows the results obtained from varying the load from 0A up to 2A.
Header 1Header 2
50V, No LoadPass - Measured 50.01V on DMM
50V, 200mA LoadPass
50V, 500mA LoadPass
50V, 1A LoadPass
50V, 2A LoadPass - Measured 49.97 on DMM
50V, Over LoadPass - Measured 24.7 on DMM
5.2.5. Set Channels 2 and 3 into Parallel Mode and to 25V and Load with an Increasing Load up to 4A
Channels 2 and 3 were put into parallel mode and the voltage of the combined channel was set to 25 and the current limit was set to 4A. Initially the output was unloaded and the voltage was measured using my Keysight U1272A Digital Multi Meter. The following table shows the results obtained from varying the load from 0A up to 4A.
Header 1Header 2
25V, 500mA LoadPass
25V, 1A LoadPass
25V, 2A LoadPass
25V, 4A LoadPass - Measured 24.945V on DMM
25V, Over LoadPass - Measured 0.379V on DMM
5.2.6. Analysis of the Results
Testing under various loads with the maximum voltages available on each channel and the Keysight E36313A didn't miss a beat. It works as expected and was very easy to reconfigure for each test.
5.3. Looking at the regulation under load, light load and transient load conditions
5.3.1. Test Overview
This this test I am just going to compare the Channel 1 output of the Keysight E36313A with the TTi CPX400S and the Channel 2 output with Channel 1 of the TTi PL303QMD. I'll take a look at the ripple and stability of each of the outputs on my Keysight MSOX3054A Oscilloscope using an AC coupled voltage probe when loaded up the outputs with my TTi LD300 electronic load. I will used the web interface available with the LAN Option for the Oscilloscope to capture the resulting waveforms.
5.3.2. Set Channel 1 of the Keysight E36313A and the CPX400S to 5V with a 10A Current Limit and Set the Load to 1A.
Keysight E36313A ConfigurationKeysight E36313A ResultsTTi CPX400S Results
5.3.3. Set Channel 1 of the Keysight E36313A and the CPX400S to 5V with a 10A Current Limit and Set the Load to 10A.
5.3.4. Set Channel 1 of the Keysight E36313A and the CPX400S to 5V with a 10A Current Limit and Set a Step Load from 1A to 10A.
5.3.5. Set Channel 2 of the Keysight E36313A and Channel 1 of the PL303QMD to 25V with a 2A Current Limit and Set the Load to 200mA.
Keysight E36313A ConfigurationKeysight E36313A ResultsTTi PL303QMD Results
5.3.6. Set Channel 2 of the Keysight E36313A and Channel 1 of the PL303QMD to 25V with a 2A Current Limit and Set the Load to 2A.
5.3.7. Set Channel 2 of the Keysight E36313A and Channel 1 of the PL303QMD to 15V with a 2A Current Limit and Set a Step Load from 200mA to 2A.
5.3.8. Analysis of the Results
We can see from the results that all three supplies are very good. The Keysight E36313A has strong performance in all the tests, beating the TTi CPX400S in the transient load and output noise measurements, where the TTi CPX400S had some noticeable regular switching spikes which increased with current. At the higher voltage and lower current tests the Keysight E36313A performed roughly on a par with the TTi PL303QMD, having slightly more excursion low but slightly less excursion high on the transient voltage test.
Under 200ma/2A transient load test the TTi power supply would run but would occasionally trip even though I had actually set the current limit to a little over 2A. They Keysight E36313A did not trip out during this test at all.
5.4. FFT analysis of the fully loaded output
5.4.1. Test Overview
For this test I will look at just the single output with 1A and 10A load conditions setup from the previous tests and using the FFT function of my Keysight MSOX3054A I will attempt to see if there are any noticeable peaks in the spectrum which are dependant on load which are detectable within the capabilities of my oscilloscope. I will used the web interface available with the LAN Option for the Oscilloscope to capture the resulting waveforms.
5.4.2. Set Channel 1 of the Keysight E36313A and the CPX400S to 5V with a 10A Current Limit and Set the Load to 1A.
5.4.3. Set Channel 1 of the Keysight E36313A and the CPX400S to 5V with a 10A Current Limit and Set the Load to 10A.
5.4.4. Analysis of the Results
Looking at the results we can see that the TTi CPX400S has got a higher peak at 125MHz and additional spurs at 187.5MHz, 200MHz, 212.5MHz and 225MHz which are either not present or at a much lower level on the output of the Keysight E36313A. These likely correlate with the edge speed of the switching noise we saw in the previous output noise tests but without further investigation I cannot be sure.
We can also see from the FFT that there are spurs in the 85MHz to 105MHz range for all tests and all equipment. These are present even under no load and with the output disabled on both units, I think these are actually artefacts which are caused by some digital data being picked up from elsewhere. I haven't tracked down from exactly where yet but if we look at the following images you can see the regularity of the bursts and with the zoomed image we can see something which looks like it might be in the 20MHz-25MHz range. It's obviously very hard to see the details of the data streams from a spurious waveform captured on my oscilloscope.
5.5. Testing out the data logging
5.5.1. Test Overview
For this test I will be capturing a set of data over time and recording it to a file which I will then import into a spreadsheet application to perform some graphing of the results. I have chosen to log the Voltage, Current and Power measurements when booting up a Raspberry Pi Model B and running some benchmark tests. For my tests I will be performing 5 separate actions
  1. Booting up the Raspberry Pi from powered off and logging in.
  2. Running a sysbench benchmark on the CPU to calculate prime numbers.
    sysbench --test=cpu --cpu-max-prime=2000 run
  3. Running a sysbench benchmark on the Memory to write 2GB of data.
    sysbench --test=memory run --memory-total-size=2G
  4. Running a sysbench benchmark on the Memory to read 2GB of data.
    sysbench --test=memory run --memory-total-size=2G --memory-oper=read
  5. Shutting down and powering off the Raspberry Pi.
    sudo shutdown -HP now
5.5.2. Performing the Tests
The unit comes with a relatively straight forward to use data logger. You can configure what values are captured, i.e. V/I/P from Channels 1/2/3, you can configure how long it captures for, how often it samples the data etc. As it's logging it will show you the waveform of the log in a graph which is like a little oscilloscope with a slow time base. You need a USB stick to capture the data and you can save it in a binary dlog format and also in CSV format.
