3D Printing
3D Printing
3D Printing Forum Input Voltage
  • Subscribers 341 subscribers
  • Views 419 views
Input Voltage
What is the maximum input voltage for the Beaglebone Black module?
    Although the voltage control is rated at 5.5VDC, my experience is that the actual limit is going to be closer to 5.2VDC unless you carefully control you power bus to avoid transient surges, etc. Analog inputs have a lower limit (1.8VDC), so just use Port 9 Pin 32 as your voltage source, if your analog sensor can work on 1.8V. Otherwise, use a voltage divider or bidirectional logic level converter to stay under the limits.
    Kirk
