RoadTests & Reviews
RoadTests & Reviews
Polls Like to Get an Intel Joule? Then Rate These Project Ideas
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: rscasny
  • Date Created: 31 May 2017 10:06 PM Date Created
  • Last Updated Last Updated: 11 Oct 2021 2:57 PM
  • Views 3211 views
  • Comments 32 comments
We received 188 applications for the Intel Joule RoadTest but only 5 units to actually RoadTest. The five official RoadTesters had great ideas. But there were many others with great, interesting and fun ideas. So, I went back to the supplier to see if it would sponsor some Intel joule projects. They agreed. These units would not be for a RoadTest per se but for project builds. The question is: what projects should we sponsor. And that's what I am posing to you. I have listed below the most interesting ideas offered by the Joule's RoadTest applicants. vote on which projects you would like to see built. the top ones I will forward to the supplier for sponsoring,
  • ntewinkel
    ntewinkel over 9 years ago +8
    Wow, a lot of those sound VERY ambitious. This is what my project proposal would look like: I would like to blink an LED. A red one. Oh and if a 3D printer or CNC company sponsorship can be included, I…
  • fvan
    fvan over 9 years ago +7
    Title of the poll is a bit confusing? "Like to Get an Intel Joule? Then Rate These Project Ideas" I interpret it as I could get a Joule, simply by rating the projects listed. Something like "Help your…
  • tekmeister
    tekmeister over 9 years ago in reply to mcb1 +5
    Sometimes these days it's actually easier to play a video than toggle a pin :-)
    beacon_dave over 7 years ago in reply to javagoza
    I had been pondering about suggesting survey and measured environment as a Project14 theme.
  • javagoza
    javagoza over 7 years ago
    I've voted for the remote monitoring of large structural elements of buildings because it's something that really worries me, especially in ancient structures and ephemeral or temporary structures.
  • rsc
    rsc over 9 years ago
    I would like to get a Joule, I just ran out of memory on my Edison.
    ffmpeg+edi-cam+fswebcam+node.js+socket.io+engine.io+update+upgrade = 100% full
    So many packages......so little eMMC........
    Scott
  • lex_b
    lex_b over 9 years ago in reply to pettitda
    It doesn't have to be tough, for example. Looking at the USB bus with 'lsusb' in terminal can give you many types of information.
    The most common to see how the devices are assign to a said USB hub is to use 'lsusb -t' in terminal.
    You can also use 'dmesg' to see what has loaded into your system from the time it started up until the current time. Of course you can use the pipe and grep command with double quotes if you need to search the dmesg log for something specific.
    You use 'lsmod' to check for loaded modules (drivers and memory resident libraries).
    There is a ready made package that is called, "hardinfo", can be run as normal user or root to gather all the system information you may need to troubleshoot or if you're curious in a graphical setting that is searchable tree, can save it as well, view the end result in a web browser. It's like Device Manager in Microsoft Windows but with an attitude, it has a lot more than just Device Manager has.
  • pettitda
    pettitda over 9 years ago in reply to tekmeister
    Navigating a Linux device tree can be daunting, so I hear.
  • lex_b
    lex_b over 9 years ago in reply to abhijitnathwani
    Use Intel Joule as an A.I. bot to gather user input on this site to write catchy clickbait titles.
    Okay, that was an off the wall comment but hey, it's possible. image
  • dweb98
    dweb98 over 9 years ago in reply to rscasny
    Cool!:) I would build a Video System. That runs on both a Battery and
    AC-DC Adapter. I would use it for Shooting Project Videos. And for
    Encoding Videos. The Sensors, could come in handy too. Perhaps, the
    Joule could turn the video recording on and off Automatically. According
    to Movement or Sound. Much like a Video Surveillance System. But, for
    other purposes...
    Don
  • fvan
    fvan over 9 years ago in reply to 14lsmith2
    There will probably be some boards free of charge, in exchange for one or more detailed blog posts on the actual project you pitched.
  • rscasny
    rscasny over 9 years ago in reply to 14lsmith2
    The supplier indicated to us they will provide some free of charge.
    balearicdynamics over 9 years ago in reply to rscasny
    Maybe good to add also the invite to users to make their proposal with the poll just as a starting point?
    Enrico