5.5.3. Test Data Collected
The following image shows the log view of the data collected:
I also captured the log data into a CSV file:
E36313A exported datalog
File type: CSV
"Sample interval: 0.200000"
"Number of sample: 1026/1650"
"Trigger sample: 0"
"Date: 2017/12/19 14:28:28"
"V1: 5.000000, -7.500000"
"I1: 0.200000, 0.150000"
"P1: 1.000000, 2.781250"
"V2: 5.000000, 0.000000"
"I2: 1.000000, 0.000000"
"P2: 2.000000, 0.000000"
"V3: 5.000000, 0.000000"
"I3: 1.000000, 0.000000"
"P3: 2.000000, 0.000000"
Sample,"Volt avg 1","Curr avg 1"
0,0.001310,0.000070
1,0.001310,0.000070
2,0.001310,0.000070
3,0.001310,0.000070
4,0.001310,0.000070
5,0.001310,0.000070
6,0.001310,0.000070
7,0.001310,0.000070
8,4.999190,0.084240
9,5.000390,0.113180
10,5.000590,0.095300
11,5.000590,0.076760
12,5.000590,0.102770
13,5.000590,0.098550
14,5.000590,0.067660
15,5.000590,0.098220
16,5.000590,0.104070
17,5.000590,0.107650
18,5.000590,0.082940
19,5.000790,0.067330
20,5.000590,0.067330
21,5.000590,0.067330
22,5.000590,0.067330
23,5.000590,0.074490
24,5.000590,0.127810
25,5.000590,0.127810
26,5.000590,0.128130
27,5.000590,0.121630
28,5.000590,0.141140
29,5.000590,0.111550
30,5.000590,0.149920
31,5.000590,0.156750
32,5.000590,0.157070
33,5.000590,0.115780
34,5.000590,0.115780
35,5.000590,0.115780
36,5.000590,0.115780
37,5.000590,0.187960
38,5.000590,0.227950
39,5.000790,0.194140
40,5.000590,0.242910
41,5.000590,0.259490
42,5.000590,0.281270
43,5.000590,0.288100
44,5.000590,0.277040
45,5.000590,0.278350
46,5.000590,0.277690
47,5.000590,0.278020
48,5.000590,0.262410
49,5.000590,0.323210
50,5.000590,0.279970
51,5.000590,0.280950
52,5.000790,0.307280
53,5.000790,0.280950
54,5.000590,0.269570
55,5.000790,0.271190
56,5.000590,0.270220
57,5.000790,0.255590
58,5.000590,0.260460
59,5.000590,0.267940
60,5.000790,0.280620
61,5.000790,0.250060
62,5.000790,0.264690
63,5.000590,0.261110
64,5.000590,0.251360
65,5.000590,0.251360
66,5.000590,0.251030
67,5.000790,0.258190
68,5.000790,0.249730
69,5.000590,0.262740
70,5.000590,0.261440
71,5.000790,0.253640
72,5.000590,0.259810
73,5.000590,0.278350
74,5.000790,0.240300
75,5.000590,0.251030
76,5.000790,0.266640
77,5.000590,0.253960
78,5.000590,0.258190
79,5.000590,0.254940
80,5.000790,0.267290
81,5.000590,0.251030
82,5.000590,0.259160
83,5.000590,0.246810
84,5.000590,0.262090
85,5.000590,0.252330
86,5.000790,0.257210
87,5.000790,0.252010
88,5.000790,0.251360
89,5.000790,0.253640
90,5.000590,0.254940
91,5.000590,0.245830
92,5.000590,0.235430
93,5.000590,0.234780
94,5.000790,0.235430
95,5.000590,0.237380
96,5.000590,0.271520
97,5.000590,0.247130
98,5.000590,0.235430
99,5.000590,0.235430
100,5.000790,0.252010
101,5.000590,0.236730
102,5.000790,0.250060
103,5.000790,0.252010
104,5.000790,0.260790
105,5.000790,0.250060
106,5.000590,0.254610
107,5.000590,0.256890
108,5.000590,0.278020
109,5.000790,0.257210
110,5.000590,0.245830
111,5.000790,0.258840
112,5.000590,0.250380
113,5.000590,0.252010
114,5.000590,0.238030
115,5.000590,0.249730
116,5.000590,0.254940
117,5.000790,0.239980
118,5.000590,0.252980
119,5.000790,0.250380
120,5.000590,0.236400
121,5.000590,0.251030
122,5.000790,0.268920
123,5.000590,0.250380
124,5.000590,0.259490
125,5.000790,0.261440
126,5.000590,0.252660
127,5.000590,0.242580
128,5.000590,0.252980
129,5.000590,0.254940
130,5.000590,0.258190
131,5.000590,0.260790
132,5.000590,0.257210
133,5.000790,0.240950
134,5.000790,0.235100
135,5.000590,0.250380
136,5.000590,0.240630
137,5.000590,0.251360
138,5.000590,0.253960
139,5.000590,0.260460
140,5.000790,0.251680
141,5.000790,0.250710
142,5.000590,0.241280
143,5.000590,0.272170
144,5.000590,0.235430
145,5.000790,0.235100
146,5.000590,0.235430
147,5.000590,0.237050
148,5.000590,0.240300
149,5.000590,0.235100
150,5.000590,0.248110
151,5.000590,0.248760
152,5.000590,0.235100
153,5.000790,0.248430
154,5.000590,0.268590
155,5.000590,0.269570
156,5.000790,0.227950
157,5.000590,0.211040
158,5.000790,0.210720
159,5.000590,0.210720
160,5.000590,0.210720
161,5.000590,0.210720
162,5.000590,0.210720
163,5.000590,0.210720
164,5.000590,0.210720
165,5.000590,0.211040
166,5.000590,0.210720
167,5.000590,0.211040
168,5.000590,0.210720
169,5.000590,0.210720
170,5.000590,0.210390
171,5.000590,0.210720
172,5.000590,0.210390
173,5.000590,0.210720
174,5.000590,0.211040
175,5.000590,0.210720
176,5.000590,0.210720
177,5.000590,0.211040
178,5.000590,0.210720
179,5.000790,0.210720
180,5.000790,0.210390
181,5.000590,0.210390
182,5.000590,0.210720
183,5.000590,0.210720
184,5.000590,0.210720
185,5.000590,0.211040
186,5.000590,0.211370
187,5.000590,0.210720
188,5.000590,0.211370
189,5.000590,0.210720
190,5.000590,0.210390
191,5.000590,0.280620
