3D Printing
3D Printing
3D Printing Forum Purge to change material on a Robox
  • Subscribers 339 subscribers
  • Views 1066 views
  • abs
  • 3d
  • pla
  • material
  • purge
  • change
  • robox
danielw
danielw over 11 years ago
We're running a Robox printer currently with White PLA Material.  When we switched from the green ABS we ran the purge a few times until no more green could be seen.  We're on our second roll of white PLA and even now very oOccasionally get a speck of the green ABS come through which doesn't stick to the white and causes a failure in the print.  Has anybody else seen this?  I guess there must be some ABS hiding in there that a few purges haven't shifted, maybe a purge at a higher temperature would help?
Dan.
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +2
    Have you checked to see if there is any ABS sticking to the outside of the HEADS on the metal and it is simple falling off from time to time ? I have switched between PLA and ABS a few times on mine without…
    0 Robert Peter Oakes over 11 years ago
    I have switched between PLA and ABS a few times on mine without issue and I normally only run a single Purge cycle when I switch
    Try raising a ticket with CEL, there pretty quick to respond these days
    Peter
