3D Printing
3D Printing
3D Printing Forum Heater decoupled on homemade 3D printer.
  • Subscribers 342 subscribers
  • Views 1858 views
  • 3d printer
  • thermistor
  • heater
czkinicz
czkinicz over 9 years ago
Helo, I've build a 3D printer, usualy it works fine but sometimes it just decouples the hot end heater.
Firmware i'm using is Repetier and the error log displays this:
11:43:08.703 : Error:One heater seems decoupled from thermistor - disabling all for safety!
11:43:08.711 : Error:Temp. raised to slow. Rise = -1.53 after 13080 ms
I've read that i can disable the decouple test feature but i'd prefer to fix the problem not the symptom.
The thermistor might have a bad contact but i don't known what could be causing the slow temp rise. I'm only using one fan (on the heatsink) so that shoudn't be the problem. Any ideas?
  • fvan
    fvan over 9 years ago in reply to czkinicz +1
    Awesome, glad you got it sorted then
  • fvan
    0 fvan over 9 years ago
    Perhaps the thermistor is faulty and no longer measures temperature (changes) ?
  • czkinicz
    0 czkinicz over 9 years ago in reply to fvan
    I replaced the thermistor but it didn't help.
    0 balearicdynamics over 9 years ago
    Hello, please can you post what kind of printer are you using? And what kind of extruder model ? As far as I read it seems an MK8 series but it is better to be sure.
    In general, when the temperature raise  too slow may depends on some wrong wiring or connector. Without a clear image of what printer it is almost impossible to do a decent troubleshooting.
    Enrico
    0 balearicdynamics over 9 years ago in reply to fvan
    It is almost strange, at least with the Marlin/Marlin-compatible firmware. If the thermistor does not work it has a high resistance value so it is detected by the firmware as well. At least in most printers.
    Enrico
  • czkinicz
    OK, so it looks like it was a bad thermistor afterall. One was bad from the box.
  • fvan
    0 fvan over 9 years ago in reply to czkinicz
    Awesome, glad you got it sorted then image