192,5.000590,0.279970
193,5.000590,0.279650
194,5.000590,0.281270
195,5.000590,0.280620
196,5.000590,0.279320
197,5.000590,0.280620
198,5.000590,0.279000
199,5.000590,0.279000
200,5.000590,0.225020
201,5.000590,0.210390
202,5.000590,0.211040
203,5.000790,0.210720
204,5.000590,0.210720
205,5.000590,0.210720
206,5.000590,0.211040
207,5.000590,0.210720
208,5.000590,0.210390
209,5.000590,0.210720
210,5.000590,0.210720
211,5.000590,0.210720
212,5.000590,0.211040
213,5.000590,0.210720
214,5.000590,0.210720
215,5.000590,0.210720
216,5.000590,0.210720
217,5.000590,0.210720
218,5.000590,0.210720
219,5.000590,0.210720
220,5.000590,0.210720
221,5.000590,0.210720
222,5.000590,0.211040
223,5.000590,0.211040
224,5.000590,0.210720
225,5.000590,0.211040
226,5.000590,0.210720
227,5.000590,0.210390
228,5.000590,0.210720
229,5.000790,0.210720
230,5.000790,0.210720
231,5.000790,0.210720
232,5.000790,0.210720
233,5.000790,0.210720
234,5.000790,0.210720
235,5.000790,0.210720
236,5.000790,0.210720
237,5.000590,0.210720
238,5.000590,0.210720
239,5.000590,0.210720
240,5.000590,0.210720
241,5.000590,0.281920
242,5.000590,0.279970
243,5.000590,0.279650
244,5.000590,0.279320
245,5.000590,0.279320
246,5.000590,0.279320
247,5.000590,0.279320
248,5.000590,0.279320
249,5.000590,0.279320
250,5.000590,0.279320
251,5.000590,0.279320
252,5.000590,0.211040
253,5.000590,0.211040
254,5.000590,0.210720
255,5.000590,0.211040
256,5.000590,0.211040
257,5.000590,0.211040
258,5.000590,0.210720
259,5.000590,0.210720
260,5.000590,0.210720
261,5.000590,0.210720
262,5.000590,0.210720
263,5.000590,0.210720
264,5.000590,0.210720
265,5.000590,0.210720
266,5.000590,0.214940
267,5.000790,0.224700
268,5.000590,0.210720
269,5.000590,0.210720
270,5.000590,0.210720
271,5.000590,0.210720
272,5.000590,0.211040
273,5.000590,0.210720
274,5.000590,0.210720
275,5.000590,0.210720
276,5.000590,0.210720
277,5.000590,0.210720
278,5.000590,0.210720
279,5.000590,0.210720
280,5.000590,0.210720
281,5.000590,0.210720
282,5.000590,0.211370
283,5.000590,0.253960
284,5.000590,0.241930
285,5.000590,0.305980
286,5.000590,0.305980
287,5.000590,0.262740
288,5.000590,0.212340
289,5.000590,0.212340
290,5.000590,0.212340
291,5.000590,0.212340
292,5.000590,0.212340
293,5.000590,0.212340
294,5.000590,0.212340
295,5.000590,0.212340
296,5.000590,0.212340
297,5.000590,0.279650
298,5.000590,0.281270
299,5.000590,0.279970
300,5.000590,0.279320
301,5.000590,0.225020
302,5.000590,0.211040
303,5.000590,0.211370
304,5.000590,0.211040
305,5.000590,0.211040
306,5.000590,0.211040
307,5.000590,0.211040
308,5.000590,0.211040
309,5.000590,0.211040
310,5.000590,0.211040
311,5.000590,0.211040
312,5.000590,0.225350
313,5.000590,0.211040
314,5.000590,0.210720
315,5.000790,0.211040
316,5.000590,0.210720
317,5.000590,0.211370
318,5.000590,0.211040
319,5.000590,0.211040
320,5.000590,0.211040
321,5.000590,0.211040
322,5.000590,0.211040
323,5.000590,0.211040
324,5.000590,0.211040
325,5.000590,0.211040
326,5.000590,0.225670
327,5.000590,0.210720
328,5.000590,0.210720
329,5.000590,0.211040
330,5.000590,0.210720
331,5.000590,0.211370
332,5.000590,0.211370
333,5.000590,0.210720
334,5.000590,0.210390
335,5.000590,0.210390
336,5.000590,0.210390
337,5.000590,0.210390
338,5.000590,0.210390
339,5.000590,0.210390
340,5.000590,0.210390
341,5.000590,0.210390
342,5.000590,0.248760
343,5.000790,0.261110
344,5.000790,0.269240
345,5.000590,0.250060
346,5.000590,0.235430
347,5.000590,0.250710
348,5.000790,0.251030
349,5.000590,0.251030
350,5.000590,0.251030
351,5.000590,0.251030
352,5.000590,0.251030
353,5.000590,0.251030
354,5.000590,0.251030
355,5.000590,0.251030
356,5.000590,0.251030
357,5.000590,0.210720
358,5.000590,0.211040
359,5.000790,0.210720
360,5.000590,0.210720
361,5.000590,0.211040
362,5.000590,0.210720
363,5.000590,0.211370
364,5.000590,0.211370
365,5.000590,0.211370
366,5.000590,0.211370
367,5.000590,0.211370
368,5.000590,0.211370
369,5.000590,0.211370
370,5.000590,0.211370
371,5.000590,0.210720
372,5.000590,0.210720
373,5.000590,0.210720
374,5.000590,0.210720
375,5.000590,0.225020
376,5.000590,0.211370
377,5.000590,0.211040
378,5.000590,0.211040
379,5.000590,0.211040
380,5.000590,0.211040
381,5.000590,0.211040
382,5.000590,0.211040
383,5.000590,0.211040
384,5.000590,0.211040
385,5.000590,0.211040
386,5.000790,0.241610
387,5.000590,0.241280
388,5.000590,0.241610
389,5.000590,0.241280
390,5.000590,0.241280
391,5.000590,0.241280
392,5.000790,0.241610
393,5.000590,0.241610
394,5.000590,0.241610
395,5.000590,0.241610
396,5.000590,0.241610
397,5.000590,0.241610
398,5.000590,0.241610
399,5.000590,0.241610
400,5.000590,0.241610
401,5.000590,0.241610
402,5.000590,0.241280
403,5.000590,0.241280
