RoadTests & Reviews
RoadTests & Reviews
Polls DIY which first?
  • Blogs
  • RoadTests
  • Reviews
  • Date Created: 31 May 2013 2:00 PM Date Created
  • Last Updated Last Updated: 11 Oct 2021 3:01 PM
  • Views 3073 views
  • Comments 24 comments
DIY which first?
Which DIY build would you do first? Based on if you haven't built or own one already.
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago +1
    A CNC router is simpler than the 3d printer but not by much, if you can't built one of those then for the same reasons you will fail with the 3d printer if your buying a kit then you can do the same for…
  • toxxn
    toxxn over 11 years ago +1
    Man, the options in this poll are tricky for me. Each one of these as a great range of usefulness. Although a DIY for a 3D printer would cost just as much as a cheap already made 3D Printer if you didn…
  • kidiccurus
    kidiccurus over 11 years ago in reply to cncdan
    Because a 3d printer is an additive process you can do more complex shapes with it than with a cnc router. Cnc routers struggle with overhang and other complex shape where is a 3d can make these relatively easily by using support structures.
  • cncdan
    cncdan over 11 years ago
    a cnc router can do everything a laser or 3D printer can do but depends on how deep your pockets are. its very easy to convert a cnc router to a laser or have a laser add on for a router or 3D printer. you can get other types of laser other than tube or diodes
    I am doing a conversion from router to laser its very easy to do, you just need to know how they work
  • toxxn
    Although a DIY for a 3D printer would cost just as much as a cheap already made 3D Printer if you didn't have access to the parts already, I chose this option because I believe a 3D printer has a infinite amount of possibilities attached to it. Imagination is the limit.
  • timswift
    timswift over 12 years ago in reply to Robert Peter Oakes
    i agree
    if your buying a kit then you can do the same for either
  • kidiccurus
    kidiccurus over 12 years ago
    I'd do a 3d printer because I think they are more easy to build. I would like a CNC router but if I made it then it would fall apart, catch fire, melt and explode.
    build the CNC and use it when building your 3DP image
  • dnear1
    dnear1 over 13 years ago
    A CNC machine would be the best to start with.  One could always make an attachment to add 3d printing capability, possibly even adding mirrors later for use with a laser cutter.
    One difficulty with a laser cutter is the laser tube and power supply.  Even a low end cutter capable of cutting anything more than paper is going to cost a thousand or more just for a bare tube.
    e14 Contributor over 13 years ago in reply to dragonstyne
    I like the way you think Steve, that would be a very interesting project.
  • dragonstyne
    dragonstyne over 13 years ago
    Greetings,
    So, you build a CNC with changeable heads.
    That way you can have the best from all worlds.
    The X,Y & Z is the same.
    Regards,
