3D Printing
3D Printing
3D Printing Forum Print your own PCBs
  • Replies 8 replies
  • Subscribers 341 subscribers
  • Views 1366 views
  • pcb
Print your own PCBs
Workshopshed
A nice technique using Ninjaflex filament to create flexible printed circuitboards.
3ders.org - 3D Print yourself an affordable and flexible circuit board | 3D Printer News & 3D Printing News
  • Problemchild
    Problemchild over 11 years ago +1
    I saw this on EETimes a few weeks ago it's a link to a link to the Instrucatble It's a good article but they dont's go in to to much depth about the actual etching process. Also I would of thought that…
  • timswift
    timswift over 11 years ago
    Do you use conductive glue with it?
    Tim
  • Problemchild
    I saw this on EETimes a few weeks ago it's a link to a link to the Instrucatble It's a good article but they dont's go in to to much depth about the actual etching process. Also I would of thought that under etching may well become a problem at smaller sizes.
    Personally I use copper backed Mylar that you can get for about £10 for an A4 sheet  then do a conventional photo etch.
  • Workshopshed
    Workshopshed over 11 years ago in reply to timswift
    No, it's a conventional etching process to make the board.
    I could be another one of those "if you have a hammer, everything is a nail" kind of situations. The origional author has access to a 3D printer so biased to using that whenever they can.
  • Problemchild
    Problemchild over 11 years ago in reply to Workshopshed
    I thought that , I think I may have another go at incorporating some Flex PCBs into a plastic model.... Would be very useful for say robotics applications
  • timswift
    timswift over 11 years ago in reply to Workshopshed
    What i meant was how do you connect the components.
    thanks
    Tim
  • Workshopshed
    You can still solder them
  • bwelsby
    bwelsby over 11 years ago in reply to timswift
    I was a little confused at first I thought that he used Ninjaflex as the substrate for a flexible pcb but having looked at the article and the tutorial I see that he is using the Ninjaflex as an etch resist because it sticks to copper.
  • Problemchild
    What's the temperature tolerance like?