404,5.000590,0.241280
405,5.000590,0.241280
406,5.000590,0.241280
407,5.000590,0.241280
408,5.000590,0.241280
409,5.000590,0.241280
410,5.000590,0.241280
411,5.000590,0.241280
412,5.000590,0.241610
413,5.000590,0.241610
414,5.000790,0.241610
415,5.000590,0.241610
416,5.000590,0.241280
417,5.000790,0.241280
418,5.000590,0.311830
419,5.000590,0.311830
420,5.000590,0.311830
421,5.000590,0.311830
422,5.000590,0.311830
423,5.000590,0.311830
424,5.000590,0.311830
425,5.000590,0.311830
426,5.000590,0.250060
427,5.000590,0.241280
428,5.000590,0.241610
429,5.000590,0.241610
430,5.000590,0.241610
431,5.000590,0.241610
432,5.000590,0.241610
433,5.000590,0.241280
434,5.000590,0.241280
435,5.000590,0.241280
436,5.000590,0.241280
437,5.000590,0.241280
438,5.000590,0.241280
439,5.000590,0.241280
440,5.000590,0.241280
441,5.000590,0.241610
442,5.000590,0.241610
443,5.000590,0.245830
444,5.000590,0.241610
445,5.000590,0.241610
446,5.000590,0.241610
447,5.000590,0.241610
448,5.000590,0.241280
449,5.000590,0.241280
450,5.000590,0.241280
451,5.000590,0.241280
452,5.000590,0.241280
453,5.000590,0.241280
454,5.000590,0.241280
455,5.000590,0.241280
456,5.000590,0.241280
457,5.000590,0.241280
458,5.000590,0.241610
459,5.000590,0.241610
460,5.000590,0.241610
461,5.000590,0.241610
462,5.000590,0.241610
463,5.000590,0.241280
464,5.000590,0.241280
465,5.000590,0.241280
466,5.000590,0.241280
467,5.000590,0.241280
468,5.000590,0.241280
469,5.000590,0.241280
470,5.000590,0.241280
471,5.000590,0.241280
472,5.000590,0.241610
473,5.000590,0.241610
474,5.000590,0.241610
475,5.000790,0.241610
476,5.000590,0.241280
477,5.000590,0.241610
478,5.000590,0.241610
479,5.000590,0.241610
480,5.000590,0.241610
481,5.000590,0.241610
482,5.000590,0.241610
483,5.000590,0.241610
484,5.000590,0.241610
485,5.000590,0.241610
486,5.000590,0.241280
487,5.000590,0.241280
488,5.000590,0.241610
489,5.000590,0.241610
490,5.000590,0.241610
491,5.000590,0.241610
492,5.000590,0.241610
493,5.000590,0.312160
494,5.000590,0.312160
495,5.000590,0.312160
496,5.000590,0.312160
497,5.000590,0.312160
498,5.000590,0.312160
499,5.000590,0.312160
500,5.000590,0.312160
501,5.000590,0.241610
502,5.000590,0.241610
503,5.000590,0.241610
504,5.000790,0.241610
505,5.000590,0.241610
506,5.000590,0.241610
507,5.000590,0.241610
508,5.000590,0.241280
509,5.000590,0.241280
510,5.000590,0.241280
511,5.000590,0.241280
512,5.000590,0.241280
513,5.000590,0.241280
514,5.000590,0.241280
515,5.000590,0.241280
516,5.000590,0.241610
517,5.000590,0.238030
518,5.000590,0.238350
519,5.000590,0.241610
520,5.000590,0.241610
521,5.000590,0.241610
522,5.000590,0.241280
523,5.000590,0.241610
524,5.000590,0.241610
525,5.000590,0.241610
526,5.000590,0.241610
527,5.000590,0.241610
528,5.000590,0.241610
529,5.000590,0.241610
530,5.000590,0.241610
531,5.000590,0.241610
532,5.000590,0.241610
533,5.000590,0.241280
534,5.000590,0.241610
535,5.000590,0.241280
536,5.000590,0.241610
537,5.000590,0.241610
538,5.000590,0.241610
539,5.000590,0.241610
540,5.000590,0.241610
541,5.000590,0.241610
542,5.000590,0.241610
543,5.000590,0.241610
544,5.000590,0.241610
545,5.000590,0.241610
546,5.000590,0.241610
547,5.000590,0.241610
548,5.000590,0.255590
549,5.000590,0.241610
550,5.000790,0.241610
551,5.000590,0.241610
552,5.000590,0.241280
553,5.000590,0.241280
554,5.000590,0.241280
555,5.000590,0.241280
556,5.000590,0.241280
557,5.000590,0.241280
558,5.000590,0.241280
559,5.000590,0.241280
560,5.000590,0.241280
561,5.000590,0.241610
562,5.000590,0.241280
563,5.000590,0.264360
564,5.000590,0.263710
565,5.000590,0.225020
566,5.000590,0.210720
567,5.000590,0.210720
568,5.000590,0.210720
569,5.000590,0.210720
570,5.000590,0.210720
571,5.000590,0.210720
572,5.000590,0.210720
573,5.000590,0.210720
574,5.000590,0.210720
575,5.000590,0.210720
576,5.000590,0.210720
577,5.000590,0.232180
578,5.000590,0.210720
579,5.000590,0.212020
580,5.000590,0.210720
581,5.000590,0.211040
582,5.000590,0.211040
583,5.000590,0.210720
584,5.000590,0.210720
585,5.000590,0.210720
586,5.000590,0.210720
587,5.000590,0.210720
588,5.000590,0.210720
589,5.000590,0.210720
590,5.000590,0.210720
591,5.000590,0.210720
592,5.000790,0.211040
593,5.000590,0.210720
594,5.000590,0.210720
595,5.000590,0.210720
596,5.000590,0.210720
597,5.000590,0.210720
598,5.000590,0.210720
599,5.000590,0.210720
600,5.000590,0.210720
601,5.000590,0.210720
602,5.000590,0.210720
603,5.000590,0.210720
604,5.000590,0.210720
605,5.000590,0.210720
606,5.000590,0.247130
607,5.000590,0.246810
608,5.000590,0.247130
609,5.000590,0.247130
610,5.000590,0.246810
611,5.000590,0.247130
612,5.000590,0.247130
613,5.000590,0.246810
614,5.000590,0.246810
