3D Printing
3D Printing
3D Printing Forum How to convert "SLICED", stl or obj files to JPEG or jpg file?
  • Replies 31 replies
  • Subscribers 342 subscribers
  • Views 8920 views
shahjee
shahjee over 11 years ago
I was wondering if a sliced .stl file (or any other 3 D file) can be converted to JPEG or jpg or similar  file, so that we can print on a desk jet, inkjet or similar printers.
  • Nate1616
    Nate1616 over 11 years ago in reply to shahjee +1
    Hello syed, If you are going for a 3DP/powder bed printer then I would check out this link. http://ytec3d.com/plan-b/ . This is a printer similar to what you are looking to do. Nate
  • shahjee
    shahjee over 11 years ago in reply to Nate1616 +1
    Thank you very much Nate. I appreciate your help and going out of way to help me. It looks like this printer is what I want to convert an inkjet printer. It says it will cost Euro 1000/= which seems to…
  • shahjee
    Thanks again. I need a lot of info to carry out the project.
    Jonathan Keep has demonstrated, how to make a ceramic 3 D printer. I was wondering, if I make one what quality will it make? If I try to make a statue or miniature of a person, will it print the facial details?
    My email address is kamranrizvi@hotmail.com.
  • Nate1616
    syed
    Jonathan's ceramic printer will get relatively good resolution for extruding paste.  You wouldn't get nearly as much detail as a FDM/FFF.  What are looking to print in ceramic. You might want to check out filament such a Lay-Ceramic http://www.makergeeks.com/laclba3dfi.html.
    Nate
  • bradnorwood
    bradnorwood over 11 years ago in reply to Nate1616
    I may build a machine this year for concrete.
  • shahjee
    shahjee over 11 years ago in reply to bradnorwood
    I would love to see that.
  • shahjee
    I was planning to make miniature statues with Jonathan Keep ceramic printer. I believe we  will achieve better results if we use DOSING pump instead of air pressure to move paste. With a dosing pump We can push the paste through a smaller nozzle to achieve better results. The dosing pump can help us control the flow better.
    I will ask Jonathan to carry out the test as well.
  • bradnorwood
    bradnorwood over 11 years ago in reply to shahjee
    Adafruit has a peristaltic pump that might work for you.
  • shahjee
    Thats what I had in mind
  • shahjee
    Thank you
  • Problemchild
    Problemchild over 11 years ago
    You could use Blender it's self to take the STL or OBj files then do a render to get the .JPG
    There's a bit of a procedure to go through for the STL but I believe it's googlable last time we tried the out put from a 3D scanner into Blender
  • shahjee
    shahjee over 11 years ago in reply to Problemchild
    Thanks a lot.
    What is Blender?
