3D Printing
3D Printing
3D Printing Forum What's the most key point when you decide to get a 3d printer?
  • Locked Locked
  • Replies 18 replies
  • Subscribers 340 subscribers
  • Views 8831 views
stephenleeeyan
stephenleeeyan over 4 years ago
As the title said, what's the key point when you want to get your first 3d printer? Speed or others?
  • Gough Lui
    Gough Lui over 4 years ago +5
    Probably price - the best printers are often out of reach of hobbyists. Print volume - larger volumes are more friendly for printing practical parts. Stepper motor drivers - some of the pricier ones…
  • robogary
    robogary over 4 years ago +4
    Price of course is primary, but next is ease of use and likelyhood of getting a good print with least effort first time. Shame I learned these desireables after I got a printer.
    dougw over 4 years ago +4
    3D printer requirements: it must be able to change filament in the middle of a print it must have auto bed levelling it must have a heated bed made of a material that will release the print when…
  • Gough Lui
    Stepper motor drivers - some of the pricier ones from Trimatic are notably quieter than the alternatives.
    Material compatibility - heated bed, all-metal hot-ends, enclosure option are helpful to ensure material compatibility beyond the basic PLA.
    Ease of construction - some printers are a bit challenging to set-up.
    Spare part availability and cost - parts wear out over time, so knowing that the printer is supported is good. Also knowing what options are available for tuning the printer to your needs is also good.
    Print speed is very hard to gauge - the manufacturer specifications are rarely meaningful as higher speeds often leads to reduced quality and details. However, the design of the printer will also affect this tradeoff - CoreXY designs tend to be more capable of high speeds because the model itself (of varying weight) is not moving during the print.
    - Gough
    • Vote Up +5 Vote Down
  • cstanton
    cstanton over 4 years ago
    Either:
    - "I want to learn a new skill and I've set aside enough money, and the price point of the 3D printer and the accessories match that price point"
    or
    - "I have enough items and problems that I can solve using these 3D computer aided design models, that I should just get my own 3D printer to create them, rather than trying to use the local Hackspace 3D printer or services to print one"
    That's the key point(s) when I want to get my first 3D printer - or an alignment of the two.
    What the kinda real question for a lot of people I see is: "What's the most key point when you decide you need a second 3D printer?"
    That's usually down to "What materials do I need to 3D print in?" and then if you were using Filament you stray into Resin, or from Resin to Filament.
    Of course some people go straight to Resin 3D printers because they're into model making or similar and want to do it as a business.
  • robogary
    • it must be able to change filament in the middle of a print
    • it must have auto bed levelling
    • it must have a heated bed made of a material that will release the print when it cools off
    • it must have accessible components, easy to service
    • it should be very quiet
    After that look for the biggest, stiffest printer you can afford.
    Note that enclosed printers can be hard to service. If you need an enclosure, build one that is easily removed.
  • baldengineer
    baldengineer over 4 years ago
    I'm not sure if I understand your question correctly. Are you asking "when is the key point [in time]" to get a 3d printer or "when getting a 3d printer what is the key point [feature] to consider?"
  • phoenixcomm
    phoenixcomm over 4 years ago
    Mostly price. I decided to roll my own, as I'm not too fond of what's out there. And if you want to print a 2-foot cube of useable space.,  you are out of luck. Plus if you want to also do laser engraving or CNC you have to rebuild or buy the world all over again.  Also, the beds need constant leveling.  I want something that's versatile. with different heads. That's why  I am trying to build my own. 1. the bed should NEVER move!  This means that all my axis travels are on a gantry.  Also, I plan on keeping filaments in an N2 cabenit. my Also, the hot ends don't get hot enough to use carbon fiber. "Nozzle temperature: 270 – 290°C."
  • rsjawale24
    rsjawale24 over 4 years ago
    For me it was the price. As I was going to use it for my hobby/DIY projects, I didn't need any high end specs and resolution or speed or special materials. I went with the Ender 3V2 because it was relatively less expensive as compared to the other 3D printers in the market. Also the reviews were pretty good.
    If it's just for hobby use, I would recommend Creality printers.
  • ntewinkel
    ntewinkel over 4 years ago
    I would say price and ease of use.
    If you get something that’s inexpensive but difficult to use, or difficult to get nice results from, you’ll just get too frustrated and end up wasting a lot of time, or maybe just not using it.
    If you get something super expensive and then you find you don’t enjoy the new hobby as much as you thought you would, you’ll regret it. The way I see it, you’ll learn what you really want and need while using the starter-priced printer that can then lead you to make a decision that’s more tuned to your personal needs… or maybe the starter printer is exactly what you need for your personal use!
    To start out with, I also recommend to just stick with PLA. Other filaments can make life hard, regardless of the printer.
    I’m still very much a beginner, and I’m quite happy with the relatively affordable Creality Ender 3pro I have. It did give me some frustration with a broken plastic part, so maybe that’s where a more expensive better model with stronger parts might have saved the pain. But the metal replacement part upgrade was only $10 and was easy to install.
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to ntewinkel
    PLA for me is only good for small lightweight parts. I would use PLA just to prove my design and then switch to carbon. You ask, why do I want carbon parts? Easy since my long-term goal is to fly and the plane uses 2 e-fans, each blade is twisted and bent, and 18 inches long., So. PLA is out of the question.
  • saadtiwana_int
    saadtiwana_int over 4 years ago
    Main limitation is always the price. Now, within your price range, go for the following (in decreasing order of importance)
    - Bigger print volume
    - Support for more materials. At the least ABS and PLA.  (ABS usually requires a heated bed and enclosure for best results)
    - Good software support
    - Auto levelling is very good-to-have feature, but not critical if you have to compromise on other things
    - Dual head is convenient, but in my experience doesn't get used much.
    - Low noise level (good to have)