615,5.000590,0.246810
616,5.000590,0.246810
617,5.000590,0.246810
618,5.000590,0.246810
619,5.000590,0.246810
620,5.000590,0.246810
621,5.000590,0.246810
622,5.000590,0.247130
623,5.000590,0.247130
624,5.000590,0.247130
625,5.000590,0.246810
626,5.000590,0.247130
627,5.000590,0.247130
628,5.000590,0.247130
629,5.000590,0.247130
630,5.000590,0.247130
631,5.000590,0.247130
632,5.000590,0.247130
633,5.000590,0.247130
634,5.000590,0.247130
635,5.000590,0.247130
636,5.000590,0.246810
637,5.000590,0.247130
638,5.000590,0.247130
639,5.000590,0.247130
640,5.000790,0.247130
641,5.000590,0.247130
642,5.000590,0.247130
643,5.000590,0.246810
644,5.000590,0.247130
645,5.000590,0.247130
646,5.000590,0.247130
647,5.000590,0.247130
648,5.000590,0.247130
649,5.000590,0.247130
650,5.000590,0.247130
651,5.000590,0.247130
652,5.000590,0.247130
653,5.000590,0.247130
654,5.000790,0.247130
655,5.000590,0.247130
656,5.000790,0.247130
657,5.000590,0.247130
658,5.000590,0.247130
659,5.000590,0.247130
660,5.000590,0.247130
661,5.000590,0.247130
662,5.000590,0.247130
663,5.000590,0.247130
664,5.000590,0.247130
665,5.000590,0.247130
666,5.000590,0.247130
667,5.000590,0.247130
668,5.000790,0.247130
669,5.000590,0.247460
670,5.000590,0.317360
671,5.000590,0.316060
672,5.000590,0.315740
673,5.000590,0.261110
674,5.000590,0.247130
675,5.000590,0.247130
676,5.000590,0.247130
677,5.000590,0.247130
678,5.000590,0.247130
679,5.000590,0.247130
680,5.000590,0.247130
681,5.000590,0.247130
682,5.000590,0.246810
683,5.000590,0.246810
684,5.000590,0.247130
685,5.000590,0.247130
686,5.000590,0.247130
687,5.000590,0.247130
688,5.000590,0.247130
689,5.000590,0.247130
690,5.000590,0.247130
691,5.000590,0.247130
692,5.000590,0.247130
693,5.000590,0.247130
694,5.000590,0.247130
695,5.000590,0.247130
696,5.000590,0.247130
697,5.000590,0.247130
698,5.000590,0.249410
699,5.000590,0.247130
700,5.000590,0.247130
701,5.000590,0.247130
702,5.000590,0.247130
703,5.000590,0.247130
704,5.000590,0.247130
705,5.000590,0.247130
706,5.000590,0.247130
707,5.000590,0.247130
708,5.000590,0.247130
709,5.000590,0.247130
710,5.000590,0.247130
711,5.000590,0.247130
712,5.000590,0.247130
713,5.000590,0.247130
714,5.000590,0.247130
715,5.000590,0.247130
716,5.000590,0.247130
717,5.000590,0.247130
718,5.000590,0.247130
719,5.000590,0.247130
720,5.000590,0.247130
721,5.000590,0.247130
722,5.000590,0.247130
723,5.000590,0.247130
724,5.000590,0.247130
725,5.000590,0.247130
726,5.000590,0.247130
727,5.000590,0.247130
728,5.000590,0.262740
729,5.000590,0.242910
730,5.000590,0.211040
731,5.000590,0.210720
732,5.000790,0.210720
733,5.000590,0.210720
734,5.000590,0.210720
735,5.000590,0.210720
736,5.000590,0.210720
737,5.000590,0.210720
738,5.000590,0.210720
739,5.000590,0.210720
740,5.000590,0.210720
741,5.000590,0.210720
742,5.000590,0.210720
743,5.000590,0.210720
744,5.000590,0.210720
745,5.000590,0.211040
746,5.000590,0.211040
747,5.000590,0.210720
748,5.000590,0.210720
749,5.000590,0.210720
750,5.000590,0.210720
751,5.000590,0.210720
752,5.000590,0.210720
753,5.000590,0.210720
754,5.000590,0.210720
755,5.000590,0.210720
756,5.000590,0.210720
757,5.000590,0.211040
758,5.000590,0.210720
759,5.000590,0.210720
760,5.000590,0.210720
761,5.000590,0.210390
762,5.000590,0.210720
763,5.000590,0.211040
764,5.000590,0.211040
765,5.000590,0.211040
766,5.000590,0.211040
767,5.000590,0.211040
768,5.000590,0.211040
769,5.000590,0.211040
770,5.000590,0.211040
771,5.000590,0.211040
772,5.000590,0.210720
773,5.000590,0.211040
774,5.000590,0.211040
775,5.000590,0.210720
776,5.000590,0.210720
777,5.000590,0.276070
778,5.000590,0.234780
779,5.000590,0.234780
780,5.000590,0.234780
781,5.000590,0.234780
782,5.000590,0.234780
783,5.000590,0.234780
784,5.000590,0.234780
785,5.000590,0.234780
786,5.000590,0.234780
787,5.000590,0.234780
788,5.000590,0.234780
789,5.000590,0.234780
790,5.000590,0.234780
791,5.000590,0.234780
792,5.000590,0.235100
793,5.000590,0.234780
794,5.000590,0.234780
795,5.000590,0.234780
796,5.000590,0.234780
797,5.000590,0.234780
798,5.000590,0.234780
799,5.000590,0.234780
800,5.000590,0.234780
801,5.000590,0.235100
802,5.000590,0.234780
803,5.000590,0.234780
804,5.000590,0.234780
805,5.000590,0.234780
806,5.000590,0.234780
807,5.000590,0.234780
808,5.000590,0.234780
809,5.000590,0.234780
810,5.000590,0.234780
811,5.000590,0.234780
812,5.000590,0.234780
813,5.000590,0.234780
814,5.000590,0.234780
815,5.000590,0.234780
816,5.000590,0.234780
817,5.000590,0.234780
818,5.000590,0.234780
819,5.000590,0.234780
820,5.000590,0.234780
821,5.000590,0.234780
822,5.000590,0.234780
823,5.000590,0.234780
824,5.000590,0.234780
825,5.000590,0.234780
826,5.000590,0.234780
