3D Printing
3D Printing
3D Printing Forum Axis slipping on printrbot simple
  • Subscribers 339 subscribers
  • Views 655 views
  • help
  • 3d_printing
  • simple
  • printrbot
  • asap
  • beginner
My y axis slips on my new simple seems to slip on my prints and I was wondering if there is a way on Repetier to re calibrate its axis' every few layers? or should I replace the sandpaper on it which is a little worse for wear?
  • Nate1616
    0 Nate1616 over 12 years ago
    Ezra
    I would change the sandpaper as its only going to get worse the more you print.  I cant think of any easy way to calibrate the machine mid print.  You could also add a little glue to the first wrap around the sandpaper to prevent it from slipping.  Just make sure to let the glue dry fully before adding further wraps of the string.
    Nate
