3D Printing
3D Printing
3D Printing Forum 3d Printing Electronics for RepRap Prusa Mendel?
  • Subscribers 341 subscribers
  • Views 701 views
Hi everyone,
One of my members has a question:
Hi all!
I am working on getting my Prusa up and running, but I can't seem to get my electronics configured properly. I am concerned that there are problems with some of my other components, mainly my stepper motors, but i cant test them properly without working electronics.
If anyone has any that they don't need I would be happy to pay for a set that has been confirmed to be working with my printer model, or if anyone knows where i can get cheaper sets to experiment with (even the open source boards + components are usually ~$100) i would be quite appreciative. I am willing to pick up for boston-area folks.
-Max"
Original request here:
http://www.engineerslooking.com/need-stuff/3d-printing-electronics-for-reprap-prusa-mendel
Any help is appreciated!
  • Nate1616
    0 Nate1616 over 12 years ago
    Hey Richard
    When you say you can’t get the electronics configured what exactly do you mean?  Do you mean you are having issues with the firmware or wiring or something else?  What controller board are you using along with what’s the firmware that's loaded?
    Nate
    Richard, you should be able to test your stepper motors using an Arduino and some basic transistors, or using a simple tester like this one from Sparkfun (https://www.sparkfun.com/products/10267) that runs around $15. If your stepper motors drivers are damaged, you can test those using a multimeter to measure the voltage across each of the leads in sequence. If the control electronics are not working, then you would need access to a digital o-scope or something similar to let you observe the signal paths. Since most controllers are variations of Ardunio+RAMPS or something similar (RAMBo, RUMBA, etc are just single-board variations), you might be able to test the Arduino component itself by uploading another script via the IDE but then you would have to reflash the electronics back to their printer configuration afterwards. As Nate asks - can you say what exactly is wrong/not working properly?
    Kirk Hausman
    Thanks very much, Kirk!  Will let you know how Max goes with this advice and see if he can provide a bit more detail about the problem he's encountering.