827,5.000590,0.234780
828,5.000590,0.234780
829,5.000590,0.235100
830,5.000590,0.234780
831,5.000590,0.234780
832,5.000590,0.234780
833,5.000590,0.234780
834,5.000590,0.234780
835,5.000590,0.234780
836,5.000590,0.234780
837,5.000590,0.234780
838,5.000590,0.234780
839,5.000590,0.234780
840,5.000590,0.234780
841,5.000590,0.234780
842,5.000590,0.234780
843,5.000590,0.234780
844,5.000590,0.234780
845,5.000590,0.234780
846,5.000590,0.234780
847,5.000590,0.234780
848,5.000590,0.234780
849,5.000590,0.234780
850,5.000590,0.234780
851,5.000590,0.234780
852,5.000590,0.234780
853,5.000590,0.234780
854,5.000590,0.234780
855,5.000590,0.234780
856,5.000590,0.234780
857,5.000790,0.234780
858,5.000590,0.234780
859,5.000590,0.234780
860,5.000590,0.234780
861,5.000590,0.234780
862,5.000590,0.234780
863,5.000590,0.234780
864,5.000590,0.234780
865,5.000590,0.234780
866,5.000590,0.234780
867,5.000590,0.234780
868,5.000590,0.234780
869,5.000590,0.234780
870,5.000590,0.234780
871,5.000590,0.234780
872,5.000590,0.234780
873,5.000590,0.234780
874,5.000590,0.234780
875,5.000590,0.234780
876,5.000590,0.234780
877,5.000590,0.234780
878,5.000590,0.235100
879,5.000590,0.234780
880,5.000590,0.234780
881,5.000590,0.234780
882,5.000590,0.234780
883,5.000590,0.234780
884,5.000590,0.234780
885,5.000590,0.234780
886,5.000590,0.234780
887,5.000790,0.210720
888,5.000590,0.210720
889,5.000790,0.210720
890,5.000590,0.211040
891,5.000590,0.211040
892,5.000590,0.210720
893,5.000790,0.210720
894,5.000790,0.210720
895,5.000790,0.210720
896,5.000790,0.210720
897,5.000790,0.210720
898,5.000790,0.210720
899,5.000790,0.210720
900,5.000790,0.210720
901,5.000590,0.211040
902,5.000590,0.211370
903,5.000790,0.211040
904,5.000590,0.211040
905,5.000590,0.210720
906,5.000590,0.211040
907,5.000590,0.211690
908,5.000790,0.210720
909,5.000790,0.210720
910,5.000790,0.210720
911,5.000790,0.210720
912,5.000790,0.210720
913,5.000790,0.210720
914,5.000790,0.210720
915,5.000790,0.210720
916,5.000590,0.210720
917,5.000590,0.210720
918,5.000590,0.211690
919,5.000790,0.210720
920,5.000590,0.210720
921,5.000590,0.210720
922,5.000790,0.211040
923,5.000590,0.210720
924,5.000790,0.210720
925,5.000790,0.210720
926,5.000790,0.210720
927,5.000790,0.210720
928,5.000790,0.210720
929,5.000790,0.210720
930,5.000790,0.210720
931,5.000790,0.210720
932,5.000590,0.211040
933,5.000590,0.210720
934,5.000590,0.210720
935,5.000590,0.250380
936,5.000590,0.249730
937,5.000590,0.251360
938,5.000590,0.236400
939,5.000590,0.250710
940,5.000590,0.250710
941,5.000590,0.250710
942,5.000590,0.250710
943,5.000590,0.250710
944,5.000590,0.250710
945,5.000590,0.250710
946,5.000590,0.250710
947,5.000590,0.235430
948,5.000590,0.235100
949,5.000590,0.236730
950,5.000590,0.275740
951,5.000590,0.250060
952,5.000590,0.236730
953,5.000590,0.250710
954,5.000590,0.250710
955,5.000590,0.250710
956,5.000590,0.250710
957,5.000590,0.250710
958,5.000590,0.250710
959,5.000590,0.250710
960,5.000590,0.250710
961,5.000590,0.288750
962,5.000590,0.244210
963,5.000590,0.252660
964,5.000590,0.281600
965,5.000590,0.279970
966,5.000590,0.279650
967,5.000590,0.281270
968,5.000590,0.279650
969,5.000590,0.279650
970,5.000590,0.279650
971,5.000590,0.279650
972,5.000590,0.279650
973,5.000590,0.279650
974,5.000590,0.279650
975,5.000590,0.279650
976,5.000590,0.076440
977,5.000590,0.073840
978,5.000590,0.075790
979,5.000590,0.073510
980,5.000590,0.075790
981,5.000590,0.073510
982,5.000590,0.075460
983,5.000590,0.073510
984,5.000590,0.075790
985,5.000590,0.075790
986,5.000590,0.075790
987,5.000590,0.075790
988,5.000590,0.075790
989,5.000590,0.075790
990,5.000590,0.075790
991,5.000590,0.075790
992,5.000590,0.075140
993,5.000590,0.073510
994,5.000590,0.075460
995,5.000590,0.073510
996,5.000590,0.073510
997,5.000590,0.073510
998,5.000590,0.073510
999,5.000590,0.073510
1000,5.000590,0.073510
1001,5.000590,0.073510
1002,5.000590,0.073510
1003,5.000590,0.073510
1004,5.000590,0.073510
1005,5.000590,0.073510
1006,5.000590,0.071560
1007,5.000590,0.071560
1008,5.000590,0.071560
1009,5.000590,0.071560
1010,5.000590,0.071560
1011,5.000590,0.071560
1012,5.000590,0.071560
1013,5.000590,0.071560
1014,5.000590,0.071560
1015,5.000590,0.071560
1016,5.000590,0.071560
1017,5.000590,0.071560
1018,5.000590,0.071560
1019,5.000590,0.071560
1020,5.000590,0.071560
1021,5.000590,0.071560
1022,5.000590,0.071560
1023,5.000590,0.071560
1024,5.000590,0.071560
1025,5.000590,0.071560
For some reason it has not included the logged power data in the CSV file. I need to investigate why this is the case. It's not actually an issue as we can reconstruct the power from the V and I data, which I will do in excel with a simple formula.
