3D Printing
3D Printing
3D Printing Forum Ack! My trusty Monoprice Maker Select Plus is broken.  Any sugestions on a suitable replacement/upgrade?
  • Replies 13 replies
  • Answers 5 answers
  • Subscribers 340 subscribers
  • Views 4396 views
genebren
genebren over 5 years ago
About 6 hours into a 8 1/2 hour job, I finally took notice that my job was still a few layers above the raft.  Even though the head was moving, no filament was being extruded.  I am not sure of the order of events, but the filament was jammed.  Did the hot end cool too much to melt the filament? Did the filament actually jam entering the heater?  After a quick disassembly, I found a distorted filament (partially ground away) in the extruder drive housing.  After I reheated and cleared the tip, I extracted the remaining chuck of filament (very difficult as I could neither pull or push it with a hot tip).  I then fed new filament into the extruder and attempted to drive it into the heater.  Oh no, there was no filament movement (funny but after detecting the failure, I attempted to drive the extruder and thought that I had heard it driving???).  Moving the extruder motor into place on another driver it seemed to work.  I am now into a full disassembly to see if I can repair this unit.  Only time will tell.  I am also thinking about the possibility of buying a new printer to take the place as primary while I refurbish the existing one as a backup (or secondary) printer.
I am leading heavily into getting a new printer.  But now I face a dilemma, what kind of printer do I get?  I have not been looking around to see what else might be available and I still am a relative newbie to the world of 3D printers as this was my first printer, so I find myself not too well equipped to pick a replacement. Any suggestions as to designs, models or vendors would be a great help.  What features should I be considering at this point (auto leveling, upgraded hot ends, etc.)?
Thanks in advance,
Gene
  • fmilburn
    fmilburn over 5 years ago +8 suggested
    I have an Anycubic I3 Mega and prints are done using PLA so nothing exotic. I don’t level it frequently and haven’t added any upgrades. It has been reliable so I would say it has been good for a basic…
  • milosrasic98
    milosrasic98 over 5 years ago +7 verified
    Hi Gene! If you're looking for another printer, could you maybe tell us a bit what you're looking for in the printer, by that I mean, just some general stuff like, size of prints, are you planning on printing…
  • hlipka
    hlipka over 5 years ago in reply to milosrasic98 +7 suggested
    I can second the Prusa. Half a year ago I exchanged my K8200 for a Prusa MK3S, and I have not looked back (and in the 6 months I have printed more stuff than in the 5 years I owned the K8200). It really…
  • fmilburn
    0 fmilburn over 5 years ago in reply to genebren
    Looking forward to hearing about your experience with the new printer!
  • hlipka
    0 hlipka over 5 years ago in reply to genebren
    One tip (maybe the most important one apart from using the online guides for building the kit) is to use the 'Live Adjust' method for the first layer: https://projects.ttlexceeded.com/3dprinting_mk3_live_z_calibration.html  (or look at the original thread at the Prusa forums: https://forum.prusaprinters.org/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/life-adjust-z…  ). Its way better than using the built-in Live-Z procedure.
    0 genebren over 5 years ago in reply to hlipka
    Thank you for the tip.  I will have to look into this and get the best results possible.  Thanks again!
