RoadTests & Reviews
RoadTests & Reviews
Polls DIY which first?
  • Blogs
  • RoadTests
  • Reviews
  • Date Created: 31 May 2013 2:00 PM Date Created
  • Last Updated Last Updated: 11 Oct 2021 3:01 PM
  • Views 3075 views
  • Comments 24 comments
DIY which first?
Which DIY build would you do first? Based on if you haven't built or own one already.
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago +1
    A CNC router is simpler than the 3d printer but not by much, if you can't built one of those then for the same reasons you will fail with the 3d printer if your buying a kit then you can do the same for…
  • toxxn
    toxxn over 11 years ago +1
    Man, the options in this poll are tricky for me. Each one of these as a great range of usefulness. Although a DIY for a 3D printer would cost just as much as a cheap already made 3D Printer if you didn…
  • binarygenius
    binarygenius over 11 years ago in reply to cncdan
    The main reason decided not to use plans was because at the beginning i did not have much money but i did get given Hiwin 2xLGW 20 bearings, 2x 20mmx1350mm rails, 2xEGW25 bearings and 2x 25mmx240mm rail also i wanted to learn how to use CAD and this seemed as good a time as any. if you take a look at my profile pic http://www.element14.com/community/people/binarygenius i have used the alu cad model which i now have all the parts for it, the machine will have a cutting area of about 900mm x 1200mm x 160mm. if i was to buy everything in one go i know i would do things different but i had to work with what i had and i have learnt a lot making the mistakes with the MDF first But dont attempt a scratch build if you give up easy because building the machine is only 1 part of the whole project along with learning CAD, CAM, Control Software, Tooling, Feeds and Speed, Materials And much more but i would say it is all worth it in the end.
  • cncdan
    cncdan over 11 years ago in reply to binarygenius
    there are a lot of plans for mdf based cnc machines if you plan on doing a lot of cnc work they are ok for something to start with but you will out grow it quite fast and you will need to keep up with the calibration of the axis as they move a lot depending on the weather.
    on the other hand if you get one of those cheep chines ones you can out grow them depending on its size but they can be reused for a different type of machine like a laser or 3D printer very easy, or expanded
  • binarygenius
    binarygenius over 11 years ago in reply to e14 Contributor
    i`m currently building a machine which i have done about 5 years of research into all kinds of CNC and have a build log here First MDF CNC 3 Axis or how not to build a CNC where i built an mdf machine to learn a few things then invested in aluminium parts for a real machine i have twice as many pics and info to still upload so if you would like help give me a message and i will answer all i can for you mate.
  • cncdan
    with what I have read on cnczone and the mach3 forum there never seems to be any problem with the frames just the electronic can be 50/50 that's why I point to the frame only.
    as you can get something like a tiny G or a gecko G540 to run the machine you can get good kits from G540 Hybrid Stepper Motor Kits | Automation Technology Inc
    there are a few other that work good out there.
    its just depends how deep your pockets are
  • kidiccurus
    kidiccurus over 11 years ago in reply to cncdan
    I was looking at the smaller models, the 3020s. Just search 3020 CNC on eBay.
  • cncdan
    cncdan over 11 years ago in reply to kidiccurus
    you got me on that one
    what ever machine you get from china ask here and on cnczone about what ever machine you get.
    there is a couple you can get small ones that the frame is fine the electronics are 50/50 I cant remember name off but I will have a look.
    these one`s
    CNC Mainbody - carving-cnc.com
  • kidiccurus
    OK then, CNC rout a perfectly square hole in a flat piece of wood with no rounded edges. Sorry, I had to bring that up. I don't actually own either machine, so this is all just based on things I have learned second hand. My plan is to start with a cheap Chinese CNC router when I have a little more cash, and then move on to a 3d printer. Your impossible cube is pretty cool though.
  • cncdan
    you sure, the head cant get inside but cutters can it would be a two piece op.
    there is a big difference between how a 6 axis router and 3D printer work you just have to think out side the box with routers I have done things on my routers most people will say I cant do. routers can machine the machines imposable cube what's a ball inside a cube the ball can move inside the cube when the op is finished
    yes a 3D printer can do it to and cost a million dollars less
  • kidiccurus
    I have now, thank you YouTube. I stand by my comment. Can it cut an extruded spiral with a solid block on each end? No, the head can't get inside. Admtidly it can do almost any shape, but a sixaxis model is far more expensive than a 3d printer. Don't get me wrong, I like CNC routers, but 3d printing can do a lot as well.
  • cncdan
    ever seen a 6 axis working