5.5.4. Using the Results Data
Once you have the data in a useful format there are many things you could so with it depending upon what the data represents. The simplest thing you can do is simply graph the data in Excel or Open/LibreOffice Calc (other Spreadsheets are available too, just use whatever you like and/or are familiar with). The following is a graph of the current (blue trace) and calculated power (red trace) for the experiment of booting up the Pi and running various benchmarks.
Using such tools you could easily calculate the average power consumption of a piece of equipment over time, or correlate particular operations happening on the hardware or in the software with peaks in power consumption, which,  if you are designing something that is required to run on batteries and needs to be low power, this can give some real insights into where to target your efforts in the design to get the best performance for the lowest power consumption.
You could of course bring the data into more comprehensive tools like MatLab, Octave, etc or write your own custom tools to process the data specific for your needs.
UPDATE 21/12/2017:
I've been experimenting and using the logging a little more and it really is very useful and as shows in one of the videos in his road test, there are plenty of more creative ways to make use of the logger. I have found a few limitations though which I think could be improved upon.
Firstly, when you set the logging period for an extended time, it gets to a point where is says there is not enough device memory and it starts to increase the logging interval. Why is this? If I am logging to a say 16Gb USB stick why am I restricted to the log size based upon memory available within the power supply itself? I would have thought even if it needs to use internal memory to capture the initial data, flushing this data to a file periodically should allow this to be able to continuously log until the USB is full. I hope this is something that can be corrected to allow the logging to be used more effectively for long term experiments.
Secondly, in order to start the logger I have to have a USB stick installed. What if I don't have a USB stick available? The logger then becomes unusable. This is a network connected device so why not have the ability to save to a network location or even use some remote logging server which the unit can connect to easily to store the logs?
Finally, I have noticed some waveform glitches on the display, regularly part of a trace will disappear for a second and then reappear. It's quite distracting having a flashing trace on the log view.
As a quick follow up to the earlier comment about the power trace not making it into the CSV file, I have not discovered the reason for this yet. If it's there as a trace I can enable for logging it should be in the file. Yes, I can create it from the V and I for the trace but if I have a long data set adding that column to my spreadsheet is fiddly and involves lots of scrolling. This should also be fixed. While I still think the logging is a great feature and very welcome, it isn't bug free and does have some limitations so for now I'm going to amend my review score down a point for the bugs and the newly discovered logging limitations. If a new firmware is released that resolves these issues I will report back and amend the score accordingly.
5.6. Using the Rear Outputs for 4-Wire Connections
5.6.1. Why 4-Wire Connections?
In an ideal world your wires which connect your power supply to your load would have zero or negligible impedance, but in reality there is a small impedance present, usually in the order of a few tens or hundreds of mOhm for typical bench hook up cables. For low current applications this small impedance makes almost no difference and the voltage measured directly at the load is almost identical to the voltage measured at the output of the power supply. As the current increases, using Ohms law (V = I/R) we can soon see how higher currents could lead to a significant drop in the voltage between the source and the load. In order to compensate, if the load was constant you could just raise the source voltage until the load voltage was at the desired level, but this is not a suitable approach as the load could change and you may end up with an over-voltage condition on the input to your load.
Usually the power supply will feed back the voltage it is using to control the output of the supply from as close to the output as possible. This compensates for any losses in the output stage of the supply but does nothing to help the case where there are additional external losses. This is where 4-Wire connections come into play. An additional pair of wires connect from the power supply to the load and these are used as dedicated sense pairs to measure the voltage directly at the load. These sense wires carry none of the output current so there is no current related voltage drop, it's an accurate measurement of the voltage directly at the load. This measurement is used instead (or as well as) of the internal voltage measurement to enable to supply to automatically deliver the desired voltage directly at the load.
5.6.2. The 4-Wire Test Setup and Results
With the output set to 2-Wire mode with a 5V output and 6.66A load (as reported on the TTi LD300 DC Electronic Load) the voltage measured on my DMM is 4.428V. This means that in my cabling between the power supply output and the load there is almost over 0.57V dropped. This is plenty to cause issues for test devices which require 5V +/-10%.
Update 20/12/2017: Having thoroughly investigated my strange readings I have discovered there was an issue with the measurements on my DMM and the voltages I was reading were not correct. Switching my TTi LD300 into meter display so it shows the voltage it sees on it's input and the current it is sinking, with a 10A load and in 2-Wire mode, the voltage at the input to the load is just 4.05V. If I vary the load the measured voltage varies as expected.
So it turns out the optimal test current for my particular the 4-Wire setup to be able to correct back up to exactly 5.000V as measure on my DMM is 6.66A. Above this and the PSU doesn't have enough headroom to be able to recover the voltage drop. But up to this, in my setup and the supply perfectly corrected back to exactly 5.000V.
Now to a slight issue, I then dropped the load to only 1A and the supply now incorrectly gives 5.168V measured on my DMM at the load. I need to do some more investigation on this as this is clearly not correct. I need to double check all my test setup and do some more analysis and see if I can fathom what is happening here.
Update 20/12/2017: As stated above, the readings from my DMM were incorrect. On the TTi LD300 meter view, with a 10A load and 4-Wire connections enabled the reading is now exactly 5.00V. This measurement now remains constant regardless of the load.
6. Road Test Summary and Conclusions
All in all I think this unit is very good. It packs in a lot of features and provides a really nice to use interface to access the features. My unit came with the USB/LAN and GPIB interfaces to connect with other systems easily and this opens up a whole lot of additional possibilities. I initially knocked off a couple of points in the "Performed to Expectations" section, one because of the mains hum from my unit, and one for the little niggles I discovered in the UI. Keysight will hopefully provide a firmware update to fix the UI issues at some point. With their response regarding the hum issue and their prompt action to replace my unit I am adding back the point I deducted for this as it appears to be specific to my unit and they are in the process of resolving the issue for me.
In comparison to the TTi units I already have you can see that it performs well. To be fair to TTi, all three unit's are very good but I think the Keysight E36313A out performs the TTi units in a few areas and the user interface and feature set is a deciding factor for me. The output can be seen from the various load tests and FFT's to be a little cleaner and some higher frequency artefacts which are present on the output of the TTi supplies are either not present or much reduced on the Keysight E363213A in comparison.
One thing I can't do with my TTi supplies is easily log data and this is a very valuable tool which the Keysight E36313A makes really easy to use. I can easily log the Voltage, Current, and Power from each of the three channels and then use this data to present these values in a useful and meaningful way or to process the data to extract hidden information such as tracking the overall power consumption of a low power device with many different power states over time.
This concludes my Road Test Review of the Keysight E36313A. Thank you all for reading this review and thanks again to Element 14 and Keysight for choosing me for this Road Test. It has been an honour to receive this item and a pleasure to go through and do a comprehensive review of this excellent piece of equipment. It's now 100% my go to power supply in my lab.
20/12/2017: I've updated the section above regarding the 4-Wire connections to correct my test results and report that is it in fact working well and exactly as expected.
21/12/2017: I've updated the section above regarding the logging capabilities to add my additional findings and limitations.
  •   wrote:
    it just took this page about 30 seconds to download the box to edit this reply after I clicked on the 'Reply' icon on Jan's post !
    Oh, I hope the Farnell website lack of speed debacle isn't spreading to here.... Alternatively it's going wrong because it knows isn't going to be around to fix it until January! image
  • Hello Jan,
    I have a DP832A of my own already but thank you for your kind offer.
    I've also got the older DP1308A (the '832A is much better).
    @Rachaelp, it just took this page about 30 seconds to download the box to edit this reply after I clicked on the 'Reply' icon on Jan's post !
    MK
  • wrote:
    Nice review - thanks.
    Thinking about the supply itself, it's quite competitively priced for a Keysight box, I think about the closest rival is the Rigol  DP832A which has most of the same features but seriously less good data logging. It's a lot cheaper (£519 against £1317). The Rigol does not have full three way isolation between channels which could be an issue (it has two isolated 30V 3A channels and one 6V which is common 0V with one of the others).
    MK
    I have that Rigol DP832A. Ping me if there's something you want to see compared.
  • Thank you!
    I've never used a Rigol product so I can't compare build quality, the quality or the accuracy of the outputs, or the usability of the user interface, etc of these. I have owned and been very happy with a number of Keysight and TTi products though. The TTi products feel a lot more utilitarian in their design, but they work well and do the job. For me the Keysight is a nice clean interface which is very easy to use and feels fairly polished and well thought out. The data logging feature is great and a hugely useful feature which I don't have in any of my other supplies, this in itself would be worth some of the extra cost to me. I think The E36313A compared well against the TTi units I was reviewing it against. The MX180TP looks like a really nice piece of kit too, but I don't have one to do a direct comparison. You are right, price wise the Keysight is a lot more than its budget rivals like Rigol and I would expect it to be, but I think the price/feature/quality/accuracy balance between the Keysight and TTi supplies is more useful and it really comes down to what features you really need, they both have their advantages and disadvantages.
    Best Regards,
    Rachael
  • Thanks Mark!
    I think they got the specs about right, a lot of boards I design have a 5V input (which I then generate other lower rails from) for all the digital stuff and this can sometimes be reasonably high current, and then for example a +/-15V pair of rails for the analogue section at lower current, or alternatively a 48V input if I am designing something that typically runs from PoE for example but I want to power it from a bench supply for development. I think this covers a lot of typical use cases. There are other times when you need higher voltage or higher current so I will be hanging onto my TTi supplies too for that reason (and because I am a test and measurement equipment hoarder! image ).
    Best Regards,
    Rachael
  • Nice review - thanks.
    I also have a TTi MX180TP which is way better than either for flexibility (two identical channels  plus one other with internal series or // operations) but, being a switcher is more noisy - it's £928.
    As ever with Keysight stuff it looks nicer to use - but is it nicer than three Rigol's, or one Rigol and one TTi etc etc ?
    MK
  • Nice review
    When this came up I was wondering what possible use there would be for this type of supply.
    Your review has certainly opened my eyes to some things I hadn't thought about.
    I've come from the days of higher voltage and current, but the reality is most of the work nowdays is 12v or less and a couple of amps, so the limits here are very suited going forward.
    It is nice to see Keysight backing up their brand by replacing the noisy version. Well done.
    Cheers
  • Thanks Gene. It's definitely found a good home here, it'll be well used. I'm just looking into some issues I have just this evening found with the 4-Wire measurement. I'll post back up with further results once I get a handle on what is going on.
    Best Regards,
    Rachael
  • rachaelp,
    A very clear, precise and timely roadtest. You were through and fair in your evaluation. It looks like that new and shinny power supply has found a very good home.
    Enjoy!
    Gene
  • Thanks DAB, I had a blast doing this so it's nice to know people like it! image
  • Very good road test report.
    Nice look inside, good verification testing and discussion of usability features.
    Well done.
  • Thanks Randall, I had a lot of fun writing this and I learned a lot not only about the supply but also about how to plan and write a road test. Great fun, I hope I am able to get the opportunity to do more of these in the future! image
  • Thanks Doug! I spent quite a bit of time planning the outline of what I wanted to do and I think it paid off image
  • Thanks John, until you get your hands on a unit like this you can't really get the impression for just how comprehensive its feature set is. I was fortunate to have a pretty good setup with my existing supplies, they are pretty high spec in themselves but they are also quite "traditional" bench power supplies with exactly the user interface and options you've come to expect from years of using this type of equipment. The user interface on the Keysight unit makes things feel much more slick and adding in the network connectivity, data logging, etc., it's really a very comprehensive tool. It's now going to be my main supply and my existing TTi supplies are going to be used when I need higher voltages, or in the case of the CPX400S, if I need a lot of current as it's a very powerful supply.
  • Rachael,
    For a first time roadtester, this is real good review. Detailed and I think balanced. The comparison is a good approach for a review. The video and screenshots, with commentary is what we like to see.
    As far as the power plug issue, I want to take a tad bit of responsibility. I usually catch this but this time I missed it. In hindsight, I should have looked and notified the roadtesters to make sure they select the proper mains voltage for their area.
    thanks for the review.
    Randall Scasny
    RoadTest Program Manager
  • Hi Rachael,
    Thank you for the comprehensive analysis of the power supply. I never dreamed that one could find so much depth to the subject of a power supply.
  • Excellent work - this is a very well organized and thorough description of the device's features and performance.
